10-31-2017, 13:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | redmi 3s prime flash sucessfully Var XIAOMI-Redmi 3s Prime Land (Redmi 3s Prime LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} Qualcomm HS-USB QDLoader 9008 Port not Found: Vid_05c6&Pid_9008 Flash Bundle: rawprogram0.xml Bad Port: SAHARA Connect Fail: -1 Var XIAOMI-Redmi 3s Prime Land (Redmi 3s Prime LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM108) Flash Bundle: rawprogram0.xml SAHARA VERS: 2.1 SAHARA PROG: prog_emmc_firehose_8937_ddr_xiaomi.mbn FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8937 FHPROG MEMT: eMMC FHINFO PAR0: 61071360 x 512 Sectors (29.12 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 Partitions to Write: 32 (3.61 GB) FWRITE DONE: ST 0x0000020000 modem 84 MB FWRITE DONE: ST 0x0000060012 sbl1 332.39 KB FWRITE DONE: ST 0x0000060412 sbl1bak 332.39 KB FWRITE DONE: ST 0x0000060812 rpm 165.6 KB FWRITE DONE: ST 0x0000060C12 rpmbak 165.6 KB FWRITE DONE: ST 0x0000061012 tz 1.29 MB FWRITE DONE: ST 0x0000062012 tzbak 1.29 MB FWRITE DONE: ST 0x0000063012 devcfg 51.62 KB FWRITE DONE: ST 0x0000063212 devcfgbak 51.62 KB FWRITE DONE: ST 0x0000063412 dsp 16 MB FWRITE DONE: ST 0x00000A0000 splash 5.27 MB FWRITE DONE: ST 0x00000C0000 aboot 567.32 KB FWRITE DONE: ST 0x00000C0800 abootbak 567.32 KB FWRITE DONE: ST 0x00000C1000 boot 20.19 MB FWRITE DONE: ST 0x00000E1000 recovery 21.27 MB FWRITE DONE: ST 0x0000101800 system 3 GB (Unsparsed Size) FWRITE DONE: ST 0x0000720000 cache 256 MB (Unsparsed Size) FWRITE DONE: ST 0x00007A0000 persist 32 MB (Unsparsed Size) FWRITE DONE: ST 0x00007B0C00 config 20 KB FWRITE DONE: ST 0x0000800C00 mdtp 1000 KB FWRITE DONE: ST 0x0000820000 lksecapp 56.01 KB FWRITE DONE: ST 0x0000820100 lksecappbak 56.01 KB FWRITE DONE: ST 0x0000820200 cmnlib 192.56 KB FWRITE DONE: ST 0x0000820400 cmnlibbak 192.56 KB FWRITE DONE: ST 0x0000820600 cmnlib64 241.94 KB FWRITE DONE: ST 0x0000820800 cmnlib64bak 241.94 KB FWRITE DONE: ST 0x0000820A00 keymaster 220.71 KB FWRITE DONE: ST 0x0000820C00 keymasterbak 220.71 KB FWRITE DONE: ST 0x0000840410 cust 512 MB (Unsparsed Size) FWRITE DONE: ST 0x0000940410 userdata 9.91 GB (Unsparsed Size) FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB FWRITE DONE: ST 0x0000000021 BackupGPT 16.5 KB FPATCH DONE: 13 FHSETD DONE: Ok FHREST DONE: Ok Write Flash Done in: 17:46.280 |
The Following User Says Thank You to galaxycompue For This Useful Post: |
