07-10-2018, 00:03 | #1 (permalink) |
Major Poster Join Date: Feb 2018
Member: 2809978 Status: Offline Sonork: WWW.SONOROK.COM Thanks Meter: 3 | ufst eror flash ichery c216.. SPRD SC7731 (eMMC) at USB Auto Select [SPRD] {Write Flash} File TMP_SC77xx.xml No.of Operations 5 (5 Byte) Error Need Select PAC File Using [FH] Button in [Flashing] Tab Or Select FDL1 and FDL2 Files Using [Add File] Button in [Flashing] Tab or [DA] SPRD SC7731 (eMMC) at USB Auto Select [SPRD] {Write Flash} File r1031_7731g_xwx_g1_icherry.pac Vers r1031_7731g_xwx_g1_icherry_5u`lf~OS_userdebug No.of Operations 26 (1.12 GB) BOOT FDL1 and FDL2 from .pac File Hold Vol+, Vol- and Insert Cable to Switched OFF Device Bad Port COM20 SPRD SC7731 (eMMC) at USB Auto Select [SPRD] {Write Flash} File r1031_7731g_xwx_g1_icherry.pac Vers r1031_7731g_xwx_g1_icherry_5u`lf~OS_userdebug No.of Operations 26 (1.12 GB) BOOT FDL1 and FDL2 from .pac File Hold Vol+, Vol- and Insert Cable to Switched OFF Device SROM SPRD3 FDL1 Spreadtrum Boot Block version 1.1 FDL2 Ok, 96 Write prodnv 5 MB, Done in 0001.182 Erase uboot 1024 KB, Done in 0000.126 Write splloader 31 KB, Done in 0000.176 Write wmodem Failed WRITE_MIDST 0x00A41000 Last USB Exception 0x0016 The device does not recognize the command. |
07-31-2018, 11:42 | #3 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1596913 Status: Offline Thanks Meter: 107 | Restore the memory layout of the program FactoryDownload FACTORYDOWNLOAD_R19.17.4301_P1 Then through ResearchDownload. |
07-31-2018, 12:03 | #4 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Can Restore Layout with UFST, only Check [Re-Partition] Option ... Always Read Tips while Mouse moving over controls. |
The Following User Says Thank You to Sha For This Useful Post: |
08-01-2018, 04:36 | #5 (permalink) |
Member: 2809978 Status: Offline Sonork: WWW.SONOROK.COM Thanks Meter: 3 | error repartitioin.. SPRD SC7731 (eMMC) at USB Auto Select [SPRD] {Write Flash} File: r1031_7731g_xwx_g1_icherry.pac Vers: r1031_7731g_xwx_g1_icherry_5u`lf~OS_userdebug No.of Operations: 26 (1.12 GB) BOOT: FDL1 and FDL2 from .pac File Hold Vol+, Vol- and Insert Cable to Switched OFF Device Flash Port not Found SPRD SC7731 (eMMC) at USB Auto Select [SPRD] {Write Flash} File: r1031_7731g_xwx_g1_icherry.pac Vers: r1031_7731g_xwx_g1_icherry_5u`lf~OS_userdebug No.of Operations: 26 (1.12 GB) BOOT: FDL1 and FDL2 from .pac File Hold Vol+, Vol- and Insert Cable to Switched OFF Device Flash Port not Found SPRD SC7731 (eMMC) at USB Auto Select [SPRD] {Write Flash} File: r1031_7731g_xwx_g1_icherry.pac Vers: r1031_7731g_xwx_g1_icherry_5u`lf~OS_userdebug No.of Operations: 26 (1.12 GB) BOOT: FDL1 and FDL2 from .pac File Hold Vol+, Vol- and Insert Cable to Switched OFF Device SROM: SPRD3 FDL1: Spreadtrum Boot Block version 1.1 FDL2: Ok, 96 ACK_ERR: No Response Repartition Failed: REPART_START FF Restart Failed: FDL FINISH |
