12-13-2014, 20:19 | #1 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2197558 Status: Offline Thanks Meter: 11 | problem with samsung sm g 800f Software: G800FXXU1ANJ2/G800FCRO1ANH2/G800FXXU1ANJ2/G800FXXU1ANJ2 ProdCode: SM2G800FZKACRO IMEI: 356099-06-788335-7 IMEI: Certificate OK MSLA: R58FA0PCKX CALD: 2014-10-19 HWVE: MP 0.800 SERN: R58FA0PCKXT PREC: CRO [T-Mobile - Croatia] PROV: 21901 MSL Auth Failed, Use [Patch MSL] to Have Access And after unlock Software: G800FXXU1ANJ2/G800FCRO1ANH2/G800FXXU1ANJ2/G800FXXU1ANJ2 ProdCode: IMEI: 000000-00-000000-0 IMEI: Certificate Corrupted MSLA: 0000000000 CALD: Y|- HWVE: SERN: R58FA0PCKXT How to fix imei and certificate Thx!! |
12-16-2014, 06:00 | #6 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hate stupidity
Member: 904530 Status: Offline Thanks Meter: 517 | you did all ok, need read e2p to save original certificate to /nv folder use gen.settings button to write back certificate and init locks to 00000000 |
The Following User Says Thank You to Major-T For This Useful Post: |
12-16-2014, 11:22 | #8 (permalink) |
Member: 2197558 Status: Offline Thanks Meter: 11 | DONE!!!!!! UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 12825310 HID: B794D5C942600004, HWK: A1.04-PRO1 SID: 55F3B6525C8F5BD90F5C6F925F4F2850CACEF2F3 XID: 98B7DA68067A64AABB510DF6AF49E34BE12DFBFB Licence: True AppVers: SAMSUNG TOOLS (HWK) v 2.3.0.5 by SarasSoft Build 52 LogFile: .\_!_LOG\12825310_2014_12_16_10_46_25_LOG.txt Loaded Settings from: Sams.ini Bad COM Port: Select Modem Port COM18: SAMSUNG Mobile USB Modem #5 Software: G800FXXU1ANJ2/G800FCRO1ANH2/G800FXXU1ANJ2/G800FXXU1ANJ2 ProdCode: IMEI: 000000-00-000000-0 IMEI: Certificate Corrupted MSLA: 0000000000 CALD: Y|- HWVE: SERN: R58FA0PCKXT PREC: CRO [T-Mobile - Croatia] PROV: NONE MCK : 12345678 NCK : 00000000 NSCK: 00000000 SPCK: 00000000 CPCK: 00000000 SIM : 00000000 NVM File: SM-G800F_R58FA0PCKXT_nv_data_0000.bin * server not running * List of devices attached S/N : R58FA0PCKXT R_SW: G800FXXU1ANJ2 ANDR: 4.4.2 ANDR: KOT49H.G800FXXU1ANJ2 Superuser Permissions Granted Transfered: 2255 KB/s (2097152 bytes in 0.908s) Transfered: 0 KB/s (32 bytes in 1.000s) Superuser Permissions Granted NVM Write Done, Reboot Device to See Changes Done, Wait Device Restarting Bad COM Port: Select Modem Port COM18: SAMSUNG Mobile USB Modem #5 Software: G800FXXU1ANJ2/G800FCRO1ANH2/G800FXXU1ANJ2/G800FXXU1ANJ2 ProdCode: SM2G800FZKACRO IMEI: 356099-06-788335-7 IMEI: Certificate OK MSLA: R58FA0PCKX CALD: 2014-10-19 HWVE: MP 0.800 SERN: R58FA0PCKXT PREC: CRO [T-Mobile - Croatia] PROV: 21901 MSL Auth Failed, Use [Patch MSL] to Have Access * server not running * List of devices attached 32045753e5ff8191 device S/N : R58FA0PCKXT R_SW: G800FXXU1ANJ2 ANDR: 4.4.2 ANDR: KOT49H.G800FXXU1ANJ2 Superuser Permissions Granted Transfered: 1984 KB/s (2097152 bytes in 1.032s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G800F\NV Saved as: SM-G800F_R58FA0PCKXT_nv_data_0000.bin Transfered: 2296 KB/s (2097152 bytes in 0.891s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G800F\NV Saved as: SM-G800F_R58FA0PCKXT_nv_data_0000.bak Transfered: 2048 KB/s (327680 bytes in 0.156s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G800F\NV Saved as: SM-G800F_R58FA0PCKXT_nv_core_0000.bak Certificate Saved as: SM-G800F_35609906788335_R58FA0PCKXT_0573.cert IMEI: 356099-06-788335-7 IMEI: Certificate OK MSLA: R58FA0PCKX * server not running * List of devices attached 32045753e5ff8191 device S/N : R58FA0PCKXT R_SW: G800FXXU1ANJ2 ANDR: 4.4.2 ANDR: KOT49H.G800FXXU1ANJ2 Superuser Permissions Granted Transfered: 1781 KB/s (2097152 bytes in 1.149s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G800F\NV Saved as: SM-G800F_R58FA0PCKXT_nv_data_0001.bin Transfered: 2014 KB/s (2097152 bytes in 1.016s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G800F\NV Saved as: SM-G800F_R58FA0PCKXT_nv_data_0001.bak Transfered: 1706 KB/s (327680 bytes in 0.187s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G800F\NV Saved as: SM-G800F_R58FA0PCKXT_nv_core_0001.bak Certificate Saved as: SM-G800F_35609906788335_R58FA0PCKXT_0573.cert * server not running * List of devices attached 32045753e5ff8191 device S/N : R58FA0PCKXT R_SW: G800FXXU1ANJ2 ANDR: 4.4.2 ANDR: KOT49H.G800FXXU1ANJ2 Superuser Permissions Granted Transfered: 1927 KB/s (2097152 bytes in 1.062s) Transfered: 0 KB/s (32 bytes in 1.000s) Superuser Permissions Granted ADB Reboot Done Patch Done, to Finish Make [Gen.Settings]or[Mobile Info] when Product Fully Booted COM18: SAMSUNG Mobile USB Modem #5 Software: G800FXXU1ANJ2/G800FCRO1ANH2/G800FXXU1ANJ2/G800FXXU1ANJ2 ProdCode: IMEI: 000000-00-000000-0 IMEI: Certificate Corrupted MSLA: 0000000000 CALD: Y|- HWVE: SERN: R58FA0PCKXT PREC: CRO [T-Mobile - Croatia] PROV: NONE MCK : < CRYPTED > NCK : < UNSET > NSCK: < UNSET > SPCK: < UNSET > CPCK: < UNSET > SIM : < UNSET > Port not Respond Port not Respond COM18: SAMSUNG Mobile USB Modem #5 ProdCode: IMEI: 000000-00-000000-0 IMEI: Certificate Corrupted MSLA: 0000000000 CALD: Y|- HWVE: PREC: CRO [T-Mobile - Croatia] PROV: NONE MSL Auth Failed Software: G800FXXU1ANJ2/G800FCRO1ANH2/G800FXXU1ANJ2/G800FXXU1ANJ2 ProdCode: SM2G800FZKACRO IMEI: 000000-00-000000-0 IMEI: Certificate Corrupted MSLA: 0000000000 CALD: 2014-10-19 HWVE: MP 0.800 SERN: R58FA0PCKXT PREC: CRO [T-Mobile - Croatia] PROV: NONE MSL Auth Failed, Use [Patch MSL] to Have Access IMEI: 000000-00-000000-0 IMEI: Certificate Corrupted MSLA: 0000000000 New S/N: R58FA0PCKX * server not running * List of devices attached 32045753e5ff8191 device S/N : R58FA0PCKXT R_SW: G800FXXU1ANJ2 ANDR: 4.4.2 ANDR: KOT49H.G800FXXU1ANJ2 Superuser Permissions Granted Transfered: 1793 KB/s (2097152 bytes in 1.141s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G800F\NV Saved as: SM-G800F_R58FA0PCKXT_nv_data_0002.bin Transfered: 1984 KB/s (2097152 bytes in 1.032s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G800F\NV Saved as: SM-G800F_R58FA0PCKXT_nv_data_0002.bak Transfered: 1567 KB/s (327680 bytes in 0.204s) Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\SM-G800F\NV Saved as: SM-G800F_R58FA0PCKXT_nv_core_0002.bak Invalid Certificate: Invalid CERTIFICATE * server not running * List of devices attached 32045753e5ff8191 device S/N : R58FA0PCKXT R_SW: G800FXXU1ANJ2 ANDR: 4.4.2 ANDR: KOT49H.G800FXXU1ANJ2 Superuser Permissions Granted Transfered: 2146 KB/s (2097152 bytes in 0.954s) Transfered: 0 KB/s (32 bytes in 1.000s) Superuser Permissions Granted ADB Reboot Done Patch Done, to Finish Make [Gen.Settings]or[Mobile Info] when Product Fully Booted Bad COM Port: Select Modem Port COM18: SAMSUNG Mobile USB Modem #5 Software: G800FXXU1ANJ2/G800FCRO1ANH2/G800FXXU1ANJ2/G800FXXU1ANJ2 IMEI: 000000-00-000000-0 IMEI: Certificate Corrupted MSLA: 0000000000 CALD: Y|- HWVE: SERN: R58FA0PCKXT PREC: CRO [T-Mobile - Croatia] PROV: NONE S/N Rebuid Done, Reboot Device to See Changes MSLA: R58FA0PCKX MCK : < CRYPTED > NCK : < UNSET > NSCK: < UNSET > SPCK: < UNSET > CPCK: < UNSET > SIM : < UNSET > ProdCode: IMEI: 000000-00-000000-0 IMEI: Certificate Corrupted MSLA: R58FA0PCKX BTID: C44202-6BF1A6 WiFi: C44202-6BF1A7 CALD: Y|- HWVE: SERN: R58FA0PCKXT PREC: CRO [T-Mobile - Croatia] PROV: NONE MCK : < CRYPTED > NCK : < UNSET > NSCK: < UNSET > SPCK: < UNSET > CPCK: < UNSET > SIM : < UNSET > Software: G800FXXU1ANJ2/G800FCRO1ANH2/G800FXXU1ANJ2/G800FXXU1ANJ2 ProdCode: IMEI: 356099-06-788335-7 IMEI: Certificate OK MSLA: R58FA0PCKX CALD: Y|- HWVE: SERN: R58FA0PCKXT PREC: CRO [T-Mobile - Croatia] PROV: NONE MCK : 12345678 NCK : 00000000 NSCK: 00000000 SPCK: 00000000 CPCK: 00000000 SIM : 00000000 |
