UFS PANEL 2.3.0.0 and 2.3.0.1 not work in windows 7 64bit Hi like in topic I try install my new UFST on windows 7 64bit and can't. Drivers installed OK Run UFS PANEL and this software not see UFST box in system. I got only 1 device in device manager UFSx and in system all see ok just UFS PANEL not see can you fix this ?? ?? App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft CPU: AuthenticAMD Platform: Windows NT 6.1 (Build 7601 Service Pack 1) Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14 C:\Program Files (x86) C:\Program Files (x86)\Common Files Nokia Path not Found, Set to: C:\Program Files (x86)\Nokia\Phoenix C:\Users\Wojtek\Desktop C:\Users\Wojtek\AppData\Roaming\Microsoft\Windows\ Start Menu\Programs App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft None of Boxes Detected, Use: [Scan Boxes] App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft None of Boxes Detected, Use: [Scan Boxes] After press SCAN BUTTON still same still software not see device and in windows xp all work ok. |
win7 64 bit problame Quote:
yes win7 64bit problame http://imageshack.us/a/img580/6378/0z5y.jpg http://imageshack.us/a/img441/290/59m6.jpg http://imageshack.us/a/img854/9348/ya38.jpg any solution sir |
@wgmmmx1, is it detected on device manager properly? unplug - replug box? |
Man be a normal this section is for UFST no OLD HWK !! !! |
Yes on device manager all ok but UFS PANEL not see it. I try disconnect few times even restart windows and not help on same system UFSx3HWK old box UFS PANEL see correct. But I want install new box on my w7 laptop and becouse this I ask. |
"Old Hwk" Work in Windows 7 64 bits and New Box don't Work!!! LOL Regards |
I am using Win764 though, but it is Intel. Your's is AMD, right? Thanks for reporting, will try to sort it. |
Yes my is AMD APU E350 cpu. |
Hi, All i can do for you that I tell you that its work fine for me and I have Windows7 64bit and I have sony Vaio intel, so the thing i probably did to solve this problem is: 1-exit the panel 2-unplug and plug ufs 3-trying to install support suite(the old) 4-repeat the regular precedure new update from the panel, in order to accomplish missing files. All done. |
ok sir sory post for wrong saction |
MALIK886 working in windows7 64bit just off antivirus Regards |
No is not working with AMD CPU. |
INTEL I7 3770 not work too :) |
all works oki just on 64 bit system need run driver installer (exe) on 32 bit system need show path where is drivers when cable asks |
How do this when drivers tell that this windows language is not supported and close in w7 64bit polish lang? |
