10-06-2018, 20:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,801 | SAMSUNG G570F custom binary blocked by frp lock got device stuck on custom binary blocked by frp lock with red color just download mode work flashed these firmware G570FXXU1BQJ1_G570FOJV1BQJ1_XSG 7 flash ok same issue G570FXXU1AQH6_OJV1AQH2_ 6.0.1 flash ok same issue G570FDDU1BQI6 7 flash error frp lock tried with pit file and without even tried nand erase same issue efs clear all done but same isssue phone SN R58J65ZPQJ MODEL G570 DS IN DOWNLOAD MODE B1 K0 S0 CURRENT BINARY CUSTOM SYSTEM STATUS CUSTOM TRIED COMB FILE ALSO SAME ISSUE |
10-06-2018, 22:15 | #2 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1596913 Status: Offline Thanks Meter: 107 | I had this once after flashing combination. Flash the latest version using latest Odin and only the BL and AP files. When the bootloader is restored will flash the full firmware. |
10-07-2018, 19:11 | #4 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,801 | i tried every thing i flashed 6.0.1 with pit stuck on logo flashed 7 reach recovery and install update at 2% then reboot flashed 8.0.0 install update erase but end with error here photo |
10-07-2018, 20:49 | #5 (permalink) |
Member: 1596913 Status: Offline Thanks Meter: 107 | First try to flash: https://drive.google.com/file/d/1R0g...zVQm9tf-w/view Then try to flash: https://drive.google.com/file/d/1pgu...AuFHoxD1J/view (If ufst allows to flash, press Selective Flash and do not check userdata.img and cashe.img) If ufst will swear on a custom bootloader that use Odin3 v3.13.1 (cut the files userdata.img and cashe.img using the program "TAR_MD5_PACKAGER". If this does not help, there may be a problem with the chip memory. |
The Following User Says Thank You to vaterpahk For This Useful Post: |
