Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 05-23-2017, 12:25   #1 (permalink)
bouali2009's Avatar
Member: 520537
Thanks Meter: 230
Thumbs up How to know the bot version of HUAWEI LUA-U22
How to know the boot version of HUAWEI LUA-U22 with ufst
The Following 2 Users Say Thank You to bouali2009 For This Useful Post:
Old 05-23-2017, 12:58   #2 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
can use also [Send ADB] with default 'getprop'
The Following User Says Thank You to Sha For This Useful Post:
Old 05-23-2017, 13:04   #3 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
All ADB 'Visual' commands can be done using [Send ADB]
and File, partition transfers can be done using [Read Part.]
here can use all ADB modifiers,: block=, count=, ...
also specify file instad of partition, because it do DD command in fact
The Following 2 Users Say Thank You to Sha For This Useful Post:
Old 05-23-2017, 13:06   #4 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
dd if='line from pop-up' of=data/local/tmp/blabla
and after pull to PC
Old 05-23-2017, 13:21   #5 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
as dd accepts modifier switches in any location of command string so we can use:
dev/block/mmcblk0 count=34
to read out a emmc GPT entry, which is located at emmc very first block
Superuser Permissions Granted (SU)
Reading Partition: dev/block/mmcblk0 count=34
Transfered: 679 KB/s (17408 bytes in 0.025s)
Saved as: XXXX_SM-N9005_d0eab6df_PT_mmcblk0 count=34 [2017_05_23_15_17_23].bin
Path: C:\Program Files (x86)\SarasSoft\ANDROID_UFS_1053_Test24\nnnn\PART\
Read Part. Done in: 00:06.530
so not need to masturbate with normal ADB command strings
and think how to pull data out
Old 05-23-2017, 13:48   #6 (permalink)
bouali2009's Avatar
Member: 520537
Thanks Meter: 230
The Following User Says Thank You to bouali2009 For This Useful Post:
Old 05-23-2017, 13:52   #7 (permalink)
bouali2009's Avatar
Member: 520537
Thanks Meter: 230
Sha //// You can explain the operation of this file
( emmc GPT entry )
MT6572_EverGlowD35_0123456789ABCDEF_PT_mmcblk0 count=34 [2017_05_23_13_42_22]
Old 05-23-2017, 13:56   #8 (permalink)
bouali2009's Avatar
Member: 520537
Thanks Meter: 230
Are there any other ADB command ????
And their operation ?????
Old 05-23-2017, 13:58   #9 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
MT6572 is using an medievial EBR partition mapping (like DOS),
but if try some MT6580 or MT67xx will see all beauty of GPT ...
Old 05-23-2017, 14:04   #10 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
can use any ADB commands in [Send ADB]
for example:
ls -l -a
drwxr-xr-x root root 2014-02-24 04:46 acct
drwxrwx--- system cache 2014-03-11 23:51 cache
dr-x------ root root 2014-02-24 04:46 config
lrwxrwxrwx root root 2014-02-24 04:46 d -> /sys/kernel/debug
drwxrwx--x system system 2017-05-23 16:01 data
-rw-r--r-- root root 474 1970-01-01 03:00 default.prop
drwxr-xr-x root root 2017-05-18 06:58 dev
drwxrwx--x system radio 2015-04-10 02:04 efs
Old 05-25-2017, 07:09   #11 (permalink)
Member: 2487681
Thanks Meter: 6
You need firmware if you need it i have it can i help U
تم الإرسال من MHA-L29 باستخدام Tapatalk
Page generated in 0.15997 seconds with 8 queries
