11-25-2017, 11:12 | #106 (permalink) | |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Quote:
QDL USB Com: Vid_05c6&Pid_9008 (COM49) Flash Bundle: Rawprogram0_sparsed.xml SAHARA VERS: 2.1 SAHARA HWID: 008110E100000000 [MSM8210] SAHARA HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F SAHARA SERN: 00D52165 (13967717) SAHARA PROG: prog_emmc_firehose_8x10_hua1.mbn FHPROG SZFT: 4096 FHPROG SZTT: 49152 FHPROG SPTT: 49152 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8x10 FHPROG MEMT: eMMC FHINFO PAR0: 15269888 x 512 Sectors (7.28 GB) Default FHINFO PAR1: 8192 x 512 Sectors (4 MB) Default FHINFO PAR2: 8192 x 512 Sectors (4 MB) Default FHPROG PART: EFI GPT FHPROG PRTY: 4 Partitions to Write: 15 (1.29 GB) FWRITE DONE: ST 0x0000000022 sbl1 289.42 KB FWRITE DONE: ST 0x0000000422 sdi 18.19 KB FWRITE DONE: ST 0x0000004000 rpm 143.54 KB FWRITE DONE: ST 0x00000043E8 tz 322.73 KB FWRITE DONE: ST 0x00000047D0 aboot 582.61 KB FWRITE DONE: ST 0x000002C000 modem 35.18 MB FWRITE DONE: ST 0x0000090000 persist 8 MB (Unsparsed Size) FWRITE DONE: ST 0x0000094000 boot 10.75 MB FWRITE DONE: ST 0x000009A000 recovery 11.84 MB FWRITE DONE: ST 0x00000A2000 cust 256 MB (Unsparsed Size) FWRITE DONE: ST 0x0000122000 cache 5.6 MB FWRITE DONE: ST 0x0000184000 system 999.82 MB FWRITE DONE: ST 0x0000384000 userdata 18.44 MB FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB FWRITE DONE: ST 0x0000000021 BackupGPT 16.5 KB FPATCH DONE: 13 FHSETD DONE: Ok FHREST DONE: Ok Write Flash Done in: 05:40.761 this is the surest 100% correct firmware | |
11-25-2017, 11:22 | #107 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Sorry I don't know why it works, but is not 100% correct file Have few bad Sparse flags. Here is correct file: https://www.4shared.com/archive/pb0e...10_V100R0.html Please try again. ... Last edited by Sha; 11-25-2017 at 11:46. |
11-25-2017, 11:54 | #108 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Var WIKO-V3720 (Lenny4 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_1640_TRUNK_01.bin BR ComPort: COM73 BR Asic Id: MT6580 [0000] BR Asic Sw: 8A00 CA00 0000 0000 BR Secured: 1 [SBC] DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 150100464536324D4203F596E4998433 [FE62MB] PR Version: 4.2 [0x9C] (7) MT6580 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000003A3E00000 [15.634.268.160] eMMC CID : 150100464536324D4203F596E4998433 [FE62MB] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 0C71A79DBF73579754FF4029297967AB PMT (GPT) Found : 25 Partition Entries Reset FRP Done in: 00:05.901 DA Shutdown Done, Disconnect Cable use same boot for lenny4plus |
11-28-2017, 11:35 | #109 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1019757 Status: Offline Sonork: [email protected] Thanks Meter: 9 | model g530h issue emegency calls only cert pass in *#0011# , need to patch cert or repair network in other devices like Z3X , it is not cert issue cert is ok . i try genral setting in ufsT , but this error came always , i tried many time on many samsung phones with ufsT but not get success , after full flash also failed , i try with rj45 cable and with usb cable , also tried in ufst android setup , PLZ how to do this job with ufsT SM-G530H at RJ45 (UART) [MODEM] Bad MSLA (Device not Fully Booted, Wait & try Again or Reconnect) Or Device Modem Supports only UART (Use RJ45 Connection) COM129: SAMSUNG Mobile USB Modem #41 COM130: SAMSUNG Mobile USB Serial Port (COM130) SM-G530H at USB (COM129) [MODEM] IMEI: 536970-60-******-5 PREC: XXV [Vietnam] Bad MSLA (Device not Fully Booted, Wait & try Again or Reconnect) Or Device Modem Supports only UART (Use RJ45 Connection) |
11-28-2017, 14:36 | #110 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | LG MS210 (Aristo MetroPCS) at Auto Select Flash Port [LG FLASH 5] {Reset FRP} DL MODE : 2 DL REQM : 5 DL MODEL: LGMS210 DL SWVER: MS21010h DL IMEI : 000000-00-000000-0 LF MODEL: LGMS210 LF SERNO: LGMS210dc22d054 LF SWVER: LGMS210AT-02-V10h-310-160-MAR-16-2017-ARB00+1 LF MINOS: MiniOS 3.0 LF OSVER: 7.0 LF IMEI : 358772-08-411996-7 LF DVPID: CH32S170508016503 LF SOCTY: msm8937 LF CABLE: 633A LAF_ERASE Failed: -5 Reset FRP Not Done LEAVE LAF Command Interface Closed |
12-06-2017, 00:06 | #111 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | SOME CPB SHOWS ERROR FILES WORKING OK AND NOT DAMAGED.. EXTRACTION SHOWS BAD.. PLZ CHECK |
The Following User Says Thank You to johnoroo37 For This Useful Post: |
12-07-2017, 22:48 | #112 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2005 Location: Colombia
Member: 142645 Status: Offline Sonork: 100.1604204 Thanks Meter: 239 | Help error Code: App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft CPU: AuthenticAMD Platform: Windows NT 6.2 (Build 9200 ) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix C:\Users\covvvva\Desktop C:\Users\covvvva\AppData\Roaming\Microsoft\Windows\Start Menu\Programs Can't open internet URL. InternetOpenURL failed! Can't open internet URL. InternetOpenURL failed! Can't open internet URL. InternetOpenURL failed! |
12-12-2017, 13:59 | #113 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | LG M400DY (Stylus 3 LTE DS) at Auto Select Flash Port [LG FLASH 69] {Reset FRP} DL MODE : 2 DL REQM : 5 DL MODEL: LG-M400DY DL SWVER: M40010d DL IMEI : LF MODEL: LG-M400DY LF SERNO: LGM400BELZIZFEB6US LF SWVER: LGM400DYAT-00-V10d-AME-XX-SEP-18-2017+0 LF MINOS: MiniOS 3.0 LF OSVER: 7.0 LF DVPID: VS04S170405002722 LF SOCTY: mt6750 LF CABLE: 910K Reset FRP Not Done LEAVE LAF Command Interface Closed |
12-15-2017, 14:45 | #115 (permalink) |
Member: 2025428 Status: Offline Thanks Meter: 445 | ALL QUALCOMM PHONES I CONNECT TO READ FIRMWARE ALWAYS SHOWS THIS SAME ERROR PLZ WHAT IS WRONG. EVEN IF I RESTART MY PC RUN ONLY UFST .STIL SAME TRIED ON THREE PC STILL SAME ERROR.. PLZ FIX IT SEE PICS BELOW IT WILL READ AND ALWAYS STOP SOMEWHERE DURING READING.. CABLES IS NOT D FAULT..CABLE IS WORKING WITH OTHER TOOLS WITH SAME PHONES.. SUGGESTION:::::: BELOW 1.MAYBE EXE SHOULD ASK USER WHERE TO SAVE READED FIRMWARE. 2.MAYBE SPPED IS ALSO TOO HIGH DURING READING ..SOMETHING LIKE THAT... JUST IDEAS. Last edited by johnoroo37; 12-15-2017 at 14:52. |
12-23-2017, 23:49 | #116 (permalink) | |
01-29-2018, 23:25 | #118 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | SPRD SC7731 (eMMC) at USB Auto Select [SPRD] {Write Flash} File: A1000_USR_S30268_1606282028_SPRD7731_ROW.pac Vers: A1000_USR_S30268_1606282028_SPRD7731_ROW No.of Operations: 27 (2.46 GB) BOOT: FDL1 and FDL2 from .pac File Hold Vol+, Vol- and Insert Cable to Switched OFF Device SROM: SPRD3 FDL1: Spreadtrum Boot Block version 1.1 FDL2: Ok, 96 Read wfixnv1 163.04 KB, Done in: 00:00.344 Saved as: NVBACKUP [2018_01_30_01_13_58] TY_03_PT_wfixnv1.bin Read wfixnv2 163.04 KB, Done in: 00:00.135 Saved as: NVBACKUP [2018_01_30_01_13_58] TY_03_PT_wfixnv2.bin Write wfixnv1 163.04 KB, Done in: 00:00.291 Read wcnfixnv1 2.53 KB, Done in: 00:00.089 Saved as: NVBACKUP [2018_01_30_01_13_59] TY_03_PT_wcnfixnv1.bin Read wcnfixnv2 2.53 KB, Done in: 00:00.037 Saved as: NVBACKUP [2018_01_30_01_13_59] TY_03_PT_wcnfixnv2.bin Write wcnfixnv1 2.53 KB, Done in: 00:00.238 Erase uboot 1024 KB, Done in: 00:00.021 Write splloader 31 KB, Done in: 00:00.166 Write wmodem 6.87 MB, Done in: 00:02.130 Write wdsp 1.88 MB, Done in: 00:01.382 Write wcnmodem 611.23 KB, Done in: 00:00.410 Write boot 9.3 MB, Done in: 00:02.115 Write recovery 9.83 MB, Done in: 00:01.769 Write system Failed: WRITE_MIDST: 0x045F6000 A 8B Restart Failed: FDL FINISH |
03-12-2018, 10:16 | #120 (permalink) |
Insane Poster Join Date: Jun 2012 Location: vasai, mumbai,india
Member: 1768108 Status: Offline Sonork: [email protected] Thanks Meter: 15 | Micromax a190 flashing error i think da problem with this model no dout ufst saras team is always best last 10years, add mi xiomi mi account remove ,update fastboot system |
