09-19-2019, 17:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Life Of Paradise
Member: 140477 Status: Offline Sonork: 100.1658502 Thanks Meter: 426 | Oppo A83 (CPH1827)OFP File Extract & Flash & Password & FRP Lock Removed Done BY UFST Oppo A83 (CPH1827) OFP File Extract & Flash & Password Lock Removed Done BY Android UFST ( Its Beta Test So Dont Ask EXE We Announce Official Release After TEST ) . . . . OFP File Extract Code: Image File: CPH1827_11_A.24_190213_a82c3dab_EXP.ofp Image Size: 5.380.575.188 Image Type: Oppo Flash Pack Proj. Name: 180405 DAA_AUTH_FILE Saved as: auth_sv5.auth EFUSE_CONFIG Saved as: 17031-efuse_oppo6763.xml EFUSE_INI Saved as: Efuse.ini Projectconfig.xml Saved as: Projectconfig.xml all-in-one-signature.bin Saved as: all-in-one-signature.bin boot Saved as: boot.img cache Saved as: cache.img lk Saved as: lk.bin lk2 Saved as: lk.bin logo Saved as: logo.bin md1dsp Saved as: md1dsp.img md1img Saved as: md1rom.img oppo_custom_17307 Saved as: oppo_custom_17307.img oppo_custom_17309 Saved as: oppo_custom_17309.img oppo_custom_17310 Saved as: oppo_custom_17310.img oppo_custom_17381 Saved as: oppo_custom_17381.img preloader Saved as: preloader_oppo6763_17101.bin recovery Saved as: recovery.img scatter Saved as: MT6763_Android_scatter.txt spmfw Saved as: spmfw.bin sspm_1 Saved as: tinysys-sspm.bin sspm_2 Saved as: tinysys-sspm.bin system Saved as: system.img system.sig Saved as: system.sig system_internal.sig Saved as: system_internal.sig tee1 Saved as: trustzone.bin tee2 Saved as: trustzone.bin userdata Saved as: userdata.img userdata.sig Saved as: userdata.sig userdata_internal.sig Saved as: userdata_internal.sig Partitions Configuration Saved as: PartitionNames.cfg Extracted and Saved: 30 Files Path: G:\CPH1827_11_A.24_190213_a82c3dab_EXP\CPH1827_11_A.24_190213_a82c3dab_EXP\CPH1827_11_A.24_190213_a82c3dab_EXP_EX\ Code: Var OPPO-A83 (A83 LTE DS CPH1729/1827) at USB Auto Select [MTK] {Write Flash} Scatter : MT6763_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_0003 (BROM) DA Agent : DA_OPPO_F5_1.bin BR ComPort: COM67 BR Asic Id: MT0690 [0000] Alias: MT6763 BR Asic Sw: 8A00 CA01 0001 0000 BR ME_ID : 4C66BFC66C304C96B471D264D53A6E8D BR Secured: E5 [SBC DAA] DA AgentId: SAA91A0C4C83687559 DA Version: MTK_AllInOne_DA_v3.3001.2017/09/22.09:22. Auth File : Oppo_F6_auth_sv5.auth Auth FiId : SABE4D915BCF9C36BF DA ProtVer: 4 PR DlagVer: 1.0 PR BootMod: brom EMI PreLdr: preloader_oppo6763_17101.bin EMI TagVer: 30 EMI Config: Ok DA Asic Id: MT0690 [8A00 CA01 0001 0000 0000] eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14.56 GB eMMC CID : 150100514536334D420637A1064B750F [QE63MB] ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB IRAM Size : 0x0000000000040000 [262.144] 256 KB UNICAL RID: B94B5AE79E90F752995AB831A98ACA85 DA USBconf: high-speed PGPT Found: 43 Partition Entries SGPT Found: 43 Partition Entries Partitions to Flash: 1 (9.26 GB) SET_ALL_SIGN Error: -4 all-in-one-signature.bin C0010004 Set External Signature: userdata.sig Write userdata 1 GB, Done in: 00:33.587 (Sparsed) Write Done in : 00:35.096 DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to Tajammul For This Useful Post: |
09-19-2019, 17:22 | #2 (permalink) |
Member: 140477 Status: Offline Sonork: 100.1658502 Thanks Meter: 426 | Oppo A83 (CPH1827) FRP Lock Removed Done BY Android UFST Oppo A83 (CPH1827) FRP Lock Removed Done BY Android UFST ( Its Beta Test So Dont Ask EXE We Announce Official Release After TEST ) . . Code: Var OPPO-A83 (A83 LTE DS CPH1729/1827) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_0003 (BROM) DA Agent : DA_OPPO_F5_1.bin BR ComPort: COM67 BR Asic Id: MT0690 [0000] Alias: MT6763 BR Asic Sw: 8A00 CA01 0001 0000 BR ME_ID : 4C66BFC66C304C96B471D264D53A6E8D BR Secured: E5 [SBC DAA] DA AgentId: SAA91A0C4C83687559 DA Version: MTK_AllInOne_DA_v3.3001.2017/09/22.09:22. Auth File : Oppo_F6_auth_sv5.auth Auth FiId : SABE4D915BCF9C36BF DA ProtVer: 4 PR DlagVer: 1.0 PR BootMod: brom EMI PreLdr: preloader_oppo6763_17101.bin EMI TagVer: 30 EMI Config: Ok DA Asic Id: MT0690 [8A00 CA01 0001 0000 0000] eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14.56 GB eMMC CID : 150100514536334D420637A1064B750F [QE63MB] ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB IRAM Size : 0x0000000000040000 [262.144] 256 KB UNICAL RID: B94B5AE79E90F752995AB831A98ACA85 DA USBconf: high-speed PGPT Found: 43 Partition Entries SGPT Found: 43 Partition Entries Reset FRP Done in: 00:06.917 (2) DA Shutdown Done, Disconnect Cable Last edited by Sha; 09-20-2019 at 05:39. |
09-20-2019, 11:31 | #8 (permalink) | ||
Product Supporter Join Date: Mar 2008 Location: Thailand Age: 46
Member: 716581 Status: Offline Thanks Meter: 767 | Quote:
