07-31-2013, 15:36 | #1 (permalink) |
No Life Poster Join Date: Jul 1999 Location: Netherlands Age: 57
Member: 334 Status: Offline Thanks Meter: 120 | New UFST box not authorised When i push "check box" button i get, HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: 2 Your IP: XX.XX.XX.XXX Support: Authentication Failure Something Wrong, Try to Use [Update Box] I get this info when i update my box, HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: 2 Must i contact my reseller? |
07-31-2013, 15:51 | #2 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | wait and try Again.. Its only server problem......... Server Busy with No UFST Updaters... Try with this procedure.. 1. [Check Box] 2. [Update Box] 3. [Check Box] 4. [Check Server] 5. [Install] Last edited by .::EXTREME::.; 07-31-2013 at 15:57. |
The Following User Says Thank You to .::EXTREME::. For This Useful Post: |
07-31-2013, 16:21 | #3 (permalink) | |
Product Supporter Join Date: Sep 2001 Location: India
Member: 6109 Status: Offline Sonork: 100.37432 Thanks Meter: 3,781 | Quote:
07-31-2013, 19:57 | #4 (permalink) |
Insane Poster Join Date: Sep 2011
Member: 1662358 Status: Offline Thanks Meter: 32 | click in Update box for more 3... clear all soft sarasoft, and reinstall only hwk support suite setup...open ufs panel...step procedure: "hardware" scan boxes check box update box check box replay step up (can error) "software" check server install ....... work 100% MyrwoK |
The Following User Says Thank You to myrwok For This Useful Post: |
08-02-2013, 06:16 | #8 (permalink) |
Product Supporter Join Date: Mar 2008 Location: Thailand Age: 46
Member: 716581 Status: Offline Thanks Meter: 767 | HWK: NOT AUTHORISED, Update Box Bad IX: 0001 Failed: 102 BOOT: TM UFST Boot v1.2 (c)SarasSoft 2012 Firmware: Ok Your IP: xxx.xx.x.xx Support: Account Ok REST: Ok UFSx: UFST, USB S/N: NVML: OK BOOT: UFST Boot v1.2 (c)SarasSoft 2012 CORE: UFST Core v1.2 (c)SarasSoft 2012 SERN: LIC5: True BOXK: 1 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.2 (c)SarasSoft 2012, Sn: HID: , HWK: A1.04-PRO1 SID: XID: LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 0001 Failed: 102 Authentication stage error: Server reported error: No more upgrade logs. Last edited by mobileclinic; 08-02-2013 at 07:50. Reason: Please don't post s.no. in forum |
08-02-2013, 06:54 | #9 (permalink) |
Product Supporter Join Date: May 2001
Member: 4566 Status: Offline Sonork: 100.112355 Thanks Meter: 503 | @nongmobile, You have updated the box and consumed the update logs for a day, if you want to update, try again after 8-24hrs. If you have updated already on that PC, you can directly go to software tab- Click Check Server and then click Install. It is important to click -Install- as this will do the authorization. |
The Following User Says Thank You to ren77 For This Useful Post: |
08-02-2013, 10:35 | #10 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Poland Age: 47
Member: 42387 Status: Offline Sonork: 1573735 Thanks Meter: 407 | IF someone use PCI usb 3.0 card (as I) and finally registered, updated, etc UFST, and got periodically not authorised errors, this mean hang 3.0 USB hub. Restart PC will help. |
08-10-2013, 08:03 | #11 (permalink) |
Junior Member Join Date: Jun 2013 Location: milan,italy
Member: 1968051 Status: Offline Thanks Meter: 1 | I received my new UFST box but when i use the control panel software i get ""not authorised update box" same problem .. App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft Box: 1 Location: 818 Serial: ********** UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.2 (c)SarasSoft 2012, Sn: ********* HID: XXXXXXXXXXXXXX, HWK: A1.04-PRO1 SID: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XID: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: AB11 Failed: 102 Your IP: ************* Support: Account Ok Something Wrong, Try to Use [Update Box Last edited by mobileclinic; 08-10-2013 at 08:10. Reason: Please don't post hid & other sn. |
The Following User Says Thank You to albert1970 For This Useful Post: |
08-10-2013, 08:12 | #12 (permalink) | |
http://forum.gsmhosting.com/vbb/f863...-ufst-1694714/ | |
The Following 2 Users Say Thank You to mobileclinic For This Useful Post: |
08-10-2013, 11:42 | #15 (permalink) |
Freak Poster Join Date: Nov 2004 Location: UK லண்ட
Member: 89837 Status: Offline Sonork: 100.1594891 Thanks Meter: 18 | UFS_PANEL_2301.zip work setup this link 100% |
The Following 3 Users Say Thank You to tamil For This Useful Post: |
