07-06-2019, 17:28 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | lyf ls-5016 hang on logo flashing done Var LYF-LS-5016 (Wind 7 LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM11) SAHARA VERS: 2.1 SAHARA HWID: 009600E100000000 [MSM8909] SAHARA HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F SAHARA SERN: 08200B73 (136317811) SAHARA PROG: prog_emmc_firehose_8909_ddr_lyf.mbn SAHARA PRID: SA2605357B81D6C2D1 Write Flash Done in: 00:00.000 Last USB Exception: 0x001F A device attached to the system is not functioning. Can be Cable Problem or Battery Low ! Var LYF-LS-5016 (Wind 7 LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM11) SAHARA VERS: 2.1 SAHARA HWID: 009600E100000000 [MSM8909] SAHARA HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F SAHARA SERN: 08200B73 (136317811) SAHARA PROG: prog_emmc_firehose_8909_ddr_lyf.mbn SAHARA PRID: SA2605357B81D6C2D1 Write Flash Done in: 00:00.000 Last USB Exception: 0x001F A device attached to the system is not functioning. Can be Cable Problem or Battery Low ! Var LYF-LS-5016 (Wind 7 LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} Qualcomm HS-USB QDLoader 9008 Port not Found: Vid_05c6&Pid_9008 Bad Port: SAHARA Connect Fail: -1 Var LYF-LS-5016 (Wind 7 LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM43) SAHARA VERS: 2.1 SAHARA HWID: 009600E100000000 [MSM8909] SAHARA HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F SAHARA SERN: 08200B73 (136317811) SAHARA PROG: prog_emmc_firehose_8909_ddr_lyf.mbn SAHARA PRID: SA2605357B81D6C2D1 FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8909 FHPROG MEMT: eMMC FHINFO DSK0: 30535680 x 512 Sectors (14.56 GB) FHINFO DSK1: 8192 x 512 Sectors (4 MB) FHINFO DSK2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 Flash Bundle: rawprogram_unsparse.xml Partitions to Write: 107 (2.68 GB) FWRITE DONE: DSK0 ST 0x0000020000 modem 50.41 MB FWRITE DONE: DSK0 ST 0x0000040000 sbl1 241 KB FWRITE DONE: DSK0 ST 0x0000040400 sbl1bak 241 KB FWRITE DONE: DSK0 ST 0x0000040800 aboot 449.84 KB FWRITE DONE: DSK0 ST 0x0000041000 abootbak 449.84 KB FWRITE DONE: DSK0 ST 0x0000041800 rpm 159.14 KB FWRITE DONE: DSK0 ST 0x0000041C00 rpmbak 159.14 KB FWRITE DONE: DSK0 ST 0x0000042000 tz 534.41 KB FWRITE DONE: DSK0 ST 0x0000042600 tzbak 534.41 KB FWRITE DONE: DSK0 ST 0x0000045412 splash 2.64 MB FWRITE DONE: DSK0 ST 0x0000060C40 sec 80 Byte FWRITE DONE: DSK0 ST 0x0000060C60 boot 8.69 MB FWRITE DONE: DSK0 ST 0x0000070C60 system 128.01 MB FWRITE DONE: DSK0 ST 0x00000B1268 system 8 KB FWRITE DONE: DSK0 ST 0x00000B2278 system 125.23 MB FWRITE DONE: DSK0 ST 0x00000F0C60 system 8 KB FWRITE DONE: DSK0 ST 0x00000F1C70 system 125.99 MB FWRITE DONE: DSK0 ST 0x0000130C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000131268 system 8 KB FWRITE DONE: DSK0 ST 0x0000132278 system 125.23 MB FWRITE DONE: DSK0 ST 0x0000170C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000171C70 system 125.99 MB FWRITE DONE: DSK0 ST 0x00001B0C60 system 8 KB FWRITE DONE: DSK0 ST 0x00001B1268 system 8 KB FWRITE DONE: DSK0 ST 0x00001B2278 system 125.23 MB FWRITE DONE: DSK0 ST 0x00001F0C60 system 8 KB FWRITE DONE: DSK0 ST 0x00001F1C70 system 125.99 MB FWRITE DONE: DSK0 ST 0x0000230C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000231268 system 8 KB FWRITE DONE: DSK0 ST 0x0000232278 system 125.23 MB FWRITE DONE: DSK0 ST 0x0000270C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000271C70 system 125.99 MB FWRITE DONE: DSK0 ST 0x00002B0C60 system 8 KB FWRITE DONE: DSK0 ST 0x00002B1268 system 8 KB FWRITE DONE: DSK0 ST 0x00002B2278 system 125.23 MB FWRITE DONE: DSK0 ST 0x00002F0C60 system 8 KB FWRITE DONE: DSK0 ST 0x00002F1C70 system 125.99 MB FWRITE DONE: DSK0 ST 0x0000330C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000331C70 system 125.99 MB FWRITE DONE: DSK0 ST 0x0000370C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000371C70 system 125.99 MB FWRITE DONE: DSK0 ST 0x00003B0C60 system 8 KB FWRITE DONE: DSK0 ST 0x00003B1C70 system 125.99 MB FWRITE DONE: DSK0 ST 0x00003F0C60 system 8 KB FWRITE DONE: DSK0 ST 0x00003F1C70 system 125.99 MB FWRITE DONE: DSK0 ST 0x0000430C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000431C70 system 125.99 MB FWRITE DONE: DSK0 ST 0x0000470C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000471C70 system 68.68 MB FWRITE DONE: DSK0 ST 0x00004B0C60 system 8 KB FWRITE DONE: DSK0 ST 0x00004F0C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000530C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000570C60 system 8 KB FWRITE DONE: DSK0 ST 0x00005B0C60 system 8 KB FWRITE DONE: DSK0 ST 0x00005F0C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000630C60 system 8 KB FWRITE DONE: DSK0 ST 0x0000670C60 persist 4.6 MB FWRITE DONE: DSK0 ST 0x0000680C60 cache 6.09 MB FWRITE DONE: DSK0 ST 0x00006C0C60 cache 8 KB FWRITE DONE: DSK0 ST 0x00006C0CE8 cache 8 KB FWRITE DONE: DSK0 ST 0x0000700C60 recovery 9.85 MB FWRITE DONE: DSK0 ST 0x0000740400 config 512 KB FWRITE DONE: DSK0 ST 0x0000740800 userdata 126.83 MB FWRITE DONE: DSK0 ST 0x0000780800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000781008 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000782018 userdata 122.54 MB FWRITE DONE: DSK0 ST 0x00007C0800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000800800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000801008 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000802018 userdata 121.6 MB FWRITE DONE: DSK0 ST 0x0000840800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000880800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000881008 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000882018 userdata 121.14 MB FWRITE DONE: DSK0 ST 0x00008C0800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000900800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000901008 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000902018 userdata 80.39 MB FWRITE DONE: DSK0 ST 0x0000940800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000980800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000981008 userdata 8 KB FWRITE DONE: DSK0 ST 0x00009C0800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000A00800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000A40800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000A80800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000AC0800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000B00800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000B40800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000B80800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000BC0800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000C00800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000C40800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000C80800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000CC0800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000D00800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000D40800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000D80800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000D81008 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000DC0800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000E00800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000E01008 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000E40800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000E80800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000EC0800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000F00800 userdata 8 KB FWRITE DONE: DSK0 ST 0x0000000000 PrimaryGPT 17 KB FWRITE DONE: DSK0 ST 0x0000000021 BackupGPT 16.5 KB FPATCH DONE: 13, Used: patch0.xml FHSETD DONE: Ok (Boot Disk: 0) Write Flash Done in: 08:19.294 |
