10-29-2014, 04:13 | #17 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2279467 Status: Offline Thanks Meter: 1 | safe mode of ur handset is 100% touch problem . just change any working handset touch to ur handset u see safe mode remove , tested more than 12 handset already wbr or if ur handset is not from original samsung than problem will be else solution if yes pl post in correct solution |
10-29-2014, 05:10 | #18 (permalink) |
Junior Member Join Date: Jul 2010 Location: philippine
Member: 1339373 Status: Offline Sonork: dexter Thanks Meter: 1 | the final sulotion of your problem sir vickygsmforum volume down sticky.. diassimble your unit and replace the volume down switch will solved your problem post result after do that.. |
01-26-2016, 16:42 | #26 (permalink) |
No Life Poster Join Date: Mar 2009 Location: BD/HAIL KSA
Member: 1001269 Status: Offline Thanks Meter: 226 | its can be 3 reasons 1 software just remove Battery few second 2 volume keys shorted 3 touch digitaiger not good |
The Following User Says Thank You to mrnazam For This Useful Post: |
07-24-2016, 09:09 | #30 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Tiptur- Karnataka, india
Member: 1809212 Status: Offline Sonork: 1000.2 Thanks Meter: 79 | Saafe-med Problem Solutions 1- Try to Remove Battry And Replace It 2- Try to Rplace Toucg 3- hacnge Vol - These RR 100% Sol |
