07-20-2018, 22:42 | #5 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1596913 Status: Offline Thanks Meter: 107 | If you don't have a password or a tethered SIM card along with email access, you can try writing in support of Xiaomi. It can take from a few weeks to a month for the application to be approved. During this time, you will communicate with consultants of the famous brand, send them photos of your device box as confirmation that you are not a fraud and you have not stolen this device, and want to get someone else's Mi account data. You can write to the support at the following e-mail addresses: [email protected] [email protected] If these methods did not help you – to solve the problem with the account will help its unbinding and the creation of a new one on the official site of Xiaomi. And if easier, then unlocking bootloader and full flashing or change IMEI |
07-21-2018, 01:48 | #6 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Reflash ONLY persist partition is more easy than bla bla with xiaomi officials... |
The Following 7 Users Say Thank You to Sha For This Useful Post: |
07-22-2018, 22:35 | #8 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | what a dead with flashing an original files ? But here we have some probs, (You dont say exact model) problem is on new models (A5) Mi Account is on file system, so cannot throw out it without a full format on persist is a emergency copy, which will come back, if was not fired so if You want save data and disable Mi - not possible if want remove, just rewrite persist and format user Thats all And do not forget about other end of stick: Traces of your (not yours) phone still is on Xiaomi server So what "Professional boxes do" it is a format of persist and user partitions in fact. its can be done easy with ufst using [Format Flash] button and entering: persist, userdata on requestor, but will (maybe) have restart problem on modern phones, because of empty "persist" So conclusion: Download original software from Mi support and flash it - No data - No problem and have last version .... with stupid format of "persist" (like profesional boxes do: "First in the world one button solution") will loose a sensors, bt and wifi data so anyway will need to reflash it to original ... This is why we do not distribute this solution as "First in The World" just use [Format Flash] Button, if you know what you are doing ... We are not 1st in the world, we not do 1st in the world solutios (its already done by manufacturers) we only care to resolve your device problems, keep safe ... if have more questions and(or) skills just look to: "dc" file on rooted device under "persist" Last edited by Sha; 07-23-2018 at 00:04. |
The Following 6 Users Say Thank You to Sha For This Useful Post: |
07-23-2018, 19:48 | #10 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | all you need is to seach the firehose and a small soft emmcdl.exe (173kb Md5:E1FCF8504051AEA8741B446E294DC3BB) emmcdl -p com25 -f prog_emmc_firehose_xxx_ddr.mbn -gpt > gpt.txt backup persist and config emmcdl -p com25 -f prog_emmc_firehose_xxx_ddr.mbn -d config -o config.img emmcdl -p com25 -f prog_emmc_firehose_xxx_ddr.mbn -d persist -o persist.img erase persist and config(frp) emmcdl -p com25 -f prog_emmc_firehose_xxx_ddr.mbn -e persist emmcdl -p com25 -f prog_emmc_firehose_xxx_ddr.mbn -e config for help emmcdl.exe |
07-23-2018, 21:19 | #11 (permalink) |
Member: 1596913 Status: Offline Thanks Meter: 107 | Ok! https://mega.nz/#!XI0nEL6K!RJMzHa4NZ...311OxwVsR7pk0A Yes, everything can be done "manually", but the programmer is needed mainly to save time, so it is very useful to add all this to it and preferably in automatic mode, otherwise why do you need it? Last edited by vaterpahk; 07-23-2018 at 21:28. |
07-27-2018, 01:16 | #12 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Why so complicated ? All is implemented, need only have little bit of knowledge and use. Just Press [Read Flash] button and can Backup what you want. Firehose will be selected auto (If right Model selected) Rawprogram.xml and Patch.xml will be generated auto. If have Original UFST cable, EDL (DeepFlash) cable will be emulated by Option [EDL Cable] |
The Following User Says Thank You to Sha For This Useful Post: |
07-27-2018, 14:11 | #13 (permalink) |
Member: 1596913 Status: Offline Thanks Meter: 107 | And why is it so difficult to make a "reset mi" button in the shell, as you did "reset frp"? About the EDL cable and TestPoint all know for a long time! Do a quick reset, reading takes a long time. And finally run the server! Still haven't found the fan? |
The Following User Says Thank You to vaterpahk For This Useful Post: |
07-27-2018, 19:57 | #14 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | i agree with vaterpahk saras boxes are powerful and the best but its deal with all users as programmers its was better to make he shell more simple and where is Samsung updates unlock frp remove sreen lock remove imei cert write and the thing i asked team very long time ago QCN write till now not supported |
07-28-2018, 14:10 | #15 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | @vaterpahk "And why is it so difficult to make a "reset mi" button in the shell, as you did "reset frp"?" Read carefully again Post#8 and you will see why. Mi can be done easy with [Format Flash] here can specify multiple partitions: "persist, userdata, cache" But anyway after this you will need to reflash with original files of these partitions, because of issues hapenning after this (Explaned in Post #8) And in any case personal data will be loosed (Did you need someones personal data ?) So why need format (Reset Mi) and after see issues, reflash it with original files to correct them ? It seems like useless work (or maybe customer not cares about these issues ?) Last edited by Sha; 07-28-2018 at 14:23. |
The Following 2 Users Say Thank You to Sha For This Useful Post: |
