09-01-2015, 07:26 | #1 (permalink) |
Product Supporter Join Date: Sep 2001 Location: India
Member: 6109 Status: Offline Sonork: 100.37432 Thanks Meter: 3,781 | UFST Samsung V 2.3.0.5 build 67 released 01-09-2015 ------ ANDROID for UFST and UFS Turbo Only New Products added (Total, more than 1240 models) Added Non-Root [Unlock] Method for SPRD (SpreadTrum) models: GT-I9060C,I,M, GT-S5310C,I,M, GT-S5312C,M, SM-G110B,H,M, SM-G130BT,BU,E,H,HN,M,U SM-G313H,HZ,ML,U, SM-G316M,ML,MY, SM-G318H,HZ,ML, SM-G355H,HN,HQ,M, SM-G360H,HU, SM-G361H,HU, SM-G531BT,H, SM-J100H,ML, SM-J110H, SM-T116, SM-T561, SM-T562 Note: Non-Root Method works only on USB connection and is software version dependant. Do not Use [Mobile Info] or any other functions before [Unlock] Some Models need to enter 12345678 Unlock Key. Full Support added for: J110F, J110G, J110M, J500Y, T365F0, N910T2, N910T3 Partial (Test) Support added for: G9198, G9280, G9287, G9287C, G928A, G928C, G928F, G928G, G928I, G928K, G928L, G928P, G928R4, G928S, G928T, G920V, G928W8, G928X, N9200, N9208, N920A, N920C, N920F, N920G, N920I, N920K, N920L, N920P, N920R4, N920S, N920T, N920V, N920W8, N920X, T817R4 Sorted out SINGLE/DUOS Models (A, E, J Series) For Android Model Details see Samsung_Android_Info document. http://forum.gsmhosting.com/vbb/f863...2/#post9621105 or inside X:\Program Files (x86)\SarasSoft\UFS\Documents X:\Program Files\SarasSoft\UFS\Documents Corresponding Full Factory Flash files on Support. |
The Following 27 Users Say Thank You to mobileclinic For This Useful Post: |
09-01-2015, 10:49 | #3 (permalink) |
No Life Poster Join Date: Jul 2012 Location: vietnam
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | please update for lumia write fw repair dieboot update for mtk nokia flashing |
The Following User Says Thank You to ngocdiemmobile For This Useful Post: |
09-01-2015, 22:04 | #6 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Sarunasoftware Support Area -> Help section panel and drivers here |
The Following User Says Thank You to Sha For This Useful Post: |
09-21-2015, 21:34 | #9 (permalink) |
Junior Member Join Date: Jan 2013 Location: Ghana
Member: 1861841 Status: Offline Sonork: 1627205 Thanks Meter: 7 | G928F IMEI: 353121xxxx IMEI: Certificate OK SKID: 0784 MSLA: R58G81EWNP Product not Authenticated Hi MobileClinic can you give a solution to the above issue ? |
12-05-2015, 03:36 | #14 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2489215 Status: Offline Thanks Meter: 1 | UFST Samsung V 2.3.0.5 build 67 released 01-09-2015 i need this panel > UFST Samsung V 2.3.0.5 build 67 released 01-09-2015 |
The Following User Says Thank You to drsaimum For This Useful Post: |
