10-29-2017, 09:43 | #1 (permalink) |
Freak Poster Join Date: Mar 2003 Age: 48
Member: 24115 Status: Offline Thanks Meter: 46 | Samsung A5 (SM-A510F) - FRP possible? Tnx. Code: Samsung SM-A510F (A5 (2016) LTE) at USB (COM29) [LOKE FLASH] {Reset FRP} PLATF: LOKE 00020000 PIT Read Done: 00:00 Reset FRP Done in: 00:00.439 Comm Error LOKE Close: Cannot Write: 0 |
The Following User Says Thank You to milenjs For This Useful Post: |
10-29-2017, 09:55 | #2 (permalink) | |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Quote:
Sent from my SM-A510F using Tapatalk | |
10-31-2017, 15:27 | #3 (permalink) |
Member: 24115 Status: Offline Thanks Meter: 46 | No success. First i flash only sboot and boot - Code: Samsung SM-A510F (A5 (2016) LTE) at USB (COM29) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-A510F_Read.pit No Partition Info for Image: a5xelte_eur_open.pit, in COMBINATION_FAC_FA51_A510FXXU4AQC1_FAC_CL9213193_QB12832200_REV00_user_mid_noship.tar.md5 Warning, Pit Image: a5xelte_eur_open.pit Skipped, Use [Re-Part.] Option with Pit Image File: COMBINATION_FAC_FA51_A510FXXU4AQC1_FAC_CL9213193_QB12832200_REV00_user_mid_noship.tar.md5 Partition: BOOTLOADER, Image: sboot.bin, Size: 0x0018B110 (1,54 MB) Partition: BOOT, Image: boot.img, Size: 0x00E28920 (14,16 MB) Flash Write Done: 00:00.964 Restart Done Samsung SM-A510F (A5 (2016) LTE) at USB [ADB] {Reset FRP} daemon started successfully * 33000fac8b6f63ab device Goto "Backup and reset" Menu and make "Factory data reset" Flash with all from combination, phone is alive, make "Backup and reset" Menu and make "Factory data reset", after that flash with normal firmware but phone again ask google account What is wrong? Code: Samsung SM-A510F (A5 (2016) LTE) at USB (COM29) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-A510F_Read.pit No Partition Info for Image: a5xelte_eur_open.pit, in COMBINATION_FAC_FA51_A510FXXU4AQC1_FAC_CL9213193_QB12832200_REV00_user_mid_noship.tar.md5 Warning, Pit Image: a5xelte_eur_open.pit Skipped, Use [Re-Part.] Option with Pit Image File: COMBINATION_FAC_FA51_A510FXXU4AQC1_FAC_CL9213193_QB12832200_REV00_user_mid_noship.tar.md5 Partition: BOOTLOADER, Image: sboot.bin, Size: 0x0018B110 (1,54 MB) Partition: PARAM, Image: param.bin, Size: 0x00154000 (1,33 MB) Partition: CM, Image: cm.bin, Size: 0x00204110 (2,02 MB) Partition: BOOT, Image: boot.img, Size: 0x00E28920 (14,16 MB) Partition: RECOVERY, Image: recovery.img, Size: 0x00F51920 (15,32 MB) Partition: SYSTEM, Image: system.img, Size: 0x3C576EC0 (965,46 MB) Partition: PERSDATA, Image: persdata.img, Size: 0x0041E0A0 (4,12 MB) Partition: RADIO, Image: modem.bin, Size: 0x020C17D0 (32,76 MB) Partition: CACHE, Image: cache.img, Size: 0x0059C110 (5,61 MB) Flash Write Done: 00:37.260 Restart Done Samsung SM-A510F (A5 (2016) LTE) at USB [ADB] {Reset FRP} daemon started successfully * Goto "Backup and reset" Menu and make "Factory data reset" |
10-31-2017, 18:49 | #4 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | do this flash this comb file COMBINATION_FAC_FA51_A510FXXU4AQC1_FAC_CL9213193_Q B12832200_REV00_user_mid_noship.tar.md5 switch phone enable usb debug and flash this stock only ap A510FXXU4BQC2_A510FOJV4BQC2_MID\A510FXXU4BQC2_A510 FOJV4BQC2_A510FXXU4BQC3_HOME.tar.md5 switch on phone adb will be on just authorize phone and do frp from box RESET FRP WITH ADB then phone will pass to app go setting enable OEM UNLOCK do reset |
The Following 3 Users Say Thank You to profkefah For This Useful Post: |
11-01-2017, 11:27 | #5 (permalink) |
Member: 24115 Status: Offline Thanks Meter: 46 | Million tnx friend, you help me again This method work like charm! Code: Samsung SM-A510F (A5 (2016) LTE) at USB (COM29) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-A510F_Read.pit No Partition Info for Image: a5xelte_eur_open.pit, in COMBINATION_FAC_FA51_A510FXXU4AQC1_FAC_CL9213193_QB12832200_REV00_user_mid_noship.tar.md5 Warning, Pit Image: a5xelte_eur_open.pit Skipped, Use [Re-Part.] Option with Pit Image File: COMBINATION_FAC_FA51_A510FXXU4AQC1_FAC_CL9213193_QB12832200_REV00_user_mid_noship.tar.md5 Partition: BOOTLOADER, Image: sboot.bin, Size: 0x0018B110 (1,54 MB) Partition: PARAM, Image: param.bin, Size: 0x00154000 (1,33 MB) Partition: CM, Image: cm.bin, Size: 0x00204110 (2,02 MB) Partition: BOOT, Image: boot.img, Size: 0x00E28920 (14,16 MB) Partition: RECOVERY, Image: recovery.img, Size: 0x00F51920 (15,32 MB) Partition: SYSTEM, Image: system.img, Size: 0x3C576EC0 (965,46 MB) Partition: PERSDATA, Image: persdata.img, Size: 0x0041E0A0 (4,12 MB) Partition: RADIO, Image: modem.bin, Size: 0x020C17D0 (32,76 MB) Partition: CACHE, Image: cache.img, Size: 0x0059C110 (5,61 MB) Flash Write Done: 00:49.266 Restart Done Samsung SM-A510F (A5 (2016) LTE) at USB (COM29) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-A510F_Read.pit No Files for Flashing Flash Write Done: 00:54.073 Restart Done Samsung SM-A510F (A5 (2016) LTE) at USB (COM29) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-A510F_Read.pit File: A510FXXU4CQE3_A510FOXY4CQE8_A510FXXU4CQE3_HOME.tar.md5 Partition: BOOTLOADER, Image: sboot.bin, Size: 0x0018B110 (1,54 MB) Partition: CM, Image: cm.bin, Size: 0x00204110 (2,02 MB) Partition: BOOT, Image: boot.img, Size: 0x012AF120 (18,68 MB) Partition: RECOVERY, Image: recovery.img, Size: 0x01586120 (21,52 MB) Partition: SYSTEM, Image: system.img, Size: 0xA8380F30 (2,63 GB) Partition: CACHE, Image: cache.img, Size: 0x043B7120 (67,72 MB) Partition: HIDDEN, Image: hidden.img, Size: 0x03516210 (53,09 MB) Partition: RADIO, Image: modem.bin, Size: 0x020F64F0 (32,96 MB) Flash Write Done: 02:01.664 Restart Done Samsung SM-A510F (A5 (2016) LTE) at USB [ADB] {Reset FRP} daemon started successfully * 33000fac8b6f63ab unauthorized Goto "Backup and reset" Menu and make "Factory data reset" |
