09-16-2016, 15:40 | #1 (permalink) |
Freak Poster Join Date: Apr 2010 Location: lucknow u.p.india Age: 35
Member: 1284209 Status: Offline Sonork: 100.1614938 Thanks Meter: 137 | redmi2 boot repair sucsess redmi mi2 wt88047 dead boot repair ok thanks saras team |
The Following 7 Users Say Thank You to shoaibansari. For This Useful Post: |
09-17-2016, 09:31 | #3 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | You need not only .xml, but whole flashing bundle, where rawprogram0.xml is an "Flash Helper" file. I hope mr.shoaibansari will share link with you. |
The Following 2 Users Say Thank You to Sha For This Useful Post: |
09-20-2016, 07:51 | #4 (permalink) |
Product Supporter Join Date: Jun 2016
Member: 2590844 Status: Offline Thanks Meter: 394 | You can download all Xiaomi fastboot flash with xml file inside from here Xiaomi MIUI Official Forum |
The Following 2 Users Say Thank You to UFST Box For This Useful Post: |
09-20-2016, 08:15 | #5 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | for Boot repair and Full flashing of QualComm models, from 9008 need Sahara (QFIL) files, not FastBoot. FastBoot is for upgrade Operational phone. for sure UFST also can Flash FasBoot .bat or .cmd files so in this forum missing: Method 4 which need for deadboot bricked, or damaged phones Last edited by Sha; 09-20-2016 at 08:20. |
The Following 3 Users Say Thank You to Sha For This Useful Post: |
09-24-2016, 23:54 | #8 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Qualcomm IMEI, BT, WIFI repair is already realised. Use [Gen.Settings] button: Edit Values and then [Write] Of Course DIAG must be enabled. Also have [Read ENVM], [Write ENVM] same functionality as QCN, only different file format. https://www.4shared.com/photo/o_tyfH...A460_IMEI.html Last edited by Sha; 09-25-2016 at 00:47. |
The Following User Says Thank You to Sha For This Useful Post: |
09-26-2016, 02:49 | #9 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | have asus (zenphone 2) phone but cant enable diag need help to change imei of this model can helpme to enable diag try some command but not work |
09-26-2016, 07:59 | #11 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | C:\adb>adb shell shell@Z00A:/ $ su root@Z00A:/ # insmod /system/lib/modules/diagchar.ko insmod: can't open '/system/lib/modules/diagchar.ko' 255|root@Z00A:/ # |
