05-24-2018, 08:37 | #1201 (permalink) |
Insane Poster Join Date: Jun 2012 Location: vasai, mumbai,india
Member: 1768108 Status: Offline Sonork: [email protected] Thanks Meter: 15 | (1) DOWNLOAD FIRMWARE,OPEN UFST TOOL AND SELECT FILE IN ADD FILES (2)REMOVE BATTERY AND PUT IN AGAIN PRESS VOLUME UP+ BUTTON AND INSER CABLE CLICK ON WRITE FLASH SEE VIDEO https://*********/yss2xYlJuNg |
The Following User Says Thank You to rrajsa For This Useful Post: |
05-31-2018, 16:58 | #1202 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | TECNO F2 FRP RESET DONE MTK MT6580 (eMMC) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_0003 (BROM) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM43 BR Asic Id: MT6580 [0000] BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 40001002 DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 150100464E36324D4203798FCEABB4C7 [FN62MB] PR Version: 4.2 [0x9C] (7) MT6580 DRAM Confg: 460001154D32364E8F790342C7B4ABCE EMI PreLdr: preloader_lava6580_sp511.bin EMI TagVer: 21 DRAM Enabl: 02000000000040000000 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000080000 [524.288] 512 KB eMMC USER : 0x00000001D2000000 [7.818.182.656] 7.28 GB eMMC CID : 150100464E36324D4203798FCEABB4C7 [FN62MB] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : 74350787BEA5E8DD331C7A490F6ADC8D DA USB Com: Vid_0e8d&Pid_2001 (DA HighSpeed) PMT (GPT) Found: 25 Partition Entries Reset FRP Done in: 00:15.582 DA Shutdown Done, Disconnect Cable |
06-01-2018, 09:56 | #1203 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | LG H631 FLASHING DONEEE File: H63120o_00_0502.kdz File Format: KDZ Type 2, Includes: H63120o_00.dz Model: LG-H631 File: H63120o Partitions {Chunks): 45 RbId: FFFFFFFFFFF-FFFFFFFFFFF-FFFFFFFFFFF-FFFFFFFFFFF-F user Partitions (Chunks) to Flash: 45 (2.31 GB) LG H631 (G Stylo MetroPCS) at USB (COM164) [LG FLASH 5] {Write Flash} DL MODE : 6 DL REQM : 5 DL MODEL: LG-H631 DL SWVER: H63120o DL IMEI : 358387-06-377170-2 LF MODEL: LG-H631 LF SERNO: LGH631ab41cc26 LF SWVER: LGH631AT-01-V20o-310-260-MAY-02-2017-ARB02+0 LF MINOS: MiniOS 3.0 LF OSVER: 6.0 LF IMEI : 351990-44-321234-2 LF DVPID: HD60S150723004900 LF SOCTY: msm8916 LF CABLE: 633A Writing Partition: PrimaryGPT Writing Partition: sbl1 Writing Partition: tz Writing Partition: hyp Writing Partition: rpm Writing Partition: aboot Writing Partition: sbl1bak Writing Partition: tzbak Writing Partition: hypbak Writing Partition: rpmbak Writing Partition: abootbak Writing Partition: persist Writing Partition: laf Writing Partition: boot Writing Partition: recovery Writing Partition: sec Writing Partition: rct Writing Partition: factory Writing Partition: modem Writing Partition: system Writing Partition: BackupGPT Flash Write Done in: 07:34.131 LF CLOSE: 0k RESTART : 2 |
06-07-2018, 11:58 | #1204 (permalink) |
Major Poster Join Date: Jun 2012 Location: ujiouoioliop Age: 39
Member: 1778446 Status: Offline Thanks Meter: 34 | Micromax q402 (bharat 2) frp done boot key vol+ only MicroMax Q402 (Brahat 2 LTE DS) at USB Auto Select [SPRD] {Reset FRP} BOOT: FDL1 and FDL2 from Default [DA] Hold Vol+, Vol- and Insert Cable to Switched OFF Device SROM_BOOT Failed: SROM_BOO1 NACK MicroMax Q402 (Brahat 2 LTE DS) at USB Auto Select [SPRD] {Reset FRP} BOOT: FDL1 and FDL2 from Default [DA] Hold Vol+, Vol- and Insert Cable to Switched OFF Device SROM: SPRD3 FDL1: FDL2: Ok, 96 Reset FRP Done in: 00:00.061 Restart Done, Disconnect Cable All Done in: 00:12.235 |
06-08-2018, 07:57 | #1205 (permalink) |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | LYF F90M (Feature(Key pad) Phone) Dead Recovered Done....... Full Logs............ Code: QC MSM8909 (eMMC) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM31) Flash Bundle: rawprogram_unsparse.xml SAHARA VERS: 2.1 SAHARA HWID: 000940E100000000 SAHARA HASH: 1067E9AE286872C1F6EDEEFFD7A955223CD27EF2900702584B28629E69F88584 SAHARA SERN: 1109C304 (285852420) SAHARA PROG: prog_emmc_firehose_8909_lite.mbn FHPROG SZFT: 4096 FHPROG SZTT: 16384 FHPROG SPTT: 16384 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8909 FHPROG MEMT: eMMC FHINFO PAR0: 7634944 x 512 Sectors (3.64 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 Partitions to Write: 55 (514.23 MB) FWRITE DONE: ST 0x0000020000 modem 46.47 MB FWRITE DONE: ST 0x0000040000 sbl1 241.12 KB FWRITE DONE: ST 0x0000040400 sbl1bak 241.12 KB FWRITE DONE: ST 0x0000040800 aboot 504.17 KB FWRITE DONE: ST 0x0000041000 abootbak 504.17 KB FWRITE DONE: ST 0x0000041800 rpm 158.52 KB FWRITE DONE: ST 0x0000041C00 rpmbak 158.52 KB FWRITE DONE: ST 0x0000042000 tz 515.26 KB FWRITE DONE: ST 0x0000042600 tzbak 515.26 KB FWRITE DONE: ST 0x0000045412 splash 150.5 KB FWRITE DONE: ST 0x0000060C40 sec 428 Byte FWRITE DONE: ST 0x0000070C60 system 128.01 MB FWRITE DONE: ST 0x00000B0E28 system 8 KB FWRITE DONE: ST 0x00000B1C68 system 126 MB FWRITE DONE: ST 0x0000130C60 system 8 KB FWRITE DONE: ST 0x0000130E28 system 8 KB FWRITE DONE: ST 0x0000131C68 system 118.86 MB FWRITE DONE: ST 0x0000170C60 system 8 KB FWRITE DONE: ST 0x00001B0C60 system 8 KB FWRITE DONE: ST 0x00001B0E28 system 8 KB FWRITE DONE: ST 0x00001F0C60 system 8 KB FWRITE DONE: ST 0x00001F1AA0 system 30.17 MB FWRITE DONE: ST 0x0000200C60 persist 4.6 MB FWRITE DONE: ST 0x0000220000 usbmsc 2.16 MB FWRITE DONE: ST 0x0000260000 usbmsc 8 KB FWRITE DONE: ST 0x0000260208 usbmsc 8 KB FWRITE DONE: ST 0x00002A0000 usbmsc 8 KB FWRITE DONE: ST 0x00002E0000 usbmsc 8 KB FWRITE DONE: ST 0x00002E0208 usbmsc 8 KB FWRITE DONE: ST 0x0000320000 usbmsc 8 KB FWRITE DONE: ST 0x0000360000 usbmsc 8 KB FWRITE DONE: ST 0x0000360208 usbmsc 8 KB FWRITE DONE: ST 0x00003A0000 usbmsc 8 KB FWRITE DONE: ST 0x00003E0000 usbmsc 8 KB FWRITE DONE: ST 0x00003E0208 usbmsc 8 KB FWRITE DONE: ST 0x00003E1150 usbmsc 15.21 MB FWRITE DONE: ST 0x0000420000 cache 6.09 MB FWRITE DONE: ST 0x0000460000 cache 8 KB FWRITE DONE: ST 0x0000460088 cache 8 KB FWRITE DONE: ST 0x0000060C60 boot 7.4 MB FWRITE DONE: ST 0x00004A0000 recovery 7.79 MB FWRITE DONE: ST 0x00004E0800 userdata 18.27 MB FWRITE DONE: ST 0x0000520800 userdata 8 KB FWRITE DONE: ST 0x0000520A08 userdata 8 KB FWRITE DONE: ST 0x0000560800 userdata 8 KB FWRITE DONE: ST 0x00005A0800 userdata 8 KB FWRITE DONE: ST 0x00005A0A08 userdata 8 KB FWRITE DONE: ST 0x00005E0800 userdata 8 KB FWRITE DONE: ST 0x0000620800 userdata 8 KB FWRITE DONE: ST 0x0000620A08 userdata 8 KB FWRITE DONE: ST 0x0000660800 userdata 8 KB FWRITE DONE: ST 0x00006A0800 userdata 8 KB FWRITE DONE: ST 0x00006A0A08 userdata 8 KB FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB FWRITE DONE: ST 0x0000000021 BackupGPT 16.5 KB FPATCH DONE: 13 FHSETD DONE: Ok FHREST DONE: Ok Write Flash Done in: 01:13.913 |
The Following 3 Users Say Thank You to 4G Telecom For This Useful Post: |
06-08-2018, 10:20 | #1206 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Nokia 3 ta-1020 reset frp ok !!! BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_SWSEC_CRYPTO20_HMD.bin BR ComPort: COM33 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: A4010000 BR Secured: 5 [SBC DAA] DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 484A019061344741B52FA532F3E595EF [a4GA] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003AB400000 [15.758.000.128] 14,68 GB eMMC CID : 90014A484147346132A52FB5EF95A4F3 [HAG4a2] ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : 5BDE1BFC022CC232A3CC59F388C1FFCB PMT (GPT) Found: 30 Partition Entries Reset FRP Done in: 00:03.110 DA Shutdown Done, Disconnect Cable |
06-14-2018, 23:27 | #1207 (permalink) |
No Life Poster Join Date: Oct 2005 Location: AsTeknik Elektronik
Member: 194874 Status: Offline Thanks Meter: 458 | Xiaomi mi max 2 imei repair done every model is written in every update. do not understand. it is better to just add phone models. we want to be able to understand the updates like other boxes. XIAOMI MI MAX 2 IMEI REPAIR DONE only UFST could not do other boxes. EFS can not reset other boxes. 1 - UNLOCK BOOTLOADER 2 - TWRP + SUPERSU 3 - ENABLE DIAG 4 - CLEAR EFS + IMEI REPAIR GEN SETTINGS (UFST) 5 - QCN WRITE (GCPRO) ------ CLEAR NVM ---------- Var XIAOMI-Mi Max 2 Oxygen (Mi Max 2 LTE DS) at USB (COM10) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: Apr 12 201818:30:33Oct 25 201723:00:008953.gen MDMBUILD: TA.2.3.c1-00100.1-0412_1824_c2ce73a NV IMEI1: 86416xx NV IMEI2: 86416xx NV BTID : 18F0:Exx NV WIFI : 2006:25xx Var XIAOMI-Mi Max 2 Oxygen (Mi Max 2 LTE DS) at USB [ADB] {Clear NVM} daemon started successfully * 299adeca device Superuser Permissions Granted (SU) Clear NVM Done in: 00:02.184 Wait, Restarting ADB Reboot Done IMEI REPAIR ----------- Var XIAOMI-Mi Max 2 Oxygen (Mi Max 2 LTE DS) at USB (COM10) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: Apr 12 201818:30:33Oct 25 201723:00:008953.gen MDMBUILD: TA.2.3.c1-00100.1-0412_1824_c2ce73a NV IMEI1: 000000-00-000000-0 NV IMEI2: 000000-00-000000-0 NV BTID : 0000:00:000000 NV WIFI : 0000:00:000000 Gen.Settings Write Done: 4 Item(s) QCN WRITE (GCPRO) ---------------- Using Version...1.0.0.0057 Selected Port Qualcomm HS-USB Android DIAG 901D COM10 Selected Model GT-I5500 Selected Task NV_QCN WRITE Searching phone... Build...TA.2.3.c1-00100.1-0412_1824_c2ce73a Please wait till finish... !!! SUCCESS !!! All Finish... Total Time Take...00:01:07 Log Saved |
The Following 3 Users Say Thank You to WhyLeR For This Useful Post: |
06-21-2018, 13:36 | #1208 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | redmi note4x mido imei repair done miu8 android 7 done Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at Auto Select Flash Port [SAHARA] {Read EFS} QDL USB Com: Vid_05c6&Pid_9008 (COM66) SAHARA VERS: 2.1 SAHARA HWID: 000460E100000000 [MSM8953] SAHARA HASH: 57158EAF1814D78FD2B3105ECE4DB18A817A08AC664A5782A9 25F3FF8403D39A SAHARA SERN: 139B7F1E (328957726) SAHARA PROG: prog_emmc_firehose_8953_ddr_xiaomi2.mbn FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8953 FHPROG MEMT: eMMC FHINFO PAR0: 122142720 x 512 Sectors (58.24 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 FHREAD DONE: ST 0x000006B412 modemst1 1.5 MB FHREAD DONE: ST 0x000006C012 modemst2 1.5 MB FHREAD DONE: ST 0x0000080040 fsg 1.5 MB FHREST DONE: Ok Read EFS Done in: 00:01.019 Saved as: XIAOMI-Redmi Note 4 Mido_NVM_BACKUP [2018_06_21_15_14_58].tar Path: D:\ANDROID_UFS_1056_Test6\XIAOMI-Redmi Note 4 Mido\EFS\ Wait, Restarting Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at USB (COM383) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Apr 28 201815:51:49Feb 26 201800:00:008953.gen MDMBUILD: MPSS.TA.2.2.c1-00442-8953_GEN_PACK-1.134037.1.138074.1 NV IMEI1: 866751-03-743268-0 NV IMEI2: 866751-03-743269-8 NV BTID : 18F0:E4:CBC5A4 NV WIFI : A5C5:CB:E4F018 Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at USB (COM383) [DIAGS] {Read ENVM} OFFLMODE: OK Set SPC Password: 000000, OK MDMVERSN: Apr 28 201815:51:49Feb 26 201800:00:008953.gen MDMBUILD: MPSS.TA.2.2.c1-00442-8953_GEN_PACK-1.134037.1.138074.1 NV IMEI1: 866751-03-743268-0 Get Names GN PROTECTED_NODE: /.efs_private Get Names GN PROTECTED_NODE: /nvm Get Names GN PROTECTED_NODE: /safe EFS2 Read Found: 1448 File(s), 0 Link(s) EFS2 Read Done : 1448 File(s), Time: 00:55.986 NVM_SIM_2 Read Done: Start 0, 5 Active Item(s), Time: 00:54.359 NVM_SIM_1 Read Done: Start 0, 53 Active Item(s), Time: 00:49.916 NVM Read Done: Start 0, 674 Active Item(s), Time: 00:59.034 Saved as: Var_XIAOMI-Redmi Note 4 Mido_866751-03-743268-0_0F [2018_06_21_15_21_07].envm Path: D:\ANDROID_UFS_1056_Test6\XIAOMI-Redmi Note 4 Mido\NVM\ Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at Auto Select Flash Port [SAHARA] {Clear NVM} Qualcomm HS-USB QDLoader 9008 Port not Found: Vid_05c6&Pid_9008 Bad Port: SAHARA Connect Fail: -1 Clear NVM Failed Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at Auto Select Flash Port [SAHARA] {Clear NVM} QDL USB Com: Vid_05c6&Pid_9008 (COM66) SAHARA VERS: 2.1 SAHARA HWID: 000460E100000000 [MSM8953] SAHARA HASH: 57158EAF1814D78FD2B3105ECE4DB18A817A08AC664A5782A9 25F3FF8403D39A SAHARA SERN: 139B7F1E (328957726) SAHARA PROG: prog_emmc_firehose_8953_ddr_xiaomi2.mbn FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8953 FHPROG MEMT: eMMC FHINFO PAR0: 122142720 x 512 Sectors (58.24 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 FHWIPE DONE: ST 0x000006B412 modemst1 1.5 MB FHWIPE DONE: ST 0x000006C012 modemst2 1.5 MB FHWIPE DONE: ST 0x0000080040 fsg 1.5 MB FHREST DONE: Ok Clear NVM Done in: 00:00.650 Wait, Restarting Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at USB (COM383) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Apr 28 201815:51:49Feb 26 201800:00:008953.gen MDMBUILD: MPSS.TA.2.2.c1-00442-8953_GEN_PACK-1.134037.1.138074.1 NV IMEI1: 000000-00-000000-0 NV IMEI2: 000000-00-000000-0 NV BTID : 0000:00:000000 NV WIFI : 0000:00:000000 Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at USB (COM383) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: Apr 28 201815:51:49Feb 26 201800:00:008953.gen MDMBUILD: MPSS.TA.2.2.c1-00442-8953_GEN_PACK-1.134037.1.138074.1 NV IMEI1: 000000-00-000000-0 NV IMEI2: 000000-00-000000-0 NV BTID : 0000:00:000000 NV WIFI : 0000:00:000000 NVM SIM_0 Write Failed Item: 0x0226, Code: 00 MDM_NVM_IMEI1 Write Failed NVM SIM_1 Write Failed Item: 0x0226, Code: 4B MDM_NVM_IMEI2 Write Failed Gen.Settings Write Done: 0 Item(s) Var XIAOMI-Redmi Note 4 Mido (Note 4 LTE DS) at USB (COM383) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Apr 28 201815:51:49Feb 26 201800:00:008953.gen MDMBUILD: MPSS.TA.2.2.c1-00442-8953_GEN_PACK-1.134037.1.138074.1 NV IMEI1: 359880-97-656765-3 NV IMEI2: 351145-46-675777-8 NV BTID : 0000:00:000000 NV WIFI : 0000:00:000000 |
The Following 3 Users Say Thank You to ferouz kassim For This Useful Post: |
06-27-2018, 20:35 | #1209 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | samsng s6 edge+ at&t u5 security unlock done Samsung SM-G928A (S6 Edge Plus ATT) at USB (COM358) [MODEM] {Fact.Unlock} MODEMCON: OK SERIALNR: R38GC06RYRE,151204, MSL ADDR: R38GC06RYR Use [Reset MSL] to Bypass MSL Security Product not Authenticated Samsung SM-G928A (S6 Edge Plus ATT) at USB (COM358) [MODEM] {Reset MSL} MODEMCON: OK SERIALNR: R38GC06RYRE,151204, MSL ADDR: R38GC06RYR MSL Updated in 00:10.047 Samsung SM-G928A (S6 Edge Plus ATT) at USB (COM358) [MODEM] {Fact.Unlock} MODEMCON: OK SERIALNR: R38GC06RYRE,151204, MSL ADDR: R38GC06RYR Lock Keys Reset: MCK : 12345678 NCK : 12345678 NSCK: 12345678 SPCK: 12345678 CPCK: 12345678 SIM : 12345678 Unlock Done in: 00:02.808 |
07-01-2018, 08:45 | #1210 (permalink) |
No Life Poster Join Date: Jan 2018
Member: 2805120 Status: Offline Thanks Meter: 1,025 | Redmi 1s hang on logo flash success by ufst 1.0.5.6 REDMI 1S HANG ON LOGO FLASH SUCCESS BY UFST 1.0.5.6 |
The Following 2 Users Say Thank You to MOHAMMEDALI2010 For This Useful Post: |
07-01-2018, 09:09 | #1211 (permalink) |
Member: 2805120 Status: Offline Thanks Meter: 1,025 | Mi note 3 mi account removed done by flashing ufst 1.0.5.6 MI NOTE 3 MI ACCOUNT REMOVED DONE BY FLASHING UFST 1.0.5.6 |
The Following 3 Users Say Thank You to MOHAMMEDALI2010 For This Useful Post: |
07-02-2018, 13:56 | #1212 (permalink) |
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | DIVA QC-704G reset FRP OK Reset FRP successfully on DIVA QC-704G MTK MT6737 (eMMC) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM33 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: 14000000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 4500017C3030534D0A103A38EBC10603 [|00SM] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000080000 [524.288] 512 KB eMMC USER : 0x00000001CCD80000 [7.731.675.136] 7,2 GB eMMC CID : 7C0100454D533030383A100A0306A3EB [EMS008] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : C04A3EADEA05DEF5FEEC1C633C46C109 PMT (GPT) Found: 25 Partition Entries Reset FRP Done in: 00:03.564 DA Shutdown Done, Disconnect Cable |
07-02-2018, 14:04 | #1213 (permalink) |
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | ARCHOS 70 Xenon AC70XEC Reset FRP OK MTK MT8321 (eMMC) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM33 BR Asic Id: MT6580 [0000] BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 60001002 DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 8801034E436172642025AF010000847D [NCard ] PR Version: 4.2 [0x9C] (7) MT6580 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000001CE100000 [7.752.122.368] 7,22 GB eMMC CID : 8801034E436172642025AF010000847D [NCard ] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : 0065044E5B432A301D8CBBE25F9799C7 PMT (GPT) Found: 23 Partition Entries Reset FRP Done in: 00:06.046 DA Shutdown Done, Disconnect Cable |
07-04-2018, 15:46 | #1214 (permalink) |
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | HAMMER myPhone reset FRP OK Reset FRP myPhone HAMMER ENERGY MTK MT6735 (eMMC) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM33 BR Asic Id: MT0321 [0000] Alias: MT6735 BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 84010000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 4400014531303446992C0136DF1A6A9C [E104F] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003AB400000 [15.758.000.128] 14,68 GB eMMC CID : 450100444634303136012C999C6AC3DF [DF4016] ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : DC9036DFC82E6925994F4C074D4B25C5 PMT (GPT) Found: 25 Partition Entries Reset FRP Done in: 00:03.513 DA Shutdown Done, Disconnect Cable |
