10-03-2017, 12:44 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | NOKIA TA-1032 SHOQ FLahing error Nokia TA-1032 (Nokia 3 LTE DS) at USB Auto Select [MTK] {Write Flash} Scatter : MT6737M_Android_scatter.txt MTK Flash Port not Found: Vid_0e8d&Pid_2000 Vid_0e8d&Pid_0003 Nokia TA-1032 (Nokia 3 LTE DS) at USB Auto Select [MTK] {Write Flash} Scatter : MT6737M_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM25 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Secured: 5 [SBC DAA] DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Flashing Canceled DA_SHUTDOWN Error: -2 Last USB Exception: 0x03E3 The I/O operation has been aborted because of either a thread exit or an application request. Can be Cable Problem or Battery Low ! Nokia TA-1032 (Nokia 3 LTE DS) at USB [FASTBOOT] {Read FB Info} FastBoot Port not Found: -1 Nokia TA-1032 (Nokia 3 LTE DS) at USB Auto Select [MTK] {Write Flash} Bad Scatter File: Nokia TA-1032 (Nokia 3 LTE DS) at USB Auto Select [MTK] {Write Flash} Scatter : MT6737M_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM25 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Secured: 5 [SBC DAA] DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Flashing Canceled DA_SHUTDOWN Error: -2 Last USB Exception: 0x03E3 The I/O operation has been aborted because of either a thread exit or an application request. Can be Cable Problem or Battery Low ! Samsung SM-J500F (J5 LTE) at USB (COM39) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-J500F_Read.pit File: J500FXXU1APD6_J500FODD1APD6_J500FDDU1APE1_HOME.tar .md5 Partition: ABOOT, Image: aboot.mbn, Size: 0x001295F0 (1.16 MB) Partition: SBL1, Image: sbl1.mbn, Size: 0x00045444 (277.07 KB) Partition: RPM, Image: rpm.mbn, Size: 0x0002DDBC (183.43 KB) Partition: QSEE, Image: tz.mbn, Size: 0x0007F18C (508.39 KB) Partition: QHEE, Image: hyp.mbn, Size: 0x00016100 (88.25 KB) Partition: APNHLOS, Image: non-hlos.bin, Size: 0x00DCC700 (13.8 MB) Partition: sec, Image: sec.dat, Size: 0x000002AC (684 Bytes) Partition: BOOT, Image: boot.img, Size: 0x00A6D910 (10.43 MB) Partition: RECOVERY, Image: recovery.img, Size: 0x00B87910 (11.53 MB) Partition: SYSTEM, Image: system.img.ext4, Size: 0x7402ABD8 (1.81 GB) Partition: MODEM, Image: modem.bin, Size: 0x02C9C700 (44.61 MB) Partition: CACHE, Image: cache.img.ext4, Size: 0x032650DC (50.39 MB) Partition: HIDDEN, Image: hidden.img.ext4, Size: 0x007DF0B8 (7.87 MB) Flash Write Done: 04:53.194 Restart Done Nokia TA-1032 (Nokia 3 LTE DS) at USB Auto Select [MTK] {Write Flash} Scatter : NE1-0-1480-MT6737M_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM25 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Secured: 5 [SBC DAA] DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Flashing Canceled DA_SHUTDOWN Error: -2 Last USB Exception: 0x03E3 The I/O operation has been aborted because of either a thread exit or an application request. Can be Cable Problem or Battery Low ! BATTERY IS CHARGED AND USB IS OK. |
