03-31-2016, 11:58 | #1 (permalink) |
Product Supporter Join Date: Sep 2001 Location: India
Member: 6109 Status: Offline Sonork: 100.37432 Thanks Meter: 3,781 | UFST Installation / Upgrade /Support Server Problems Post your UFST installation,Upgrade & support file server related problems in this sticky post.Its easy to solve them for us if its in one thread. Now Server is back online.All old posts about server problem now fixed & deleted due to users can post new issues if have any. Last edited by mobileclinic; 04-16-2016 at 07:01. Reason: Thread cleaned up for new issues.Old server issue fixed now. |
The Following 12 Users Say Thank You to mobileclinic For This Useful Post: |
04-16-2016, 07:45 | #2 (permalink) |
Insane Poster Join Date: Jan 2014 Location: Indonesia
Member: 2108563 Status: Offline Thanks Meter: 19 | help me sir. my problem not fix. update or instalation done. but only none authorized. UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D x x UFST Core v1.3 (c)SarasSoft 2013, Sn: 1148xxxx HID: 7CCAE2D3426000CF, HWK: A1.04-PRO1 SID: 71AF225F390354EA164A801315849A7706C66A0B XID: B50C72EA995F511CECCA302899BE170E9A7E2457 Licence: True Connection Failed8: 0 |
04-16-2016, 08:07 | #3 (permalink) |
Member: 2108563 Status: Offline Thanks Meter: 19 | I am sorry. I am confused. App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft CPU: GenuineIntel Platform: Windows NT 6.1 (Build 7601 Service Pack 1) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix C:\Users\JSC\Desktop C:\Users\JSC\AppData\Roaming\Microsoft\Windows\Sta rt Menu\Programs Last Server Update: 2016/03/30 Active Panel Version: 2.3.0.7 Box: 1 Location: 8514 Serial: TMA114xxxxx UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 114xxxxx HID: 7CCAE2D3426000CF, HWK: A1.04-PRO1 SID: 71AF225F390354EA164A801315849A7706C66A0B XID: B50C72EA995F511CECCA302899BE170E9A7E2457 LIC: True BOOT: TM UFST Boot v1.2 (c)SarasSoft 2012 Firmware: Ok Your IP: 36.74.50.29 Support: Account Ok REST: Ok UFSx: UFST, USB S/N: 114xxxxx NVML: Ok BOOT: UFST Boot v1.2 (c)SarasSoft 2012 CORE: UFST Core v1.3 (c)SarasSoft 2013 SERN: 11487286 LIC5: True BOXK: 0 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 114xxxxx HID: 7CCAE2D3426000CF, HWK: A1.04-PRO1 SID: 71AF225F390354EA164A801315849A7706C66A0B XID: B50C72EA995F511CECCA302899BE170E9A7E2457 LIC: True Authentication successfull. Upgrade client is up-to-date. Upgrade process completed. None of Boxes Selected or Active Use [Check Box] in Hardware Page App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 8514 Serial: TMA114xxxxx UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 114xxxxx HID: 7CCAE2D3426000CF, HWK: A1.04-PRO1 SID: 71AF225F390354EA164A801315849A7706C66A0B XID: B50C72EA995F511CECCA302899BE170E9A7E2457 LIC: True None Authorised Copy of Software Detected, Reinstall Bad IX: AB1D Failed: 100 Your IP: 36.74.50.29 Support: Account Ok Wrong Instalation, Try to Use [Install] in Software Page Last Server Update: 2016/03/30 Active Panel Version: 2.3.0.7 Found Items to Install: 1 Installed: 1 Item(s) Time: 00:00.640 App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 8514 Serial: TMA114xxxxx UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 114xxxxx HID: 7CCAE2D3426000CF, HWK: A1.04-PRO1 SID: 71AF225F390354EA164A801315849A7706C66A0B XID: B50C72EA995F511CECCA302899BE170E9A7E2457 LIC: True BoxStat : Ok Firmware: Ok Your IP: 36.74.50.29 Support: Account Ok |
The Following 2 Users Say Thank You to Djafar.f For This Useful Post: |
04-16-2016, 08:17 | #4 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Armenia
Member: 448264 Status: Offline Thanks Meter: 78 | Where is Saras team >????? how many time must wirte problems?? Saras work is only sale box it will work or not it's not interesting they |
The Following User Says Thank You to juve2106 For This Useful Post: |
04-16-2016, 08:18 | #5 (permalink) |
Member: 448264 Status: Offline Thanks Meter: 78 | Box: 1 Location: 0 Serial: TMA11179422 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 11179422 HID: 83EE9F2641600030, HWK: A1.04-PRO1 SID: 7239F6C10D4875E6E3109E70DF31D41C64306279 XID: 8246D013D5ADE8E17CB9F57B62824F79A4ADF4F0 LIC: True BOOT: TM UFST Boot v1.2 (c)SarasSoft 2012 Firmware: Ok Your IP: 82.199.223.147 Support: Account Ok REST: Ok UFSx: UFST, USB S/N: 11179422 NVML: Ok BOOT: UFST Boot v1.2 (c)SarasSoft 2012 CORE: UFST Core v1.3 (c)SarasSoft 2013 SERN: 11179422 LIC5: True BOXK: 0 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 11179422 HID: 83EE9F2641600030, HWK: A1.04-PRO1 SID: 7239F6C10D4875E6E3109E70DF31D41C64306279 XID: 8246D013D5ADE8E17CB9F57B62824F79A4ADF4F0 LIC: True Authentication successfull. Upgrade client is up-to-date. Upgrade process completed. App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 0 Serial: TMA11179422 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 11179422 HID: 83EE9F2641600030, HWK: A1.04-PRO1 SID: 7239F6C10D4875E6E3109E70DF31D41C64306279 XID: 8246D013D5ADE8E17CB9F57B62824F79A4ADF4F0 LIC: True HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: 2 Your IP: 82.199.223.147 Support: Account Ok Something Wrong, Try to Use [Update Box] |
04-16-2016, 09:02 | #6 (permalink) | |
Member: 6109 Status: Offline Sonork: 100.37432 Thanks Meter: 3,781 | Quote:
The Following User Says Thank You to mobileclinic For This Useful Post: |
04-21-2016, 18:42 | #7 (permalink) |
Freak Poster Join Date: Jun 2010 Location: morocco
Member: 1322811 Status: Offline Thanks Meter: 46 | am new user ufsturbo update box feild her is log App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft CPU: GenuineIntel Platform: Windows NT 5.1 (Build 2600 Service Pack 3) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files C:\Program Files\Fichiers communs Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix C:\Documents and Settings\hassan\Bureau C:\Documents and Settings\hassan\Menu Démarrer\Programmes Last Server Update: 2016/03/30 Active Panel Version: 2.3.0.7 App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 1314 Serial: TMA10620861 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 10620861 HID: B28DBB5642600001, HWK: A1.04-PRO1 SID: CBD3BD199FA07BA85E70CD24722328CA4547C0E8 XID: 5121826B159B447EE73AD204CF62E68473FF803F LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 0001 Failed: 102 Your IP: 41.140.195.94 Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 1314 Serial: TMA10620861 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 10620861 HID: B28DBB5642600001, HWK: A1.04-PRO1 SID: CBD3BD199FA07BA85E70CD24722328CA4547C0E8 XID: 5121826B159B447EE73AD204CF62E68473FF803F LIC: True BOOT: TM UFST Boot v1.2 (c)SarasSoft 2012 Firmware: Ok Your IP: 41.140.195.94 Support: Account Ok REST: Ok UFSx: UFST, USB S/N: 10620861 NVML: Ok BOOT: UFST Boot v1.2 (c)SarasSoft 2012 CORE: UFST Core v1.3 (c)SarasSoft 2013 SERN: 10620861 LIC5: True BOXK: 1 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 10620861 HID: B28DBB5642600001, HWK: A1.04-PRO1 SID: CBD3BD199FA07BA85E70CD24722328CA4547C0E8 XID: 5121826B159B447EE73AD204CF62E68473FF803F LIC: True Connection to server failed. Socket Error # 10060 Connection timed out.(Une tentative de connexion a échoué car le parti connecté n'a pas répondu convenablement au-delà d'une certaine durée ou une connexion établie a échoué car l'hôte de connexion n'a pas répondu.) |
The Following User Says Thank You to vanilla-sky007 For This Useful Post: |
05-03-2016, 04:32 | #8 (permalink) |
Freak Poster Join Date: Mar 2008 Location: australia
Member: 721542 Status: Offline Thanks Meter: 56 | How to solve the problem, tried all the update with the box . but none of them is working |
The Following User Says Thank You to edisonsuen For This Useful Post: |
05-26-2016, 13:27 | #10 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 368 | Hi I have recently bought UFST I updated and installed all completely after installation now when I open DCTxBB5 or SAMs it give error Please Reinstall HWK Support Suite ! How to solve this problem ? and What might has caused it ? I have UFS+HWK and since 10 years I am using it , I am not new with SarsSoft Boxes. WBR |
The Following 2 Users Say Thank You to NKhan_Gsm For This Useful Post: |
06-07-2016, 23:26 | #12 (permalink) |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 368 | I could solve the problem by downloading new UFS Control Panel from http://support.sarunasoftware.com/he...PANEL_2307.exe and replacing old one with this new exe. |
06-16-2016, 04:58 | #14 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,117 | |
The Following 4 Users Say Thank You to kamal_singla For This Useful Post: |
06-16-2016, 13:57 | #15 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | |
The Following 2 Users Say Thank You to Odia The Ultimate For This Useful Post: |
