09-08-2013, 13:52 | #46 (permalink) |
Freak Poster Join Date: Mar 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 716661 Status: Offline Thanks Meter: 19 | good luck reg h4in |
09-08-2013, 17:13 | #47 (permalink) | |
Junior Member Join Date: May 2008 Location: Mactan Lapu2x Cebu PHILIPPINE
Member: 782484 Status: Offline Sonork: Ding Thanks Meter: 17 | Quote:
it need to run by admin in XP sp3 mode look at the defference OS windows 7 {home basic , Home Premium, Professional & ultimate} http://windows.microsoft.com/en-PH/w...mpare#T1=tab01 only Professional & ultimate have XP SP3 MODE can run admin look at this post By kerug-bali he's done successfully by used AMD Phenom™ Processor & OS winndows 7 Ultimate 64bit hope it will help for you Last edited by drcool33; 09-08-2013 at 17:20. | |
09-08-2013, 17:29 | #48 (permalink) |
Member: 782484 Status: Offline Sonork: Ding Thanks Meter: 17 | is it used windows 7 Ultimate? if not try use OS Windows 7 ULTIMATE either 32 BIT OR 64BIT it need to run by admin in XP sp3 mode look at the defference OS windows 7 {home basic , Home Premium, Professional & ultimate} Compare Windows 7 - Microsoft Windows only Professional & ultimate have XP SP3 MODE can run admin look at this post By kerug-bali he's done successfully by used AMD Phenom™ Processor & OS winndows 7 Ultimate 64bit hope it will help for you |
The Following User Says Thank You to drcool33 For This Useful Post: |
10-10-2013, 15:26 | #50 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | From UFS PANEL 2.3.0.2 and new drivers all working correct in all system(without windows 8 64bit that need sighned drivers) topic should be closed. |
02-06-2014, 06:33 | #57 (permalink) |
Freak Poster Join Date: Dec 2012 Location: chinnasalem tamilnadu india
Member: 1849338 Status: Offline Sonork: 100.1646373 Thanks Meter: 89 | All boxes are working fine in windows 7 windows 8 and windows 8.1. Mx key volcano box in windoes 7 only ufst hwk box spt box miracle box |
