07-11-2019, 11:32 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | frp reset error DL MODE : 6 DL_DLRQ Failed: -1 Device not in Flash Mode, will Switch now None of Diags Ports Selected LG H990DS (V20 DS) at Auto Select Flash Port [LG FLASH 69] {Reset FRP} DL MODE : 6 DL_DLRQ Failed: -1 Device not in Flash Mode, will Switch now Comms Failed: -1 (No Response) DL MODE : 6 DL_DLRQ Failed: -1 LG H990DS (V20 DS) at Auto Select Flash Port [LG FLASH 69] {Reset FRP} DL MODE : 6 DL_DLRQ Failed: -1 Device not in Flash Mode, will Switch now Comms Failed: -1 (No Response) DL MODE : 6 DL_DLRQ Failed: -1 LG H990DS (V20 DS) at Auto Select Flash Port [LG FLASH 69] {Reset FRP} DL MODE : 6 DL_DLRQ Failed: -1 Device not in Flash Mode, will Switch now Comms Failed: -1 (No Response) DL MODE : 6 DL_DLRQ Failed: -1 LG H990DS (V20 DS) at Auto Select Flash Port [LG FLASH 69] {Reset FRP} Flash Port not Found LG H990 (V20 DS) at Auto Select Flash Port [LG FLASH 69] {Reset FRP} DL MODE : 13 DL_DLRQ Failed: -4 Device not in Flash Mode, will Switch now None of Diags Ports Selected LG H990 (V20 DS) at USB [ADB] {ADB Info} daemon started successfully * <<< STOP >>> ADB Connection Break ADB Connection Aborted LG H990 (V20 DS) at Auto Select Flash Port [LG FLASH 69] {Reset FRP} DL MODE : 13 DL_DLRQ Failed: -4 Device not in Flash Mode, will Switch now OFFLMODE: OK FLASHMOD: OK DL MODE : 2 DL REQM : 5 DL MODEL: LG-H990ds DL SWVER: H99020a DL IMEI : 352163-08-236081-9 LF MODEL: LG-H990ds LF SWVER: LGH990dsAT-00-V20a-AME-XX-NOV-21-2018+0 LF MINOS: MiniOS 3.0 LF OSVER: 8.0.0 LF IMEI : 352163-08-236081-9 LF DVPID: SM02S170114003772 LF SOCTY: msm8996 LF CABLE: 633A LAF_WRTE Bad Response Type: -5, 4641494C Misc Write Failed: -5 LG H990DS (V20 DS) at USB (COM56) [LG FLASH 69] {Reset FRP} DL MODE : 2 DL REQM : 5 DL MODEL: LG-H990ds DL SWVER: H99020a DL IMEI : 352163-08-236081-9 LF MODEL: LG-H990ds LF SWVER: LGH990dsAT-00-V20a-AME-XX-NOV-21-2018+0 LF MINOS: MiniOS 3.0 LF OSVER: 8.0.0 LF IMEI : 352163-08-236081-9 LF DVPID: SM02S170114003772 LF SOCTY: msm8996 LF CABLE: 633A LAF_WRTE Bad Response Type: -5, 4641494C Misc Write Failed: -5 |
