02-12-2016, 14:13 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | MSL Auth Failed, Use [Patch MSL] to Have Access Product not Authenticated IMEI: 000000-00-000000-0 IMEI: Certificate Corrupted SKID: 0346 MSLA: 0000000000 MSL Auth Failed, Use [Patch MSL] to Have Access Product not Authenticated SM-G920W8 at RJ45 (UART) [MODEM] IMEI: 000000-00-000000-0 IMEI: Certificate Corrupted SKID: 0346 MSLA: 0000000000 New S/N: RF8G41XMAW SM-G920W8 at USB [ADB] List of devices attached 04157df43c4a2409 device product:zerofltebmc model:SM_G920W8 device:zerofltebmc RILSN: 00000000000 RILSW: G920W8VLU3BOK1 PRNAM: zerofltebmc ANDRV: 5.1.1 ANDRB: LMY47X.G920W8VLU3BOK1 BOSER: 04157df43c4a2409 MODEL: SM-G920W8 Superuser Permissions Granted Transfered: 4015 KB/s (1048576 bytes in 0.255s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G920W8\NV Saved as: SM-G920W8_00000000000_nv_data_04157df43c4a2409_0001.b in Transfered: 3313 KB/s (1048576 bytes in 0.309s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G920W8\NV Saved as: SM-G920W8_00000000000_nv_data_04157df43c4a2409_0001.b ak remote object '/data/local/tmp/.nv_core.bak' does not exist * server not running * SM-G920W8 at USB [ADB] List of devices attached 04157df43c4a2409 device product:zerofltebmc model:SM_G920W8 device:zerofltebmc RILSN: 00000000000 RILSW: G920W8VLU3BOK1 PRNAM: zerofltebmc ANDRV: 5.1.1 ANDRB: LMY47X.G920W8VLU3BOK1 BOSER: 04157df43c4a2409 MODEL: SM-G920W8 Superuser Permissions Granted Transfered: 3140 KB/s (1048576 bytes in 0.326s) Transfered: 6 KB/s (32 bytes in 0.005s) Superuser Permissions Granted SM-G920W8 at USB [ADB] ADB Reboot Done Patch Done, to Finish Make [Gen.Settings]or[Mobile Info] when Product Fully Booted |
02-12-2016, 19:57 | #3 (permalink) | |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,801 | Quote:
plez explain so i can help u best regards | |
02-13-2016, 06:24 | #4 (permalink) | |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | Quote:
Hello your Imei and Certificate Is Corruppted you have to write CERT File To get Network Work To write Cert To as Follows
Regards Rehan Shaikh | |
02-13-2016, 06:36 | #5 (permalink) |
Member: 2207555 Status: Offline Thanks Meter: 1,622 | Here Is Cert File SM-G920F CERT File Note:you can Write Same Key Cert File,G920F Ic Compatible With G920w8 bcoz KEy ID is Same KEY ID IS:0346 Regards Rehan Shaikh Sharing is Caring |
The Following User Says Thank You to rehansk8879 For This Useful Post: |
07-28-2016, 22:18 | #6 (permalink) | |
No Life Poster Join Date: Jun 2014 Location: Bolivia
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | :) Quote:
and I want to know how I can know the S/N cell but no label. you can do to Patch MSL. you can put some code or command ADB to know S/N. I hope your kind answer | |
07-29-2016, 12:04 | #7 (permalink) | |
if no label on back sticker then, Select Model Connect Mobile(UART) Click Mobile Info there will be shown SERN:XXXXXXXXXXX Regards _______ Rehan | |
