08-29-2019, 12:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | frp not removed BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_SWSEC_HUA_3.bin BR ComPort: COM5 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: 14000000 DA AgentId: SA4C97CE07F4846E0F DA Version: MTK_AllInOne_DA_v3.3001.00.00. BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -15 Last USB Exception: 0x03E3 The I/O operation has been aborted because of either a thread exit or an application request. Can be Cable Problem or Battery Low ! Huawei LUA-L21 ROW (Y3 II LTE DS Luna) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_SWSEC_HUA_3.bin BR ComPort: COM5 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: 14000000 DA AgentId: SA4C97CE07F4846E0F DA Version: MTK_AllInOne_DA_v3.3001.00.00. BR_RUN_D5 Error: -1 -1 Possible not Valid DA Agent BR_BOOT Error: -15 Reset FRP 0 Failed: -15 DA_SHUTDOWN Error: -2 Last USB Exception: 0x0002 The system cannot find the file specified. Huawei LUA-L21 ROW (Y3 II LTE DS Luna) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_SWSEC_HUA_3.bin BR ComPort: COM5 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: 14000000 DA AgentId: SA4C97CE07F4846E0F DA Version: MTK_AllInOne_DA_v3.3001.00.00. BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -15 Last USB Exception: 0x03E3 The I/O operation has been aborted because of either a thread exit or an application request. Can be Cable Problem or Battery Low ! Huawei LUA-L21 ROW (Y3 II LTE DS Luna) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_SWSEC_HUA_3.bin BR ComPort: COM5 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: 14000000 DA AgentId: SA4C97CE07F4846E0F DA Version: MTK_AllInOne_DA_v3.3001.00.00. BR_RUN_D5 Error: -1 -1 Possible not Valid DA Agent BR_BOOT Error: -15 Reset FRP 0 Failed: -15 DA_SHUTDOWN Error: -2 Last USB Exception: 0x0002 The system cannot find the file specified. Huawei LUA-L21 ROW (Y3 II LTE DS Luna) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_SWSEC_HUA_3.bin BR ComPort: COM5 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: 14000000 DA AgentId: SA4C97CE07F4846E0F DA Version: MTK_AllInOne_DA_v3.3001.00.00. BR_LOAD_D7 Error: -7, 184 BR_BOOT Error: -14 Last USB Exception: 0x03E3 The I/O operation has been aborted because of either a thread exit or an application request. Can be Cable Problem or Battery Low ! |
08-31-2019, 07:59 | #2 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1596913 Status: Offline Thanks Meter: 107 | Firmware if Secureboot 0. Install original driver Huawei_Y3II_LUA-L21_SP_Drivers_2.0.rar 1. Off phone. 2. Open factory LUA L21_SP_Flash_Tool_exe_Windows_v5.1528.00.000_0225. rar 3. Click Download Agent and select DA_SWSEC.bin which is in the folder firmware \signed_bin\DA\DA_SWSEC.bin 4. Click Scatter-loading and choose MT6735M_Android_scatter.txt (your firmware) 5. Change the selector to " Download "in this mode to uncheck" PRELOADER " [block]. 6. Press the Download button and connect the phone to the battery, after flashing off the USB cable and distort the battery. https://androidhost.ru/J7 |
