Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 08-03-2013, 10:26   #1 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,228
UFS PANEL 2.3.0.0 and 2.3.0.1 not work in windows 7 64bit
Hi like in topic I try install my new UFST on windows 7 64bit and can't.
Drivers installed OK
Run UFS PANEL and this software not see UFST box in system.
I got only 1 device in device manager UFSx and in system all see ok just UFS PANEL not see can you fix this ?? ??
App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft
CPU: AuthenticAMD
Platform: Windows NT 6.1 (Build 7601 Service Pack 1)
Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14
C:\Program Files (x86)
C:\Program Files (x86)\Common Files
Nokia Path not Found, Set to: C:\Program Files (x86)\Nokia\Phoenix
C:\Users\Wojtek\Desktop
C:\Users\Wojtek\AppData\Roaming\Microsoft\Windows\ Start Menu\Programs
None of Boxes Detected, Use: [Scan Boxes]
After press SCAN BUTTON still same still software not see device and in windows xp all work ok.
The Following 6 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 08-03-2013, 10:34   #2 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,689
Exclamation win7 64 bit problame
CPU: AuthenticAMD
yes win7 64bit problame
any solution sir
The Following User Says Thank You to .::THE ROCK::. For This Useful Post:
Old 08-03-2013, 11:22   #3 (permalink)
Member: 4566
Sonork: 100.112355
Thanks Meter: 501
@wgmmmx1,
is it detected on device manager properly? unplug - replug box?
The Following User Says Thank You to ren77 For This Useful Post:
Old 08-03-2013, 11:29   #4 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,228
Originally Posted by MALIK886 View Post
[CENTER]
any solution sir
Man be a normal this section is for UFST no OLD HWK !! !!
Old 08-03-2013, 11:33   #5 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,228
Originally Posted by ren77 View Post
@wgmmmx1,
Yes on device manager all ok but UFS PANEL not see it. I try disconnect few times even restart windows and not help on same system UFSx3HWK old box UFS PANEL see correct.
But I want install new box on my w7 laptop and becouse this I ask.
The Following User Says Thank You to wgmmmx1 For This Useful Post:
Old 08-03-2013, 11:40   #6 (permalink)
Haicha's Avatar
Member: 330579
Thanks Meter: 47,146
"Old Hwk" Work in Windows 7 64 bits and New Box don't Work!!! LOL
Regards
The Following User Says Thank You to Haicha For This Useful Post:
Old 08-03-2013, 11:47   #7 (permalink)
Member: 4566
Sonork: 100.112355
Thanks Meter: 501
I am using Win764 though, but it is Intel.
Your's is AMD, right?
Thanks for reporting, will try to sort it.
Old 08-03-2013, 11:59   #8 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,228
Yes my is AMD APU E350 cpu.
Old 08-03-2013, 14:00   #9 (permalink)
Member: 1721899
Thanks Meter: 39
Hi, All i can do for you that I tell you that its work fine for me and I have Windows7 64bit
and I have sony Vaio intel, so the thing i probably did to solve this problem is:
1-exit the panel
2-unplug and plug ufs
3-trying to install support suite(the old)
4-repeat the regular precedure new update from the panel, in order to accomplish missing files.
All done.
The Following User Says Thank You to omarb1989 For This Useful Post:
Old 08-03-2013, 15:13   #10 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,689
ok sir sory post for wrong saction
Old 08-04-2013, 21:52   #11 (permalink)
S.Leo's Avatar
Member: 485779
Thanks Meter: 127
MALIK886
working in windows7 64bit just off antivirus
Regards
The Following User Says Thank You to S.Leo For This Useful Post:
Old 08-04-2013, 22:32   #12 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,228
No is not working with AMD CPU.
Old 08-08-2013, 04:31   #13 (permalink)
xiaoyuz's Avatar
Member: 76767
Sonork: 100.1594567
Thanks Meter: 1,091
INTEL I7 3770 not work too
Old 08-08-2013, 04:37   #14 (permalink)
Member: 904530
Thanks Meter: 513
all works oki
just on 64 bit system need run driver installer (exe)
on 32 bit system need show path where is drivers
when cable asks
Old 08-08-2013, 06:26   #15 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,228
Originally Posted by Major-T View Post
all works oki
when cable asks
How do this when drivers tell that this windows language is not supported and close in w7 64bit polish lang?
Page generated in 0.38140 seconds with 8 queries
