08-08-2013, 08:00 | #19 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | You are sure we speak about NEW UFS_TURBO BOX not old one ?? Old one like ufsx3, n-box, twister etc work ok in w7 64bit JUST NEW BOX UFST not working. And we speaking here about laptop or computer with AMD CPU no INTEL. |
08-08-2013, 20:28 | #21 (permalink) |
No Life Poster Join Date: Nov 2006 Location: poland krakow
Member: 389207 Status: Offline Thanks Meter: 61 | I have similar problem Like wgmmmx1 ufs panel dont recognize ufst but device manager saw correctly install driver for ufst . Curious bkoz i have win7 home ed ..... X86 32bit with intel tommorow i will paste scrnshot. Regards |
08-10-2013, 08:34 | #25 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Yes I run with admin and without nothing change. I will write one more time OLD BOX UFSx3 on same system same computer working correct then 100% something with UFS PANEL or with drivers. |
08-11-2013, 14:03 | #26 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 432 | install the drivers manually. Device manager, you get the box with exclamation mark, right click, update driver, manual install not automatic, copy path where driver .inf for 64bit, will install. need to confirm (big red warning) because drivers are not digitally signed I had the language not supported also and used manual install to get it working. Br |
08-14-2013, 14:47 | #28 (permalink) |
Freak Poster Join Date: May 2006 Location: Slovakia
Member: 272319 Status: Offline Thanks Meter: 99 | Same here, box not found. Previous support suite/hwk suite detect and works with box normally. PC: WIN 7 - 32BIT, Intel CPU, UFS-3 tornado Code: App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft CPU: GenuineIntel Platform: Windows NT 6.1 (Build 7601 Service Pack 1) Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix C:\Users\erik\Desktop C:\Users\erik\AppData\Roaming\Microsoft\Windows\Start Menu\Programs App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft None of Boxes Detected, Use: [Scan Boxes] Last edited by janda; 08-14-2013 at 14:55. |
08-14-2013, 14:50 | #29 (permalink) | |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
Why you write about OLD HWK box in NEW BOX UFST section ?? If you write in bad section this is normal that noone will answer you correctly about your problem !! THIS SECTION IS ONLY FOR NEW UFST BOX USERS NO OLD ONE !! !! !! | |
08-14-2013, 15:13 | #30 (permalink) |
Member: 272319 Status: Offline Thanks Meter: 99 | oops sorry, but problem is the same, device not detected, i things that programmer is same person, peace On my pc with old box new version works normally. The problem relates to friend's box. Only drivers are not the same, he uses new, i am using Versions: Ufs2xx.dll 3.1.19, Ufs2xx.sys 2.6.0 |
