10-19-2018, 15:54 | #1 (permalink) |
Freak Poster Join Date: Mar 2003 Age: 48
Member: 24115 Status: Offline Thanks Meter: 46 | Network lock - Samsung SM-925F? Factory info - Code: Samsung SM-G925F (S6 Edge) at USB (COM15) [MODEM] {Factory Info} MODEMCON: OK PRODCODE: SM-G925FZDAFTM HW VERS : MP 0.700 SERIALNR: R58GA1XM5RP MSL ADDR: R58GA1XM5R IMEI 1 : 353621-07-562763-4 CERT 1 : 0346, 0000, OK Use [Reset MSL] to Bypass MSL Security CAL DATE: 2015-10-21 LOCKSTAT: 20801_34001_64700 Code: Samsung SM-G925F (S6 Edge) at USB (COM15) [MODEM] {Unlock} MODEMCON: OK SERIALNR: R58GA1XM5RP Unlock Failed: -2 Try to Downgrade Modem, if is Possible or Use from COMBINATION Code: Samsung SM-G925F (S6 Edge) at USB (COM15) [MODEM] {Reset MSL} MODEMCON: OK SERIALNR: R58GA1XM5RP MSL Update Failed: -2 Try to Downgrade Modem, if is Possible or Use from COMBINATION |
10-19-2018, 17:53 | #2 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1596913 Status: Offline Thanks Meter: 107 | Here's a link to combination file U6: https://drive.google.com/uc?export=d...azYsoRwDP79eMo try, go for it. |
10-19-2018, 23:43 | #3 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | flash modem frm combination and start procedure again if fails download full combination and flash it do procdure again sometimes some models require rj45 if u dont have it just untick rj45 Sent from my F8332 using Tapatalk |
10-20-2018, 10:21 | #4 (permalink) | |
Member: 24115 Status: Offline Thanks Meter: 46 | Quote:
What is the name of file? Or another location for downloading? | |
10-20-2018, 14:56 | #5 (permalink) |
Insane Poster Join Date: Oct 2012 Location: morroco
Member: 1820874 Status: Offline Thanks Meter: 20 | flash this modem only in cp SM-G925F ENG Modem PakFirmware.com ps you need root |
10-21-2018, 11:05 | #6 (permalink) |
Member: 24115 Status: Offline Thanks Meter: 46 | Flash with combination from link but no success - Code: Samsung SM-G925F (S6 Edge) at USB (COM4) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-G925F_Read.pit No Partition Info for Image: zerolte_eur_open.pit, in COMBINATION_OXA_FA50_G925FXXU6ARC1_BOXWares.tar.md5 Warning, Pit Image: zerolte_eur_open.pit Skipped, Use [Re-Part.] Option with Pit Image File: COMBINATION_OXA_FA50_G925FXXU6ARC1_BOXWares.tar.md5 Partition: BOOTLOADER, Image: sboot.bin, Size: 0x0018F110 (1,56 MB) Partition: PARAM, Image: param.bin, Size: 0x00124800 (1,14 MB) Partition: CM, Image: cm.bin, Size: 0x00204110 (2,02 MB) Partition: BOOT, Image: boot.img, Size: 0x0185E120 (24,37 MB) Partition: RECOVERY, Image: recovery.img, Size: 0x01872920 (24,45 MB) Partition: SYSTEM, Image: system.img, Size: 0x3031E090 (771,12 MB) Partition: PERSDATA, Image: persdata.img, Size: 0x004180A0 (4,09 MB) Partition: RADIO, Image: modem.bin, Size: 0x0273D910 (39,24 MB) Partition: CACHE, Image: cache.img, Size: 0x0059C110 (5,61 MB) Flash Write Done: 00:56.525 Restart Done None of Modem Ports Selected Samsung SM-G925F (S6 Edge) at USB (COM15) [MODEM] {Unlock} MODEMCON: OK SERIALNR: R58GA1XM5RP Unlock Failed: -2 Try to Downgrade Modem, if is Possible or Use from COMBINATION Samsung SM-G925F (S6 Edge) at USB (COM15) [MODEM] {Fact.Unlock} MODEMCON: OK SERIALNR: R58GA1XM5RP MSL ADDR: R58GA1XM5R Use [Reset MSL] to Bypass MSL Security Product not Authenticated Samsung SM-G925F (S6 Edge) at USB (COM15) [MODEM] {Reset MSL} MODEMCON: OK SERIALNR: R58GA1XM5RP MSL Update Failed: -2 Try to Downgrade Modem, if is Possible or Use from COMBINATION Samsung SM-G925F (S6 Edge) at USB (COM15) [MODEM] {Factory Info} MODEMCON: OK PRODCODE: SM-G925FZDAFTM HW VERS : MP 0.700 SERIALNR: R58GA1XM5RP MSL ADDR: R58GA1XM5R IMEI 1 : 353621-07-562763-4 CERT 1 : 0346, 0000, OK Use [Reset MSL] to Bypass MSL Security CAL DATE: 2015-10-21 LOCKSTAT: 20801_34001_64700 |
