09-24-2018, 00:47 | #1291 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Exists dedicated button [Reset FRP] so select Right Model and use it, all will be done without a pain about in which partition resides FRP data. And [Reset FRP] works in different, more correct way than [Format Flash] |
09-24-2018, 22:01 | #1293 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Which Button to remove ? I see you mixing some things, so let me to explane. FRP is acronym from 'Factory Reset Protection' solution proposed by Google from OS version 5.1.1 and have nothing todo with Partition name. Factory Reset Protection solution need some place to store 'secure' data. Here is none convention how this place will be named or where stored, it can be Disk, Partition, File or even Physical sectors. Every manufacturer can choose in his own way: MTK - frp, Qualcomm - config, frp, Spreadtrum - persist, Samsung, LG - persistent .... You can make own OS and name it as 'blabla' for example. Property ro.frp.pst points to Factory Reset Protection data placeholder [Reset FRP] button detects automatically where data is stored and mods it. and it have nothing todo with [Format Flash] button which is used to wipe any partition not only frp partition ... Last edited by Sha; 09-24-2018 at 22:20. |
The Following 6 Users Say Thank You to Sha For This Useful Post: |
09-28-2018, 12:17 | #1295 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | LG H630D{Reset FRP} Code: LG H630D (G4 Stylus LTE DS) at Auto Select Flash Port [LG FLASH 5] {Reset FRP} DL MODE : 6 DL REQM : 5 DL MODEL: LG-H630D DL SWVER: H63010g DL IMEI : 352776-07-009669-7 LF MODEL: LG-H630D LF SERNO: LGH630D5ac03065 LF SWVER: LGH630DAT-00-V10g-IND-XX-NOV-27-2015+0 LF MINOS: MiniOS 3.0 LF OSVER: 5.0.2 LF IMEI : 352776-07-009669-7 LF DVPID: CT68S150618003728 LF SOCTY: msm8916 LF CABLE: USER Reset FRP Done in 00:08.818 LEAVE LAF Command Interface Closed |
09-29-2018, 09:00 | #1297 (permalink) |
Freak Poster Join Date: Apr 2016 Location: GSM Forum Age: 27
Member: 2559216 Status: Offline Thanks Meter: 220 | Lenovo A6600d40 Reset FRP done By UFST Code: Lenovo A6600d40 (A6600+ LTE DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_SWSEC_CRYPTO20_K10a40.bin BR ComPort: COM84 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: 24000000 DA AgentId: SA84B09001F866FD7F DA Version: MTK_AllInOne_DA_v3.3001.00.00. DA ProtVer: 2 PR MMC CID: 460001154D32314576620742A31862D8 [M21Ev] PR Version: 4.2 [0x93] (5) MT8735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14.56 GB eMMC CID : 150100464531324D42076276D86273A3 [FE12MB] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : E13A022D1EE7F479364156F3164B96BE PMT (GPT) Found: 25 Partition Entries Reset FRP Done in: 00:02.844 (0) DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to Riz_Mobile For This Useful Post: |
09-29-2018, 10:42 | #1298 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | Panasonic eluga i2 hang logo and frp Var PANASONIC-Eluga I2 (Eluga I2 LTE DS) at USB Auto Select [MTK] {Format Flash} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM56 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: 24000000 DA Version: MTK_AllInOne_DA_v3.3001.00.00. DA ProtVer: 2 PR MMC CID: 460001154D323237B9710042CB8C319A [M227] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000080000 [524.288] 512 KB eMMC USER : 0x00000001D2000000 [7.818.182.656] 7.28 GB eMMC CID : 150100463732324D420071B99A31C3CB [F722MB] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : B8A21443E2A4CAAE2F186E3B27DCE00F PMT (GPT) Found: 25 Partition Entries Erasing: LinST: 0x00A4000000 Size: 0x012CF80000 userdata Format Flash Done in: 00:07.054 DA Shutdown Done, Disconnect Cable Var PANASONIC-Eluga I2 (Eluga I2 LTE DS) at USB Auto Select [MTK] {Format Flash} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM56 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: 24000000 DA Version: MTK_AllInOne_DA_v3.3001.00.00. DA ProtVer: 2 PR MMC CID: 460001154D323237B9710042CB8C319A [M227] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000080000 [524.288] 512 KB eMMC USER : 0x00000001D2000000 [7.818.182.656] 7.28 GB eMMC CID : 150100463732324D420071B99A31C3CB [F722MB] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : B8A21443E2A4CAAE2F186E3B27DCE00F PMT (GPT) Found: 25 Partition Entries Erasing: LinST: 0x0006A00000 Size: 0x0000100000 frp Format Flash Done in: 00:03.543 DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to trio1 For This Useful Post: |
10-02-2018, 18:21 | #1299 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1596913 Status: Offline Thanks Meter: 107 | Vivo X20A Reset user password, hard reset did not help, the password remained. Var VIVO-X20 (X20 LTE DS PD1709F) at Auto Select Flash Port [SAHARA] {Format Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM4) SAHARA VERS: 2.1 SAHARA HWID: 0008C0E100730003 [SDM660] SAHARA HASH: F188B3BC5198FB412FC8AB7EF8B60D245EBB705A0FC0AF387F 1DB21533CC4570 SAHARA SERN: A754BF4A (2807349066) SAHARA PROG: prog_emmc_ufs_firehose_Sdm660_ddr_vivo.elf SAHARA PRID: SA8A4F3B7DBA2CB855 FHPROG SZFT: 4096 FHPROG SZTT: 32768 FHPROG SPTT: 32768 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: MSM8996 FHPROG CHSN: 0x00000000 FHPROG MEMT: eMMC FHINFO Failed: 4, 30 FHPROG PART: EFI GPT FHPROG PRTY: 16 <log value="Binary build date: Oct 19 2017 @ 23:22:01"/> <log value="Chip serial num: 0 (0x0)"/> <log value="Supported Functions: program configure nop firmwarewrite patch setbootablestoragedrive ufs emmc power benchmark read getstorageinfo getsha256digest erase peek poke "/> <data><nop value="ping" /></data> <log value="Binary build date: Oct 19 2017 @ 23:22:01"/> <log value="fh.attrs.Verbose is set to 0"/> <log value="Chip serial num: 0 (0x0)"/> <log value="Supported Functions: program configure nop firmwarewrite patch setbootablestoragedrive ufs emmc power benchmark read getstorageinfo getsha256digest erase peek poke "/> <response value="ACK" /> <data><configure MaxPayloadSizeToTargetInBytes="49152" MemoryName="eMMC" TargetName="8x26"/></data> <log value="Calling usb_al_bulk_set_zlp_mode(TRUE) since ZlpAwareHost='1'"/> <response value="ACK" MinVersionSupported="1" MemoryName="eMMC" MaxPayloadSizeFromTargetInBytes="4096" MaxPayloadSizeToTargetInBytes="49152" MaxPayloadSizeToTargetInBytesSupported="49152" MaxXMLSizeInBytes="4096" Version="1" TargetName="MSM8996" DateTime="Oct 19 2017 - 23:22:01" /> <data><configure MaxPayloadSizeToTargetInBytes="131072" MemoryName="eMMC" TargetName="8x26"/></data> <log value="fh.attrs.MaxPayloadSizeToTargetInBytes of 131072 > fh.channel_buffer_capacity of 49152"/> <log value="Calling usb_al_bulk_set_zlp_mode(TRUE) since ZlpAwareHost='1'"/> <response value="NAK" MinVersionSupported="1" MemoryName="eMMC" MaxPayloadSizeFromTargetInBytes="4096" MaxPayloadSizeToTargetInBytes="49152" MaxPayloadSizeToTargetInBytesSupported="49152" MaxXMLSizeInBytes="4096" Version="1" TargetName="MSM8996" DateTime="Oct 19 2017 - 23:22:01" /> <data><configure ZlpAwareHost="1" SkipStorageInit="0" TargetName="MSM8996" SkipWrite="0" MaxPayloadSizeToTargetInBytes="32768" MemoryName="eMMC"/></data> <log value="Calling usb_al_bulk_set_zlp_mode(TRUE) since ZlpAwareHost='1'"/> <response value="ACK" MinVersionSupported="1" MemoryName="eMMC" MaxPayloadSizeFromTargetInBytes="4096" MaxPayloadSizeToTargetInBytes="32768" MaxPayloadSizeToTargetInBytesSupported="32768" MaxXMLSizeInBytes="4096" Version="1" TargetName="MSM8996" DateTime="Oct 19 2017 - 23:22:01" /> <data><getstorageinfo physical_partition_number="0" /></data> <log value="INFO: Device Total Logical Blocks: 0x747c000"/> <log value="INFO: Device Block Size in Bytes: 0x200"/> <log value="INFO: Device Total Physical Partitions: 0x0"/> <log value="INFO: Device Manufacturer ID: 0x15"/> <log value="INFO: Device Serial Number: 0xf532c877"/> <log value="INFO: {"storage_info": {"total_blocks":122142720, "block_size":512, "page_size":512, "num_physical":4, "manufacturer_id":21, "serial_num":4113746039, "fw_version":"5","mem_typ e":"eMMC","prod_name":&qu ot;DH6DMB"}}"/> <log value="ERROR: SDCC Error 20 (2)"/> <log value="ERROR: Get Raw Info Failed 532"/> <log value="ERROR: Failed to get info raw 1 slot 0, partition 0, error 2"/> <log value="GetStorageInfo Raw Data failed in storage_device_get_info_raw() "/> <log value="ERROR 14: Line 1281: HANDLE_STORAGE_INFO_FAILURE"/> <response value="NAK" /> <data><read SECTOR_SIZE_IN_BYTES="512" num_partition_sectors="2" start_sector="0" physical_partition_number="0" read_back_verify="0"/></data> <response value="ACK" rawmode="true" /> Big Partition: userdata, Will be Wiped First 128 MB FHWIPE DONE: ST 0x0000C0A000 userdata 128 MB Format Flash (1/1) Done in: 00:27.859 |
The Following User Says Thank You to vaterpahk For This Useful Post: |
10-04-2018, 07:42 | #1302 (permalink) |
Member: 757799 Status: Offline Thanks Meter: 782 | SONY Z5 E6653 REMOVE PASSWORD Sony E6653 (Xperia Z5 LTE Sumire) at USB Auto Select [S1] {Write Flash} Files to Flash: 1 GGSOMC, GGSEMC Drivers not Installed -1 All Done in 00:00.000 Sony E6653 (Xperia Z5 LTE Sumire) at USB Auto Select [S1] {Write Flash} Files to Flash: 1 GGSOMC, GGSEMC Drivers not Installed -1 All Done in 00:00.000 Sony E6653 (Xperia Z5 LTE Sumire) at USB Auto Select [S1] {Write Flash} Files to Flash: 1 USB DEV : SOMC [USB\VID_0FCE&PID_ADDE\6&df2ee03&0&3] BL VERS : S1_Boot_MSM8994_LA1.2.3_47 BL PKTSZ: 0x00080000 BL IMEI : 354187-07-432080-2 BL ROOTS: ROOTED TA MODEL: E6653 TA DEVSN: CB5A28UEPN TA CDVER: 1298-7250_R1E TA SWVER: 1295-7444_32.4.A.1.54 TA FLVER: GENERIC_32.4.A.1.54 Loader Boot Done in 00:00.375 FL VERS : MSM8994_41 FL PKTSZ: 0x00400000 FL IMEI : 354187-07-432080-2 TA MODEL: E6653 TA DEVSN: CB5A28UEPN TA CDVER: 1298-7250_R1E TA SWVER: 1295-7444_32.4.A.1.54 TA FLVER: GENERIC_32.4.A.1.54 TA S1VER: 1289-5620 S1_Boot_MSM8994_LA1.2.3_47 TA FTIME: 2018-09-02 19:39:21 AT PLFRT: F421B16FFDD52124A7107C2156B6C478355991BC9D88F0F868 2CD08F127A0FA5 AT OTLCK: LOCKED AT OTDAT: 01000400 AT IDCOD: 109400E1 Writing File: userdata.sin File Write Done in 00:05.678 + 00:23.057 Shut Down Ok All Done in 00:31.824 |
The Following 3 Users Say Thank You to trio1 For This Useful Post: |
10-05-2018, 13:41 | #1303 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Infocus-m370i frp reset done Code: Var INFOCUS-M370I (M370i LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM10) SAHARA VERS: 2.1 SAHARA HWID: 009600E100000000 [MSM8909] SAHARA HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998421ADAD42A380F SAHARA SERN: 009E1546 (10360134) SAHARA PROG: prog_emmc_firehose_8909_ddr_if.mbn SAHARA PRID: SA0697B57FC88514BD FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8909 FHPROG MEMT: eMMC FHINFO DSK0: 15269888 x 512 Sectors (7.28 GB) FHINFO DSK1: 8192 x 512 Sectors (4 MB) FHINFO DSK2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 Reset FRP Done in: 00:00.274 (1) |
10-09-2018, 11:45 | #1304 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Nokia 3 TA-1032 Remove FRP OK ! Nokia TA-1032 (Nokia 3 LTE DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_SWSEC_CRYPTO20_HMD.bin BR ComPort: COM10 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: A4010000 BR Secured: 5 [SBC DAA] DA Version: MTK_AllInOne_DA_v3.3001.00.00. DA ProtVer: 2 PR MMC CID: 484A019061344741334BA532CB618731 [a4GA3] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003AB400000 [15.758.000.128] 14,68 GB eMMC CID : 90014A484147346132A54B33318715CB [HAG4a2] ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : 5DBC1E4AF521CEB5EDEDB7E0FB348597 PMT (GPT) Found: 30 Partition Entries Reset FRP Done in: 00:02.890 |
10-10-2018, 07:30 | #1305 (permalink) |
Member: 757799 Status: Offline Thanks Meter: 782 | sm-g531f frp done Flash Port not Found Samsung SM-G531F (Grand Prime Ve LTE) at USB (COM36) [LOKE FLASH] {Reset FRP} PLATF: LOKE 00020000 PIT Read Done: 00:00 Reset FRP Done in: 00:00.468 Restart Done |
