07-17-2017, 06:14 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | UFST - ANDROID UFS 1055 Test16 COMMON Minor Bug's Fixed in File and Model Selection. INI File saving time decreased. ALCATEL More Alcatel Models Added (Including QualComm Sahara): 6014D, 6014X, 6050A, 6050F, 6050W, 6050Y, 7043A, 7043E, 7043K, 7043Y, 7044A, 7044X, 7044Y, 7053D, 7053E, 7053J, VF-895N FASTBOOT Fixed Flashing of Devices with v0.4 fastboot core (Nvidia, Blackphone BP1) Reboot Mode Selector: Normal, Bootloader, EDL, Recovery (if Device Supports) HUAWEI More Huawei Models Added: ATH-TL00, ATH-UL00, G620-L72, G620-L75, G629-UL00, G730-U30, H30-C00, S8-701U, SC-CL00, VNS-AL00 LENOVO More Lenovo Models Added: A8-50LC, A2016a40, A2016b30, A2016b31, A2800-D, A3860, A3910e70, A3910t30, A5890, A6010+, A6020a41, A6020L36, A6020L37, A6600a40, A6600d40, A7010a48, A7700, B8080-F, B8080-H, B8080-HV, K10a40, K10e70, K30-E, K30-TM, K31-T3, K50-T3s, K51c78, K910E, K910L, K910SS, PB2-650M, PB2-670M, PB2-690M, S1La40, S856, TB3-730F, TB3-730X, TB3-850F, TB3-850M, TB3-8703F, TB3-8703X, TB3-X70F, TB3-X70L, YT-X703F, YT-X703L, YT-X703X LG More LG Models Added: AS993, F770S, F820L, G600K, G600L, G600S, G600V, H870, H870DS, H870K, H870S, H870V, H871, H872, H873, K371, K373, LS450, LS775, LS993, M150, M151, M153, M154, M160, M160E, M250AR, M250F, M250H, M250I, M250K, M320, M320AR, M320DSN, M320F, M320H, M320K, M320N, M320TV, M320Y, M400DF, M400DK, M400DY, M400F, M400MT, M400N, M400Y, MP260, MS210, TP260, US997, VS501, VS835, VS988, X130G, X130J, X132, X135, X137, X145, X147, X150, X155, X160, X165, X165G, X170G, X210MB, X220DSH, X220DST, X220M, X220MB MICROMAX More Micromax Models Added: AQ4750, C1, E451, E453, E485, E491, E4820, P701, P702, P70221, P802, Q310, Q346+, Q354, Q402, Q453, Q3301, Q3501, Q3555, Q4202, Q4220, Q4251, Q4260, Q4310, V51 MOTOROLA More Motorola Models Added: XT1670, XT1671, XT1672, XT1675, XT1676, XT1677 (Moto G5 Cerdic) XT1680, XT1681, XT1683, XT1684, XT1685, XT1687 (Moto G5 Plus Potter) XT1750 (Moto C 3G Watson) Enabled [Reset FRP], Use [ADB Mode (via Menu...)], ADB Must be Enabled. To Enable ADB use Trick with *#*#4636#*#*, Aptoide and Test_dpc_smart_manager. MTK [Format Flash] Function Added. Format (Erase) Can be Done by Linear Address or Partition Name. [Read Flash] Preloader Analysis and Extraction (to SPFL Format) Added. Preloader now is saved as 2 Files: preloader_partition.bin (Whole Partition), Flashable by UFST and preloader_blabla.bin (Extracted SPFL File), Flashable by Original SPFL. Blocked Write of not Correct Preloader File (Must be in Partition Format) [Factory Info] will show Unlock Keys in Meta Mode (If is Allowed) NOKIA More Nokia Models Added: Nokia 3 (NE1, TA-1020, TA-1028, TA-1032, TA-1038) RM-1013 Sahara Flashing. QC (QUALCOMM) Added Programer (FireHose) File Selection using [Add File] it will override Default or selected by [DA] File and allows to save into INI File. SAMSUNG [Add MSL] Function Added (To Store Factory MSL into Local DataBase) Fixed new models Failure while flashing HOME Files (meta-data) More Samsung Models Added: C5018, C7018, C701F, C9008, C900Y, G390Y, G891A, G930VL, G9500, G9508, G950F, G950N, G950U, G950U1, G950W, G9550, G955F, G955N, G955U, G955U1, G955W, J326AZ, J327A, J327AZ, J327R4, J327R6, J327R7, J327T, J327T1, J327U, J327V, J327VPP, J330F, J330FN, J330G, J530F, J530FM, J530G, J530GM, J530K, J530L, J530S, J530Y, J701F, J701M, J727A, J727R4, J727S, J727T, J727T1, J727U, J727V, J727VPP, J730F, J730FM, J730G, J730GM, N935K, N935L, N935S, S120VL, S320VL, S550TL, S820L, SC-02J, SC-03J, SC-04J, SCV35, SCV36, T825N0, T825Y, T827, T827R4, T827V SONY Increased Image Write time-out from 5mins to 10mins, to prevent error -2 at 99% for hughe (system) files. Fixed Flashing of Models without loader.sin files. Enabled [Reset FRP], Use [ADB Mode (via Menu...)], ADB Must be Enabled. To Enable ADB use Trick with QuickShortcutMaker.apk or other. More Sony Models Added: SO-02J (Xperia X Compact Kugo) SO-01J, SOV34, 601SO (Xperia XZ Kagura) G3112, G3116, G3121, G3123, G3125 (Xperia XA1 Hinoki) G3212, G3221, G3223, G3226 (Xperia XA1 Ultra Redwood) G3311, G3312, G3313 (Xperia L1 Pine) G8231, G8232, SO-03J, SOV35, 602SO (Xperia XZs Keyaki) SPRD (SPREADTRUM) More Sophistcated Boot Options: Now can Boot, by Selecting FDL1 and FDL2 Using [Add File] or [DA] Button, FDL Selection Order: PAC File, File from List [Add File] and Default by [DA] Choosing with [Add File] Allows save into INI (Individual for each model). Read Mode Selector Lets Auto-Read Files from Unknown Model. [Format Flash] Function Added. Format (Erase) Can be Done by Partition Name. VAR MTK ACER Models Added: Liquid Z6E, Liquid Zest 4G AMOI Models Added: L350, L760C ARK Models Added: Benefit M505, Benefit M506, Benefit M507, Benefit S503 BLACKVIEW Models Added: A5, A7, A8, A8 Max, A9, A9 Pro, Alife P1 Pro, Alife S1, Breeze, BV2000, BV2000s, BV5000, BV6000s, BV7000s, C1, E7, E7s, Heatwave, JK450, JK600, JK606, JK890, Omega Pro, P2 Lite, R6, R6 Lite, R6s, Ultra, Ultra Plus, V3 CONDOR Models Added: Griffe G4, Griffe G4+ CHERRY Models Added: Cosmos 3, Cubix Cube 3, Flare 4, Flare 5, Flare HD Max, Flare Infinity Lite, Flare J1 Plus, Flare J3, Flare J3 Plus, Flare J5, Flare J7, Flare P1, Flare P1 Plus, Flare S, Flare S4, Flare S4 Max, Flare S4 Plus, Flare S5, Flare S5 Plus, Flare S5 Power, Flare Selfie, Flare X, H7, Touch 2, Touch XL2 COOLPAD Models Added: 3503I (Mega 3), 3505I-S00 (Fancy 3), 8722-S00 (Roar Plus E570), 8722-U00 (Porto S E570), Y83-S00 (Sky 3 E502), Y83-U00 (Modena 2 E502) DISCOVERY Models Added: V8 DOOGEE Models Added: T3, T5, T5 Lite, T6, T6 Pro, X3, X5, X5 b, X5 Max, X5 Max Pro, X5 Max S, X5S, X6, X6 Pro, X6S, X7, X7 Pro, X7S, X9, X9 Pro, X9S, Y100X EVERTEK Models Added: EverAllure 2, EverFancy, EverFancy 3, EverGlory 2, EverGlory Plus, EverGlow D35, EverGlow D40, EverGlow D50, EverMellow D45, EverMellow D50, EverMiracle Mini, EverMiracle Nano, EverMiracle Plus, EverMiracle Power, EverMiracle S, EverMiracle S2, EverShine 2, EverShine Plus, EverSlim Nano, EverSolo, EverStar D40, EverStar Nano, EverStar Pro, EverStar Pro V2, EverStar Q40, EverStar Q50, EverStar S, EverTrendy, EverTrendy Plus 3G, EverTrendy Plus 4G, EverVivid Q47, F1, V1 Mini GIONEE Models Added: Elife S Plus, F103, F103B, F103BL, F103L, F105, F301, F303, F306, F306L, GN3003L, GN5001L, GN5001S, GN5002, M3 Mini, M5 Plus L, M5 Mini, S6, S6S INNJOO Models Added: Fire 3G, Fire 2 3G, Fire 2 LTE, Fire 2 Plus LTE, Fire 3 LTE, Fire 3 Air LTE, Fire Plus LTE, Fire Pro LTE, Halo LTE, Halo 2 LTE, Halo Plus, i1, i1k, i1s, Max, Max 2 3G, Max 2 Plus 3G, Max 3 3G, Max 3 LTE, Max 3 Pro, Note, Note E, Note Pro, One HD LTE, Pro, Two LTE INTEX Models Added: Aqua HD 5.5, Aqua Play, Aqua Ring, Aqua S7, Aqua Shine 4G, Aqua Power Pro, Aqua Pride, Prime 4G, Aqua Strong 5.1, Aqua Strong 5.2, Aqua Supreme+, Aqua Trend Lite, Aqua View, Aqua Y2 Pro, Cloud Q11 KARBONN Models Added: K9 Smart 4G LAVA Models Added: A2, A3, Iris 820 MX, Z10 LYF Models Added: LS-5506 Water 9, LS-5507 Water 7 PHILIPS Models Added: S226M, S309, S318, S388, S396, S398, S616, V377, V387, V526, V586, V787, X586 QMOBILE Models Added: Z10, Z12, Z12 Pro, Z9 Plus TEXET Models Added: TM-4071, TM-4072, TM-4082, TM-4083, TM-4172, TM-4182, TM-4272, TM-4510, TM-4513, TM-4515, TM-4572, TM-4672, TM-4772, TM-4782, TM-4872, TM-4972, TM-4982, TM-5003, TM-5005, TM-5009, TM-5010, TM-5011, TM-5017, TM-5072, TM-5082, TM-5172, TM-5503, TM-5505, TM-5508, TM-5513, TM-5577, TM-6003 VODAFONE Models Added: VFD300, VFD301, VFD500, VFD501, VFD502 ZTE Models Added: Blade L3 Lite, Blade V7 Lite, Blade X7, Nubia N1 Lite, S158, T520, Voyage 4S VAR QUALCOMM BLACKPHONE Models Added: BP2 COOLPAD Models Added: 3600I (Note 5), 8297-A, 8297-W00 (Dazen F2), A8-930, A8-I01 (Max A8), SK3-S00 (Fancy E561), SK3-U00 (Torino S E561), Y76-I01 (Sky E501), Y76-U00 (Modena E501), Y90-G00 (Shine R106), Y91-I00 (Note 3S), Y91-U00 (Torino R108) INTEX Models Added: Aqua 4G, Aqua Fish, Elit-E1 HAIER Models Added: Esteem L50, L61, Leisure L7 LYF Models Added: LS-5005 Water 4, LS-5007 Water 5, LS-5502 Wind 3, LS-5505 Water F1 OPPO Models Added: A11, A57, R8000, R9s, R9s Plus, X9000 VODAFONE Models Added: VFD900 XIAOMI Models Added: Mi Max 2 Oxygen VAR SPRD ARCHOS Models Added: 40 Neon, 50C Platinum, 50D Titanium CHERRY Models Added: Flare J1, Flare J1S, Flare Lite 2, Flare Lite Quad, Flare P1 Mini, Flare P1 Lite, Flare S5 Mini, Omega Lite 2, Touch HD EVERTEK Models Added: V1 Nano INNJOO Models Added: Halo 3G, Halo 2 3G, Halo Plus, Halo X INTEX Models Added: Aqua 4.0 3G, Aqua 4.0 4G, Aqua 4.5 Pro, Aqua 4G Mini, Aqua_Amaze+, Aqua Craze 2, Aqua Lions 4G, Aqua Q7N Pro, Aqua Pro 4G, Aqua Raze 2, Aqua S3, Aqua Selfie, Aqua Strong 5.1+, Aqua Style 3, Y2 Power, Cloud 4G Smart, Cloud M5 II, Cloud Matte, Cloud Scan FP, Cloud String HD LAVA Models Added: A50, A55 PHILIPS Models Added: S326, S337 TEXET Models Added: TM-4003, TM-4503, TM-5006, TM-5007, TM-5016 for UFST and UFS Turbo Only. Download link - https://www.4shared.com/archive/ipol...55_Test16.html |
The Following 10 Users Say Thank You to srinibas For This Useful Post: |
07-17-2017, 07:07 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Test 16 ABD reading Done Quote:
BOOTSERN: 0123456789ABCDEF Thanks It will be a big help i have many phones with this king of Error | |
07-17-2017, 09:00 | #4 (permalink) |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | This is the info i got MTK MT6572 (eMMC) at META {Factory Info} Insert Cable to Switched OFF Device BR USB Com: Vid_0e8d&Pid_2000 ME USB Com: Vid_0e8d&Pid_2007 ME_MCUID: MT6572,S01 ME_MODEL: ALPS.JB3.MP.V1.P146 ME_BLDAT: 2014 06 26 17:08:35 CST ME_CHIPS: MT6572, E01 ME_DSPFW: 2000.00.00 ME_DSPPT: 1.0 ME_BOARD: TINNO72_WET_JB3_GPRS_HW ME_SWVER: MOLY.WR8.W1315.MD.WG.MP.V1.P9 ME_MLVER: Unknown ME_SERNR: LI401428114299 10 ME_IMEI1: 352331-06-318120-3 ME_SIML1: NCK : 12345678 NSCK: 56781234 SPCK: 11112222 CCK : 33334444 SIM : 55556666 |
07-17-2017, 09:04 | #5 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | So Barcode (ME_SERNR) is Ok. At the moment, I not catch from where Chinese MTK phones have BOOTSERN: 0123456789ABCDEF I see many with this number. Normal phones puts here a eMMC Serial Number Ok, i will investigate that problem, if is not a Chinese manufacturers bug aka Chinese Simplified ... |
07-17-2017, 09:19 | #6 (permalink) |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | we can normally get this error after we process format download option on SPF tool since i just got my UFST last year i use the free flash tool for mtk after format download option we commonly got this error IMEI invalid after that this BOOTSERN: 0123456789ABCDEF will show |
07-18-2017, 10:53 | #7 (permalink) |
Freak Poster Join Date: Jan 2016 Age: 34
Member: 2516015 Status: Offline Thanks Meter: 100 | Many models and names , why dont you just do it like infinity team and sort it by CPU , it will be more elegant , please add support for nokia mtk . Thank you Kings . Sent from my A1601 using Tapatalk |
07-18-2017, 11:00 | #8 (permalink) | |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Quote:
More Nokia Models Added: Nokia 3 (NE1, TA-1020, TA-1028, TA-1032, TA-1038) RM-1013 Sahara Flashing. QC (QUALCOMM) Added Programer (FireHose) File Selection using [Add File] it will override Default or selected by [DA] File and allows to save into INI File. most of nokia models is supported already more models with each DA means accurate data process so better to have each model than use generic method. | |
07-18-2017, 11:12 | #10 (permalink) |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | in DCTX most of MTk based phone is supported already... V 2.3.0.2 ----------- 4. DCT4 MTK Based Products UI support added: RM-944,RM-945 (108) 5. Windows8 64bit support. |
07-18-2017, 13:56 | #12 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | @DZcondor "Many models and names , why dont you just do it like infinity team and sort it by CPU , it will be more elegant , please add support for nokia mtk . Thank you Kings ." You already have selection by MCU in MTK, QC, SPRD Tabs. Model Selection, chooses for you download agents and other model specific settings, like FRP parms, Diags Enable method and many other things ... So if you not like Model selection, use by MCU, but need choose loaders by yourself. And do not say is not done by CPU, just look closer to software at first. |
07-19-2017, 12:49 | #15 (permalink) |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Do you have any idea how to fix this? Var CHERRY-Flare S4 (Flare S4 LTE DS) at USB Auto Select [MTK] {Write Flash} Scatter : MT6753_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_0003 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM6 BR Asic Id: MT0337 [0000] >> MT6735 BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 524E011336394A31CF54104E3D3BEEC0 [69J1] PR Version: 4.2 [0x9B] (5) MT6737T DRAM Confg: 13014E52314A39364E1054CFC0EE3B3D DRAM PreLd: preloader_n325bh.bin DRAM ConVs: 20 DRAM ENABLE ERROR: No Settings for Device: 69J1 PR_LOADER_CNF Error: -204, 5 BR_BOOT Error: -15 Flashing Canceled DA_SHUTDOWN Error: -3 |
