07-16-2017, 07:59 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | for UFST and UFS Turbo Only. Test 15 v 1.0.5.5 --------- COMMON Minor Bug's Fixed in File and Model Selection. INI File saving time decreased. ALCATEL More Alcatel Models Added (Including QualComm Sahara): 6014D, 6014X, 6050A, 6050F, 6050W, 6050Y, 7043A, 7043E, 7043K, 7043Y, 7044A, 7044X, 7044Y, 7053D, 7053E, 7053J, VF-895N FASTBOOT Fixed Flashing of Devices with v0.4 fastboot core (Nvidia, Blackphone BP1) Reboot Mode Selector: Normal, Bootloader, EDL, Recovery (if Device Supports) HUAWEI More Huawei Models Added: ATH-TL00, ATH-UL00, G620-L72, G620-L75, G629-UL00, G730-U30, H30-C00, S8-701U, SC-CL00, VNS-AL00 LENOVO More Lenovo Models Added: A8-50LC, A2016a40, A2016b30, A2016b31, A2800-D, A3860, A3910e70, A3910t30, A5890, A6010+, A6020a41, A6020L36, A6020L37, A6600a40, A6600d40, A7010a48, A7700, B8080-F, B8080-H, B8080-HV, K10a40, K10e70, K30-E, K30-TM, K31-T3, K50-T3s, K51c78, K910E, K910L, K910SS, PB2-650M, PB2-670M, PB2-690M, S1La40, S856, TB3-730F, TB3-730X, TB3-850F, TB3-850M, TB3-8703F, TB3-8703X, TB3-X70F, TB3-X70L, YT-X703F, YT-X703L, YT-X703X LG More LG Models Added: AS993, F770S, F820L, G600K, G600L, G600S, G600V, H870, H870DS, H870K, H870S, H870V, H871, H872, H873, K371, K373, LS450, LS775, LS993, M150, M151, M153, M154, M160, M160E, M250AR, M250F, M250H, M250I, M250K, M320, M320AR, M320DSN, M320F, M320H, M320K, M320N, M320TV, M320Y, M400DF, M400DK, M400DY, M400F, M400MT, M400N, M400Y, MP260, MS210, TP260, US997, VS501, VS835, VS988, X130G, X130J, X132, X135, X137, X145, X147, X150, X155, X160, X165, X165G, X170G, X210MB, X220DSH, X220DST, X220M, X220MB MICROMAX More Micromax Models Added: AQ4750, C1, E451, E453, E485, E491, E4820, P701, P702, P70221, P802, Q310, Q346+, Q354, Q402, Q453, Q3301, Q3501, Q3555, Q4202, Q4220, Q4251, Q4260, Q4310, V51 MOTOROLA More Motorola Models Added: XT1670, XT1671, XT1672, XT1675, XT1676, XT1677 (Moto G5 Cerdic) XT1680, XT1681, XT1683, XT1684, XT1685, XT1687 (Moto G5 Plus Potter) XT1750 (Moto C 3G Watson) Enabled [Reset FRP], Use [ADB Mode (via Menu...)], ADB Must be Enabled. To Enable ADB use Trick with *#*#4636#*#*, Aptoide and Test_dpc_smart_manager. MTK [Format Flash] Function Added. Format (Erase) Can be Done by Linear Address or Partition Name. [Read Flash] Preloader Analysis and Extraction (to SPFL Format) Added. Preloader now is saved as 2 Files: preloader_partition.bin (Whole Partition), Flashable by UFST and preloader_blabla.bin (Extracted SPFL File), Flashable by Original SPFL. Blocked Write of not Correct Preloader File (Must be in Partition Format) [Factory Info] will show Unlock Keys in Meta Mode (If is Allowed) NOKIA More Nokia Models Added: Nokia 3 (NE1, TA-1020, TA-1028, TA-1032, TA-1038) RM-1013 Sahara Flashing. QC (QUALCOMM) Added Programer (FireHose) File Selection using [Add File] it will override Default or selected by [DA] File and allows to save into INI File. SAMSUNG [Add MSL] Function Added (To Store Factory MSL into Local DataBase) Fixed new models Failure while flashing HOME Files (meta-data) More Samsung Models Added: C5018, C7018, C701F, C9008, C900Y, G390Y, G891A, G930VL, G9500, G9508, G950F, G950N, G950U, G950U1, G950W, G9550, G955F, G955N, G955U, G955U1, G955W, J326AZ, J327A, J327AZ, J327R4, J327R6, J327R7, J327T, J327T1, J327U, J327V, J327VPP, J330F, J330FN, J330G, J530F, J530FM, J530G, J530GM, J530K, J530L, J530S, J530Y, J701F, J701M, J727A, J727R4, J727S, J727T, J727T1, J727U, J727V, J727VPP, J730F, J730FM, J730G, J730GM, N935K, N935L, N935S, S120VL, S320VL, S550TL, S820L, SC-02J, SC-03J, SC-04J, SCV35, SCV36, T825N0, T825Y, T827, T827R4, T827V SONY Increased Image Write time-out from 5mins to 10mins, to prevent error -2 at 99% for hughe (system) files. Fixed Flashing of Models without loader.sin files. Enabled [Reset FRP], Use [ADB Mode (via Menu...)], ADB Must be Enabled. To Enable ADB use Trick with QuickShortcutMaker.apk or other. More Sony Models Added: SO-02J (Xperia X Compact Kugo) SO-01J, SOV34, 601SO (Xperia XZ Kagura) G3112, G3116, G3121, G3123, G3125 (Xperia XA1 Hinoki) G3212, G3221, G3223, G3226 (Xperia XA1 Ultra Redwood) G3311, G3312, G3313 (Xperia L1 Pine) G8231, G8232, SO-03J, SOV35, 602SO (Xperia XZs Keyaki) SPRD (SPREADTRUM) More Sophistcated Boot Options: Now can Boot, by Selecting FDL1 and FDL2 Using [Add File] or [DA] Button, FDL Selection Order: PAC File, File from List [Add File] and Default by [DA] Choosing with [Add File] Allows save into INI (Individual for each model). Read Mode Selector Lets Auto-Read Files from Unknown Model. [Format Flash] Function Added. Format (Erase) Can be Done by Partition Name. VAR MTK ACER Models Added: Liquid Z6E, Liquid Zest 4G Models Added: L350, L760C ARK Models Added: Benefit M505, Benefit M506, Benefit M507, Benefit S503 BLACKVIEW Models Added: A5, A7, A8, A8 Max, A9, A9 Pro, Alife P1 Pro, Alife S1, Breeze, BV2000, BV2000s, BV5000, BV6000s, BV7000s, C1, E7, E7s, Heatwave, JK450, JK600, JK606, JK890, Omega Pro, P2 Lite, R6, R6 Lite, R6s, Ultra, Ultra Plus, V3 CONDOR Models Added: Griffe G4, Griffe G4+ CHERRY Models Added: Cosmos 3, Cubix Cube 3, Flare 4, Flare 5, Flare HD Max, Flare Infinity Lite, Flare J1 Plus, Flare J3, Flare J3 Plus, Flare J5, Flare J7, Flare P1, Flare P1 Plus, Flare S, Flare S4, Flare S4 Max, Flare S4 Plus, Flare S5, Flare S5 Plus, Flare S5 Power, Flare Selfie, Flare X, H7, Touch 2, Touch XL2 COOLPAD Models Added: 3503I (Mega 3), 3505I-S00 (Fancy 3), 8722-S00 (Roar Plus E570), 8722-U00 (Porto S E570), Y83-S00 (Sky 3 E502), Y83-U00 (Modena 2 E502) DISCOVERY Models Added: V8 DOOGEE Models Added: T3, T5, T5 Lite, T6, T6 Pro, X3, X5, X5 b, X5 Max, X5 Max Pro, X5 Max S, X5S, X6, X6 Pro, X6S, X7, X7 Pro, X7S, X9, X9 Pro, X9S, Y100X EVERTEK Models Added: EverAllure 2, EverFancy, EverFancy 3, EverGlory 2, EverGlory Plus, EverGlow D35, EverGlow D40, EverGlow D50, EverMellow D45, EverMellow D50, EverMiracle Mini, EverMiracle Nano, EverMiracle Plus, EverMiracle Power, EverMiracle S, EverMiracle S2, EverShine 2, EverShine Plus, EverSlim Nano, EverSolo, EverStar D40, EverStar Nano, EverStar Pro, EverStar Pro V2, EverStar Q40, EverStar Q50, EverStar S, EverTrendy, EverTrendy Plus 3G, EverTrendy Plus 4G, EverVivid Q47, F1, V1 Mini GIONEE Models Added: Elife S Plus, F103, F103B, F103BL, F103L, F105, F301, F303, F306, F306L, GN3003L, GN5001L, GN5001S, GN5002, M3 Mini, M5 Plus L, M5 Mini, S6, S6S INNJOO Models Added: Fire 3G, Fire 2 3G, Fire 2 LTE, Fire 2 Plus LTE, Fire 3 LTE, Fire 3 Air LTE, Fire Plus LTE, Fire Pro LTE, Halo LTE, Halo 2 LTE, Halo Plus, i1, i1k, i1s, Max, Max 2 3G, Max 2 Plus 3G, Max 3 3G, Max 3 LTE, Max 3 Pro, Note, Note E, Note Pro, One HD LTE, Pro, Two LTE INTEX Models Added: Aqua HD 5.5, Aqua Play, Aqua Ring, Aqua S7, Aqua Shine 4G, Aqua Power Pro, Aqua Pride, Prime 4G, Aqua Strong 5.1, Aqua Strong 5.2, Aqua Supreme+, Aqua Trend Lite, Aqua View, Aqua Y2 Pro, Cloud Q11 KARBONN Models Added: K9 Smart 4G LAVA Models Added: A2, A3, Iris 820 MX, Z10 LYF Models Added: LS-5506 Water 9, LS-5507 Water 7 PHILIPS Models Added: S226M, S309, S318, S388, S396, S398, S616, V377, V387, V526, V586, V787, X586 QMOBILE Models Added: Z10, Z12, Z12 Pro, Z9 Plus TEXET Models Added: TM-4071, TM-4072, TM-4082, TM-4083, TM-4172, TM-4182, TM-4272, TM-4510, TM-4513, TM-4515, TM-4572, TM-4672, TM-4772, TM-4782, TM-4872, TM-4972, TM-4982, TM-5003, TM-5005, TM-5009, TM-5010, TM-5011, TM-5017, TM-5072, TM-5082, TM-5172, TM-5503, TM-5505, TM-5508, TM-5513, TM-5577, TM-6003 VODAFONE Models Added: VFD300, VFD301, VFD500, VFD501, VFD502 ZTE Models Added: Blade L3 Lite, Blade V7 Lite, Blade X7, Nubia N1 Lite, S158, T520, Voyage 4S VAR QUALCOMM BLACKPHONE Models Added: BP2 COOLPAD Models Added: 3600I (Note 5), 8297-A, 8297-W00 (Dazen F2), A8-930, A8-I01 (Max A8), SK3-S00 (Fancy E561), SK3-U00 (Torino S E561), Y76-I01 (Sky E501), Y76-U00 (Modena E501), Y90-G00 (Shine R106), Y91-I00 (Note 3S), Y91-U00 (Torino R108) INTEX Models Added: Aqua 4G, Aqua Fish, Elit-E1 HAIER Models Added: Esteem L50, L61, Leisure L7 LYF Models Added: LS-5005 Water 4, LS-5007 Water 5, LS-5502 Wind 3, LS-5505 Water F1 OPPO Models Added: A11, A57, R8000, R9s, R9s Plus, X9000 VODAFONE Models Added: VFD900 XIAOMI Models Added: Mi Max 2 Oxygen VAR SPRD ARCHOS Models Added: 40 Neon, 50C Platinum, 50D Titanium CHERRY Models Added: Flare J1, Flare J1S, Flare Lite 2, Flare Lite Quad, Flare P1 Mini, Flare P1 Lite, Flare S5 Mini, Omega Lite 2, Touch HD EVERTEK Models Added: V1 Nano INNJOO Models Added: Halo 3G, Halo 2 3G, Halo Plus, Halo X INTEX Models Added: Aqua 4.0 3G, Aqua 4.0 4G, Aqua 4.5 Pro, Aqua 4G Mini, Aqua_Amaze+, Aqua Craze 2, Aqua Lions 4G, Aqua Q7N Pro, Aqua Pro 4G, Aqua Raze 2, Aqua S3, Aqua Selfie, Aqua Strong 5.1+, Aqua Style 3, Y2 Power, Cloud 4G Smart, Cloud M5 II, Cloud Matte, Cloud Scan FP, Cloud String HD LAVA Models Added: A50, A55 PHILIPS Models Added: S326, S337 TEXET Models Added: TM-4003, TM-4503, TM-5006, TM-5007, TM-5016 4Shared Official Link Here |
The Following 3 Users Say Thank You to dyo For This Useful Post: |
07-16-2017, 15:34 | #2 (permalink) |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | List of devices attached 0123456789ABCDEF device BOOTSERN: 0123456789ABCDEF PRDBRAND: i3 PRDMODEL: i3 PRDNAME : i3 BLDVERS : 4.2.2 BLDDISID: i3-ah-6582-20140211 BLDPROD : malata82_we_jb5 PRODBRD : i3 HARDWARE: mt6582 USB CNFG: mass_storage,adb MMC1 CID: 90014a4841473464040302a52991c0a1 Superuser Permissions Denied Samsung Unknown at USB [ADB] {ADB Info} List of devices attached 0123456789ABCDEF device BOOTSERN: 0123456789ABCDEF PRDBRAND: i3 PRDMODEL: i3 PRDNAME : i3 BLDVERS : 4.2.2 BLDDISID: i3-ah-6582-20140211 BLDPROD : malata82_we_jb5 PRODBRD : i3 HARDWARE: mt6582 USB CNFG: mass_storage,adb MMC1 CID: 90014a4841473464040302a52991c0a1 Superuser Permissions Denied Reset FRP Canceled MTK MT6582 (eMMC) at USB [ADB] {ADB Reboot} ADB Reboot Done MTK MT6582 (eMMC) at USB Auto Select [MTK] {Write Flash} Scatter : MT6582_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM5 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CA01 0001 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 90014A4841473464040302A52991C0A1 [HAG4d] PR Version: 4.2 [0x87] (5) MT6582 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000003AB800000 [15.762.194.432] eMMC CID : 90014A4841473464040302A52991C0A1 [HAG4d] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 5F1889EECE58273BA668B35E0F21759F PMT (EBR) Found : 21 Partition Entries Partitions to Flash: 11 (4.83 GB) Write PMT Done Write PRELOADER 12 MB, Skipped Write MBR 512 Bytes, Done in: 00:00.465 Write EBR1 512 Bytes, Done in: 00:00.315 Write PRO_INFO 3 MB, Skipped Write NVRAM 5 MB, Skipped Write PROTECT_F 10 MB, Skipped Write PROTECT_S 10 MB, Skipped Write SECCFG 128 KB, Skipped Write UBOOT 248.73 KB, Done in: 00:01.165 Write BOOTIMG 4.45 MB, Done in: 00:00.570 Write RECOVERY 4.95 MB, Done in: 00:00.525 Write SEC_RO 132 KB, Done in: 00:00.240 Write MISC 512 KB, Skipped Write LOGO 498.56 KB, Done in: 00:00.200 Write EBR2 512 Bytes, Done in: 00:00.245 Write EXPDB 10 MB, Skipped Write ANDROID 610.02 MB, Done in: 01:38.982 Write CACHE 6.02 MB, Done in: 00:01.327 EMMC_WRITE Error: -14 userdata.img 0, 5A DA_SHUTDOWN Error: -2 error in flash kata i3 but when i use spf it works fine |
The Following User Says Thank You to dyo For This Useful Post: |
07-16-2017, 16:13 | #3 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Seems to small time-out for hughe sparsed chunk, i think corrected it in upcoming but as is userdata, it may not affect result .... |
The Following User Says Thank You to Sha For This Useful Post: |
07-19-2017, 07:48 | #7 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | @Yaio "please for the new update add tft file flashing for sony phones" TFT Files is ZIP archives in reality, rename to zip and extract. |
