05-23-2017, 12:25 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Tunisia
Member: 520537 Status: Offline Thanks Meter: 230 | How to know the bot version of HUAWEI LUA-U22 Last edited by MyGSM World; 05-23-2017 at 14:31. Reason: Website Link Removed. |
05-23-2017, 13:04 | #3 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | All ADB 'Visual' commands can be done using [Send ADB] and File, partition transfers can be done using [Read Part.] here can use all ADB modifiers,: block=, count=, ... also specify file instad of partition, because it do DD command in fact |
The Following 2 Users Say Thank You to Sha For This Useful Post: |
05-23-2017, 13:06 | #4 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | dd if='line from pop-up' of=data/local/tmp/blabla and after pull to PC |
The Following User Says Thank You to Sha For This Useful Post: |
05-23-2017, 13:21 | #5 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | as dd accepts modifier switches in any location of command string so we can use: dev/block/mmcblk0 count=34 to read out a emmc GPT entry, which is located at emmc very first block Superuser Permissions Granted (SU) Reading Partition: dev/block/mmcblk0 count=34 Transfered: 679 KB/s (17408 bytes in 0.025s) Saved as: XXXX_SM-N9005_d0eab6df_PT_mmcblk0 count=34 [2017_05_23_15_17_23].bin Path: C:\Program Files (x86)\SarasSoft\ANDROID_UFS_1053_Test24\nnnn\PART\ Read Part. Done in: 00:06.530 so not need to masturbate with normal ADB command strings and think how to pull data out |
05-23-2017, 13:48 | #6 (permalink) | |
Member: 520537 Status: Offline Thanks Meter: 230 | Quote:
to read out a emmc GPT entry, which is located at emmc very first block | |
The Following User Says Thank You to bouali2009 For This Useful Post: |
05-23-2017, 13:58 | #9 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | MT6572 is using an medievial EBR partition mapping (like DOS), but if try some MT6580 or MT67xx will see all beauty of GPT ... |
05-23-2017, 14:04 | #10 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | can use any ADB commands in [Send ADB] for example: ls -l -a drwxr-xr-x root root 2014-02-24 04:46 acct drwxrwx--- system cache 2014-03-11 23:51 cache dr-x------ root root 2014-02-24 04:46 config lrwxrwxrwx root root 2014-02-24 04:46 d -> /sys/kernel/debug drwxrwx--x system system 2017-05-23 16:01 data -rw-r--r-- root root 474 1970-01-01 03:00 default.prop drwxr-xr-x root root 2017-05-18 06:58 dev drwxrwx--x system radio 2015-04-10 02:04 efs ......... |
