Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 06-05-2019, 17:42   #1471 (permalink)
Member: 2185549
Thanks Meter: 535
xiaomi redmi-go(tiare flashing done)
QDL USB Com: Vid_05c6&Pid_9008 (COM21)
SAHARA VERS: 2.1
SAHARA HWID: 000560E100000000 [MSM8917]
SAHARA HASH: 57158EAF1814D78FD2B3105ECE4DB18A817A08AC664A5782A9 25F3FF8403D39A
SAHARA SERN: 3E969675 (1050056309)
SAHARA PROG: prog_emmc_firehose_8917_ddr.mbn
SAHARA PRID: QO4CB02593E080CF95
FHPROG SZFT: 4096
FHPROG SZTT: 131072
FHPROG SPTT: 1048576
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8917
FHPROG MEMT: eMMC
FHINFO DSK0: 15269888 x 512 Sectors (7.28 GB)
FHINFO DSK1: 8192 x 512 Sectors (4 MB)
FHINFO DSK2: 8192 x 512 Sectors (4 MB)
FHINFO MENM: FN62MB
FHINFO MESN: 6C17AA4E (1813490254)
FHPROG PART: EFI GPT
FHPROG PRTY: 0
Flash Bundle: rawprogram0.xml
Partitions to Write: 27 (1.5 GB)
FWRITE DONE: DSK0 ST 0x0000000028 sbl1 342.12 KB
FWRITE DONE: DSK0 ST 0x0000000428 rpm 180.38 KB
FWRITE DONE: DSK0 ST 0x0000000828 tz 1.47 MB
FWRITE DONE: DSK0 ST 0x0000001828 devcfg 60.68 KB
FWRITE DONE: DSK0 ST 0x0000001A28 sbl1bak 342.12 KB
FWRITE DONE: DSK0 ST 0x0000001E28 rpmbak 180.38 KB
FWRITE DONE: DSK0 ST 0x0000002228 tzbak 1.47 MB
FWRITE DONE: DSK0 ST 0x0000003228 devcfgbak 60.68 KB
FWRITE DONE: DSK0 ST 0x0000004000 cmnlib 208.84 KB
FWRITE DONE: DSK0 ST 0x0000004800 cmnlib64 262.78 KB
FWRITE DONE: DSK0 ST 0x0000005000 keymaster 265.12 KB
FWRITE DONE: DSK0 ST 0x0000005800 aboot 559.51 KB
FWRITE DONE: DSK0 ST 0x0000006000 cmnlibbak 208.84 KB
FWRITE DONE: DSK0 ST 0x0000006800 cmnlib64bak 262.78 KB
FWRITE DONE: DSK0 ST 0x0000007000 keymasterbak 265.12 KB
FWRITE DONE: DSK0 ST 0x0000007800 abootbak 559.51 KB
FWRITE DONE: DSK0 ST 0x0000020018 dsp 16 MB
FWRITE DONE: DSK0 ST 0x0000032018 splash 10.55 MB
FWRITE DONE: DSK0 ST 0x0000048000 modem 84 MB
FWRITE DONE: DSK0 ST 0x0000072000 boot 15.18 MB
FWRITE DONE: DSK0 ST 0x000008A000 recovery 19.73 MB
FWRITE DONE: DSK0 ST 0x0000096000 vendor 318 MB (Unsparsed Size)
FWRITE DONE: DSK0 ST 0x0000135000 system 1.29 GB (Unsparsed Size)
FWRITE DONE: DSK0 ST 0x00003CC000 cache 150 MB (Unsparsed Size)
The Following 2 Users Say Thank You to ferouz kassim For This Useful Post:
Old 06-05-2019, 18:19   #1472 (permalink)
Member: 2185549
Thanks Meter: 535
xiaomi redmi a2 lite (diasy)
Var XIAOMI-Mi A2 Lite Daisy (Mi A2 Lite LTE DS) at USB (COM69) [DIAGS] {Factory Info}
OFFLMODE: OK
MDMVERSN: May 14 201915:54:03Apr 10 201901:00:008953.gen
MDMBUILD: MPSS.TA.3.0.c1-00326-8953_GEN_PACK-1.184854.2.199731.1
NV IMEI1: 863896-04-327437-9
NV IMEI2: 351145-34-534647-0
NV BTID : 0000:00:000000
NV WIFI : 0000:00:000000
Var XIAOMI-Mi A2 Lite Daisy (Mi A2 Lite LTE DS) at USB (COM69) [DIAGS] {Read ENVM}
OFFLMODE: OK
Set SPC Password: 000000, OK
Get Names GN PROTECTED_NODE: /.efs_private
Get Names GN PROTECTED_NODE: /nvm
Get Names GN PROTECTED_NODE: /safe
EFS2 Read Found: 1556 File(s), 0 Link(s)
File Props Failed: -1
EFS2 Read Done : 1555 File(s), Time: 01:00.561
NVM_SIM_2 Read Done: Start 0, 1 Active Item(s), Time: 00:44.889
NVM_SIM_1 Read Done: Start 0, 41 Active Item(s), Time: 00:46.566
NVM Read Done: Start 0, 728 Active Item(s), Time: 00:46.090
Saved as: Var_XIAOMI-Mi A2 Lite Daisy_863896-04-327437-9_0F [2019_06_05_20_07_19].envm
Path: D:\ANDROID_UFS_1056_Test6\XIAOMI-Mi A2 Lite Daisy\NVM\
Var XIAOMI-Mi A2 Lite Daisy (Mi A2 Lite LTE DS) at Auto Select Flash Port [SAHARA] {Clear NVM}
SAHARA VERS: 2.1
SAHARA HWID: 000460E100000000 [MSM8953]
SAHARA SERN: 28CC7CB2 (684489906)
SAHARA PROG: prog_emmc_firehose_8953_ddr_daisy_rb1.mbn
SAHARA PRID: SA457FFB8621400276
FHPROG SZFT: 4096
FHPROG SZTT: 131072
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8953
FHPROG MEMT: eMMC
FHINFO DSK0: 61071360 x 512 Sectors (29.12 GB)
FHINFO MENM: DL2032
FHINFO MESN: 006E683D (7235645)
FHPROG PRTY: 0
FHWIPE DONE: DK 0 ST 0x000000FFFA fsg 8 MB
FHWIPE DONE: DK 0 ST 0x0000013FFA modemst1 8 MB
FHWIPE DONE: DK 0 ST 0x0000017FFA modemst2 8 MB
Clear NVM (3/3) Done in: 00:02.905
Wait, Restarting
Var XIAOMI-Mi A2 Lite Daisy (Mi A2 Lite LTE DS) at USB (COM68) [DIAGS] {Factory Info}
<<< STOP >>>
Comms Failed: -1 (No Response)
OFFLMODE: OK
NV IMEI1: 000000-00-000000-0
NV IMEI2: 000000-00-000000-0
Var XIAOMI-Mi A2 Lite Daisy (Mi A2 Lite LTE DS) at USB (COM69) [DIAGS] {Gen.Settings}
OFFLMODE: OK
Gen.Settings Write Done: 2 Item(s)
OFFLMODE: OK
NV IMEI1: 352234-34-556577-3
NV IMEI2: 352234-34-556576-5
Var XIAOMI-Mi A2 Lite Daisy (Mi A2 Lite LTE DS) at USB (COM69) [DIAGS] {Write ENVM}
OFFLMODE: OK
ENVM Image: Var_XIAOMI-Mi A2 Lite Daisy_863896-04-327437-9_0F [2019_06_05_20_07_19].envm
Image Version: 100
Image DEVICE_INFO: Var_XIAOMI-Mi A2 Lite Daisy_863896-04-327437-9
Image MDM_VERSION: MPSS.TA.3.0.c1-00326-8953_GEN_PACK-1.184854.2.199731.1
Directory Created: /pdn_limit_throttle/pdn_limit_throttle_params.txt
Directory Created: /GNSS/PE/AlmFile10
Directory Created: /mmgsdi/subs_prov_mgr/subs_prov_info.txt
Directory Created: /rfc/ip2_cal/gsm_ip2_cal_data.dat
Directory Created: /rfc/rffe_scan/rffe_scan.dat
Directory Created: /selfcal/modem/adc.dat
Directory Created: /gnss/cfg/sdp/private
Directory Created: /nv/item_files/gsm/gl1/gsm_rx_diversity
Directory Created: /nv/item_files/modem/geran/grr/g2l_blind_redir_after_csfb_control
Directory Created: /nv/item_files/modem/lte/rrc/cap/diff_fdd_tdd_fgi_enable
Directory Created: /nv/reg_files/modem/lte/rrc/asf/csg_db
Directory Created: /nv/reg_files/modem/lte/rrc/csp/acq_db
NVM SIM_2 Write Done: 1 Item(s), Time: 00:00.006
NVM SIM_1 IMEI: 351145-34-534647-0
Write of IMEI Item Skipped
NVM SIM_1 Write Done: 40 Item(s), Time: 01:06.121
Cannot Write NVM Item: 0x0001, Write Protected
NVM IMEI: 863896-04-327437-9
Cannot Write NVM Item: 0x0CB4, NACK: 14
Cannot Write NVM Item: 0x15DD, Write Protected
NVM Write Done: 724 Item(s), Time: 00:06.377
ENVM Write Done: 1558 File(s), Time: 03:39.342
The Following User Says Thank You to ferouz kassim For This Useful Post:
Old 06-09-2019, 12:34   #1473 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 730
Wink Lenovo ZUK-Z2-Z2131 Format Done with Ufst
Lenovo ZUK-Z2-Z2131 (ZUK Z2 Plus LTE DS) at Auto Select Flash Port [SAHARA] {Format Flash}
QDL USB Com: Vid_05c6&Pid_9008 (COM17)
SAHARA VERS: 2.1
SAHARA HWID: 009470E100000000 [MSM8996]
SAHARA HASH: CAB02552DC28F562E8C5BEFA75BC4A97B90AAB1C91A3C186EC 51F3D3D7D6A1C7
SAHARA SERN: 0F194938 (253315384)
SAHARA PROG: prog_emmc_firehose_8996_ddr_zuk.elf
SAHARA PRID: SAA0345DB95FE53911
FHPROG SZFT: 4096
FHPROG SZTT: 32768
FHPROG SPTT: 32768
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: MSM8996
FHPROG CHSN: 0x0F194938
FHPROG MEMT: eMMC
FHINFO DSK0: 122142720 x 512 Sectors (58.24 GB)
FHINFO MESN: 0FB9B2F5 (263828213)
FHPROG PRTY: 16
Big Partition: userdata, Will be Wiped First 512 MB
FHWIPE DONE: DK 0 ST 0x0000834218 userdata 512 MB
Format Flash (1/1) Done in: 02:06.399
{Ahmadge}
The Following User Says Thank You to ahmadge For This Useful Post:
Old 06-10-2019, 14:08   #1474 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 730
Thumbs down Lenovo K520 format frp Done with Ufst
format logo
Lenovo K520 (S5 LTE DS Seoul) at Auto Select Flash Port [SAHARA] {Format Flash}
SAHARA VERS: 2.1
SAHARA HASH: CAB02552DC28F562E8C5BEFA75BC4A97B90AAB1C91A3C186EC51F3D3D7D6A1C7
SAHARA SERN: D725A81E (3609569310)
SAHARA PROG: prog_emmc_firehose_8953_ddr_lenzuk.mbn
SAHARA PRID: SA608D13AE9A8DDD2C
FHPROG SZFT: 4096
FHPROG SZTT: 131072
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8953
FHPROG MEMT: eMMC
FHINFO MENM: RH64AB
FHINFO MESN: 8EFA9BE5 (2398788581)
FHPROG PRTY: 0
FHWIPE DONE: DK 0 ST 0x0000CC1410     userdata      512 MB
Format Flash (1/1) Done in: 00:36.348
frp remove logo
Lenovo K520 (S5 LTE DS Seoul) at Auto Select Flash Port [SAHARA] {Reset FRP}
SAHARA VERS: 2.1
FHPROG SZFT: 4096
FHPROG SZTT: 131072
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8953
FHPROG MEMT: eMMC
FHINFO MENM: RH64AB
FHPROG PRTY: 0
Reset FRP Done in: 00:00.157 (1)
Wow nice tool
{Ahmadge}
Old 06-15-2019, 20:47   #1475 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
HUAWEI CAG-L23 MTK FULL FRP REMOVED BY UFST
DA Agent : DA_PL_CAG3.bin
BR ComPort: COM14
BR Asic Id: MT0335 [0000] Alias: MT6735
BR Asic Sw: 8A00 CB00 0000 0000
BR Fuse Id: 94020000
BR Secured: 05 [SBC DAA]
DA AgentId: SADD08EC5FB2933FE8
DA Version: MTK_AllInOne_DA_v3.3001.00.00.
DA ProtVer: 2
PR MMC CID: 150100464E36324D4206469EF2FCBF17 [FN62MB]
PR Version: 4.2 [0x9B] (5) MT6735
eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB
eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB
eMMC RPMB : 0x0000000000080000 [524.288] 512 KB
eMMC USER : 0x00000001D2000000 [7.818.182.656] 7,28 GB
eMMC CID : 150100464E36324D4206469EF2FC4517 [FN62MB]
ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB
IRAM Size : 0x0000000000020000 [131.072] 128 KB
UNICAL RID: BF3E3C633A7FBB1C6CC219878A72A32B
PMT (GPT) Found: 40 Partition Entries
Reset FRP Done in: 00:02.968 (0)
DA Shutdown Done, Disconnect Cable
THX.
The Following 2 Users Say Thank You to Hacker84 For This Useful Post:
Old 06-21-2019, 10:46   #1476 (permalink)
Registered User
Member: 2698195
Thanks Meter: 18
VIVO Y81 (Y81 LTE DS PD1732F) Factory Reset done.
Var VIVO-Y81 (Y81 LTE DS PD1732F) at [VCOM] {Factory Def.}
Bad Port: Select Modem Port
Var VIVO-Y81 (Y81 LTE DS PD1732F) at USB Auto Select [MTK] {Format Flash}
BR USB Com: Vid_0e8d&Pid_2000 (Preloader)
DA Agent : DA_VIV65_0321.bin
BR ComPort: COM5
BR Asic Id: MT0766 [0000] Alias: MT6765
BR Asic Sw: 8A00 CA00 0000 0000
DA AgentId: SA5DE5E472C23D5EFB
DA Version: MTK_AllInOne_DA_v3.3001.2018/03/20.21:09_402229+403250.
Authentication Need BROM Boot (With Vol Keys)
DA ProtVer: 4
PR DlagVer: 1.0
PR BootMod: preloader
DA Asic Id: MT0766 [8A00 CA00 0000 0000 0000]
eMMC RPMB : 0x0000000001000000 [16.777.216] 16 MB
eMMC USER : 0x0000000747C00000 [31.268.536.320] 29.12 GB
eMMC CID : 90014A68423861503E0345D242D05533 [hB8aP>]
ERAM Size : 0x0000000030000000 [805.306.368] 768 MB
IRAM Size : 0x0000000000040000 [262.144] 256 KB
UNICAL RID: F564B3328BB02E973FB6BCAADA554452
DA USBconf: high-speed
PGPT Found: 46 Partition Entries
SGPT Found: 46 Partition Entries
Erasing: LinST: 0x017A000000 Size: 0x0010000000 cache
Erasing: LinST: 0x018A000000 Size: 0x05BA0FBE00 userdata
Format Flash Done in: 00:21.140
The Following 2 Users Say Thank You to BeatSahil For This Useful Post:
Old 06-29-2019, 08:01   #1477 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Gionee V6L Flashing Done
Var GIONEE-V6L (Ctrl V6L LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash}
QDL USB Com: Vid_05c6&Pid_9008 (COM5)
SAHARA VERS: 2.1
SAHARA HWID: 008050E100000000 [MSM8926]
SAHARA HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998421ADAD42A380F
SAHARA SERN: 0657AB70 (106408816)
SAHARA PROG: prog_emmc_firehose_8x26.mbn
SAHARA PRID: SAF5FA3FB2C5769A12
FHPROG SZFT: 4096
FHPROG SZTT: 16384
FHPROG SPTT: 49152
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8x26
FHPROG MEMT: eMMC
FHINFO DSK0: 15269888 x 512 Sectors (7.28 GB) Default
FHINFO DSK1: 8192 x 512 Sectors (4 MB) Default
FHINFO DSK2: 8192 x 512 Sectors (4 MB) Default
FHPROG PRTY: 4
Flash Bundle: rawprogram_unsparse.xml
Partitions to Write: 63 (1.54 GB)
FWRITE DONE: DSK0 ST 0x0000080000        aboot   396.62 KB
FWRITE DONE: DSK0 ST 0x0000080400     abootbak   396.62 KB
FWRITE DONE: DSK0 ST 0x00000A0000         boot    14.09 MB
FWRITE DONE: DSK0 ST 0x00000E0000       system   128.01 MB
FWRITE DONE: DSK0 ST 0x00003E0000      persist      4.2 MB
FWRITE DONE: DSK0 ST 0x00003F0000        cache     6.05 MB
FWRITE DONE: DSK0 ST 0x0000120308       system        8 KB
FWRITE DONE: DSK0 ST 0x0000121318       system   125.61 MB
FWRITE DONE: DSK0 ST 0x0000160000       system        8 KB
FWRITE DONE: DSK0 ST 0x0000161010       system   125.99 MB
FWRITE DONE: DSK0 ST 0x00001A0000       system        8 KB
FWRITE DONE: DSK0 ST 0x00001A0308       system        8 KB
FWRITE DONE: DSK0 ST 0x00001A1318       system   125.61 MB
FWRITE DONE: DSK0 ST 0x0000860000     userdata   127.14 MB
FWRITE DONE: DSK0 ST 0x00008A0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x00008A0608     userdata        8 KB
FWRITE DONE: DSK0 ST 0x00008A1618     userdata   112.82 MB
FWRITE DONE: DSK0 ST 0x00008E0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x00008E1010     userdata    25.64 MB
FWRITE DONE: DSK0 ST 0x0000920000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000920608     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000960000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x00009A0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x00009A0608     userdata        8 KB
FWRITE DONE: DSK0 ST 0x00009E0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000A20000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000A20608     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000A60000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000AA0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000AA0608     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000AE0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000B20000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000B60000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000BA0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000BE0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000C20000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000C60000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000CA0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000CE0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000D20000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000D60000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000DA0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000DE0000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x0000E20000     userdata        8 KB
FWRITE DONE: DSK0 ST 0x00001E0000       system        8 KB
FWRITE DONE: DSK0 ST 0x00001E1010       system   125.99 MB
FWRITE DONE: DSK0 ST 0x0000220000       system        8 KB
FWRITE DONE: DSK0 ST 0x0000220308       system        8 KB
FWRITE DONE: DSK0 ST 0x0000221318       system   125.61 MB
FWRITE DONE: DSK0 ST 0x0000260000       system        8 KB
FWRITE DONE: DSK0 ST 0x0000261010       system   125.99 MB
FWRITE DONE: DSK0 ST 0x00002A0000       system        8 KB
FWRITE DONE: DSK0 ST 0x00002A0308       system        8 KB
FWRITE DONE: DSK0 ST 0x00002A1318       system   125.61 MB
FWRITE DONE: DSK0 ST 0x00002E0000       system        8 KB
FWRITE DONE: DSK0 ST 0x00002E1010       system   125.99 MB
FWRITE DONE: DSK0 ST 0x0000320000       system        8 KB
FWRITE DONE: DSK0 ST 0x0000320308       system        8 KB
FWRITE DONE: DSK0 ST 0x0000321318       system    125.6 MB
FWRITE DONE: DSK0 ST 0x0000360000       system        8 KB
FWRITE DONE: DSK0 ST 0x0000361010       system    12.32 MB
FWRITE DONE: DSK0 ST 0x00003A0000       system        8 KB
FWRITE DONE: DSK0 ST 0x0000430000     recovery    14.53 MB
FHSETD DONE: Ok (Boot Disk: 0)
Write Flash Done in: 18:40.575
The Following User Says Thank You to 4G Telecom For This Useful Post:
Old 07-09-2019, 09:09   #1478 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Techno Air2+ Pattern unlock
Var TECNO-ID3K (Camon iAir 2+ LTE DS) at USB Auto Select [MTK] {Write Flash}
Scatter   : MT6761_Android_scatter.txt
DA Agent  : DA_INTC.bin
BR ComPort: COM663
BR Asic Id: MT0717 [0000] Alias: MT6761
BR Asic Sw: 8A00 CA01 0200 0000
DA AgentId: SAA79A0D8169C03239
DA Version: MTK_AllInOne_DA_v3.3001.2018/05/22.14:57_437806.
DA ProtVer: 4
PR DlagVer: 1.0
DA Asic Id: MT0717 [8A00 CA01 0200 0000 0000]
eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB
eMMC USER : 0x000000073A000000 [31.037.849.600] 28.91 GB
eMMC CID  : 880103534C44333262129F0B203185DB [SLD32b]
ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB
UNICAL RID: B1EABB8B9E360779CC51227D128B4D70
PGPT Found: 41 Partition Entries
SGPT Found: 41 Partition Entries
Partitions to Flash: 2 (25.15 GB)
Write preloader               256 KB, Skipped
Write pgpt                     32 KB, Skipped
Write boot_para              1024 KB, Skipped
Write recovery                 32 MB, Skipped
Write para                    512 KB, Skipped
Write tranfs                  300 MB, Skipped
Write expdb                    20 MB, Skipped
Write frp                    1024 KB, Skipped
Write nvcfg                    32 MB, Skipped
Write nvdata                   64 MB, Skipped
Write metadata                 32 MB, Skipped
Write protect1                  8 MB, Skipped
Write protect2              13.47 MB, Skipped
Write seccfg                    8 MB, Skipped
Write persist                  48 MB, Skipped
Write sec1                      2 MB, Skipped
Write proinfo                   3 MB, Skipped
Write md1img                  100 MB, Skipped
Write spmfw                  1024 KB, Skipped
Write scp1                   1024 KB, Skipped
Write scp2                   1024 KB, Skipped
Write sspm_1                 1024 KB, Skipped
Write sspm_2                 1024 KB, Skipped
Write gz1                      16 MB, Skipped
Write gz2                      16 MB, Skipped
Write nvram                    64 MB, Skipped
Write lk                     1024 KB, Skipped
Write lk2                    1024 KB, Skipped
Write boot                     32 MB, Skipped
Write logo                      8 MB, Skipped
Write dtbo1                     8 MB, Skipped
Write dtbo2                     8 MB, Skipped
Write tee1                      5 MB, Skipped
Write tee2                     11 MB, Skipped
Write vendor                  808 MB, Skipped
Write system                 2.09 GB, Skipped
Write cache                  8.63 MB, Done in: 00:00.640 (Sparsed)
Write userdata              50.99 MB, Done in: 00:02.449 (Sparsed)
Write otp                      43 MB, Skipped
Write flashinfo                16 MB, Skipped
Write sgpt                   16.5 KB, Skipped
Write Done in : 00:04.836
Old 07-18-2019, 09:15   #1479 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 459
Nokia 5.1 TA-1075 remove frp OK !!!
Nokia TA-1075 (Nokia 5.1 LTE DS CO2) at USB Auto Select [MTK] {Reset FRP}
BR USB Com: Vid_0e8d&Pid_0003 (BROM)
DA Agent : MTK_AllInTwo_DA.bin
BR ComPort: COM3
BR Asic Id: MT0326 [0000] Alias: MT6755
BR Asic Sw: 8A00 CB00 0001 0000
BR Fuse Id: 00008486
BR ME_ID : B11C1D072D36FAE1C92A5782219FA43C
BR Secured: 01 [SBC]
DA AgentId: SACD617A028AD75F6F
DA Version: MTK_AllInOne_DA_v3.3001.2018-11-07.23:57_458956.
DA ProtVer: 4
PR DlagVer: 1.0
PR DlagVer: 2099.3.3
PR BootMod: brom
EMI PreLdr: preloader_CO2.bin
EMI TagVer: 22
DA Asic Id: MT6750 [8A00 CB00 0001 0000 0000]
eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14,56 GB
eMMC CID : 150100514536334D42033C4BDE8085C1 [QE63MB]
UNICAL RID: F5FDF4AA277292943CDCC51137C36FE9
DA USB Com: Vid_0e8d&Pid_2001 (DA HighSpeed)
PGPT Found: 50 Partition Entries
SGPT Found: 50 Partition Entries
Reset FRP Done in: 00:09.071 (3)
The Following User Says Thank You to Umbabaraumba For This Useful Post:
Old 07-29-2019, 08:37   #1480 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 459
Nokia 3.1 TA-1057 remove FRP OK !
Nokia TA-1057 (Nokia 3.1 LTE DS ES2) at USB Auto Select [MTK] {Reset FRP}
BR ComPort: COM3
BR Fuse Id: 00001C46
BR ME_ID : A860E9CBC09AEB2C2ABA2CEE1AAD30CB
DA ProtVer: 4
PR DlagVer: 1.0
PR BootMod: brom
EMI PreLdr: preloader_ES2.bin
EMI TagVer: 22
eMMC CID : 150100514536334D4203D789D37855AD [QE63MB]
UNICAL RID: F2DBA85AFB01A25054DBC83363A24A94
Reset FRP Done in: 00:10.831 (3)
Old 08-01-2019, 16:39   #1481 (permalink)
Member: 1596913
Thanks Meter: 107
Nokia 2
Nokia TA-1029 (Nokia 2 LTE DS E1M) at Auto Select Flash Port [SAHARA] {Reset FRP}
QDL USB Com: Vid_05c6&Pid_9008 (COM31)
SAHARA VERS: 2.1
SAHARA HWID: 009600E100000000 [MSM8909]
SAHARA HASH: F5F4192A33B2830974B400119BAB728CC9FE911011F928625C 2AED0DA441AC97
SAHARA SERN: 0CB7E0D4 (213377236)
SAHARA PROG: prog_emmc_firehose_8909_ddr_hmd.mbn
SAHARA PRID: SA181403B673F3DEAB
FHPROG SZFT: 4096
FHPROG SZTT: 131072
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8909
FHPROG MEMT: eMMC
FHINFO DSK0: 15269888 x 512 Sectors (7,28 GB)
FHPROG PRTY: 0
Reset FRP Done in: 00:00.406 (1)
The Following 2 Users Say Thank You to vaterpahk For This Useful Post:
Old 08-04-2019, 00:48   #1482 (permalink)
Member: 603138
Thanks Meter: 100
LG X240F (K8 (2017) LTE) at USB Auto Select [MTK] {Reset FRP}
DA Agent : DA_SWSEC_CRYPTO20_LG.bin
BR ComPort: COM15
BR Fuse Id: A4020000
BR ME_ID : C00E71D1B4D9AA3517F2997200985402
DA AgentId: SA6B1EC25E16CD4357
DA ProtVer: 2
PR MMC CID: 15010051333136424202194BD10040E7 [Q316BB]
PR Version: 4.2 [0x93] (5) MT8735
DRAM Confg: 15010051333136424202194BD10040E7
EMI PreLdr: preloader_lv3.bin
EMI TagVer: 20
DRAM Enabl: 02000000000060000000
eMMC CID : 15010051333136424202194BD10094E7 [Q316BB]
ERAM Size : 0x0000000060000000 [1.610.612.736] 1,5 GB
UNICAL RID: 8688882D4DFFB712B64909C25DEA6E9A
PMT (GPT) Found: 29 Partition Entries
Reset FRP Done in: 00:07.720 (0)
The Following User Says Thank You to jeilyscell For This Useful Post:
Old 08-13-2019, 10:48   #1483 (permalink)
Member: 2185549
Thanks Meter: 535
huawei mrd-lxf1(y6 2019) mtk frp reset done "who said we dead????"
MTK MT6763 (eMMC) at USB Auto Select [MTK] {Reset FRP}
DA Agent : DA_HU6165_C1A9.bin
BR ComPort: COM10
BR ME_ID : 7591457E7399E561C9A23BD693F703E0
BR Secured: E5 [SBC DAA]
DA AgentId: SA1A7A54C950A268E7
DA Version: MTK_AllInOne_DA_v3.3001.2018/10/18.17:38_452898.
Auth File : Hua_C1A9_sv5.auth
Auth FiId : SA2950FD448DA68224
DA ProtVer: 4
PR DlagVer: 1.0
PR BootMod: brom
EMI PreLdr: preloader_k61v1_64_mexico.bin
EMI TagVer: 38
EMI Config: Ok
eMMC CID : 150100514436334D4201BD6DD25816FD [QD63MB]
IRAM Size : 0x0000000000080000 [524.288] 512 KB
UNICAL RID: 4097E9599117CE320CAF6FF9A17115AF
PGPT Found: 48 Partition Entries
SGPT Found: 48 Partition Entries
GPT Error : PGPT <> SGPT
Reset FRP Done in: 00:11.916 (3)
say it one more time
Old 08-13-2019, 12:47   #1484 (permalink)
Member: 1656416
Thanks Meter: 23
Huawei CRO-UOO reset FRP done
UFS has always been one of the best boxes, we hope UFST team returns
Huawei CRO-U00 (Y3 2017 3G DS Cairo) at USB Auto Select [MTK] {Reset FRP}
DA Agent  : DA_PL_CRU.bin
BR ComPort: COM10
BR Asic Id: MT6580 [0000]
BR Fuse Id: 40001002
DA AgentId: SAC584B90242497D9A
DA ProtVer: 2
PR MMC CID: 90014A483847346132D428F23094740B [H8G4a2]
PR Version: 4.2 [0x94] (7)     MT8591
eMMC CID  : 90014A483847346132D428F23094740B [H8G4a2]
UNICAL RID: EA1A1EA50B3018BD7C4CA1C57CEEBB62
PMT (GPT) Found: 27 Partition Entries
Reset FRP Done in: 00:06.121 (0)
Other boxes did not reset Google Account
The Following User Says Thank You to bs123 For This Useful Post:
Old 08-16-2019, 12:05   #1485 (permalink)
Member: 2185549
Thanks Meter: 535
Var ITEL-A14 (A14 3G DS SA215) at USB Auto Select [SPRD] {Reset FRP}
BOOT: FDL1 and FDL2 from Default [Fdl] SC7731E_Itel_A14_fdl
Hold Vol+, Vol- and Insert Cable to Switched OFF Device
FDLA: 50002E00, 9EFFFE00
SROM: SPRD3
FDL1:
FDL2: Ok, 96, v1.1
Reset FRP Done in: 00:00.131
Restart Done, Disconnect Cable
All Done in: 00:12.341
Page generated in 0.37361 seconds with 9 queries
