Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 07-25-2017, 05:01   #1 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 608
UFST and UFS Turbo Only. Test 19
for UFST and UFS Turbo Only.
v 1.0.5.5
COMMON
Minor Bug's Fixed in File and Model Selection.
INI File Saving time decreased.
[FPGM],[Re-Partition],[Use FastBoot] now Saving to Ini under Model Settings.
Loging to File Added (Tick [Log] CheckBox in [Main Box Functions] Tab)
Re-Tick of [Log] Will set New LogFile name (with Current Time Stamp)
More Sophisticated USB Exceptions Handling with Tips where was a Problem.
ALCATEL
More Alcatel Models Added (Including QualComm Sahara):
6014D, 6014X, 6050A, 6050F, 6050W, 6050Y, 7043A, 7043E, 7043K, 7043Y,
7044A, 7044X, 7044Y, 7053D, 7053E, 7053J, VF-895N
FASTBOOT
Fixed Flashing of Devices with v0.4 fastboot core (Nvidia, Blackphone BP1)
Reboot Mode Selector: Normal, Bootloader, EDL, Recovery (if Device Supports)
Editable Commands Selector with Predefined (Most Used) Commands List.
HUAWEI
More Huawei Models Added:
ATH-TL00, ATH-UL00, G620-L72, G620-L75, G629-UL00, G730-U30, H30-C00, S8-701U,
SC-CL00, VNS-AL00
LENOVO
More Lenovo Models Added:
A8-50LC, A2016a40, A2016b30, A2016b31, A2800-D, A3860, A3910e70, A3910t30,
A5890, A6010+, A6020a41, A6020L36, A6020L37, A6600a40, A6600d40, A7010a48,
A7700, B8080-F, B8080-H, B8080-HV, K10a40, K10e70, K30-E, K30-TM, K31-T3,
K50-T3s, K51c78, K910E, K910L, K910SS, PB2-650M, PB2-670M, PB2-690M, S1La40,
S856, TB3-730F, TB3-730X, TB3-850F, TB3-850M, TB3-8703F, TB3-8703X, TB3-X70F,
TB3-X70L, YT-X703F, YT-X703L, YT-X703X
LG
More LG Models Added:
AS993, F770S, F820L, G600K, G600L, G600S, G600V, H870, H870DS, H870K, H870S,
H870V, H871, H872, H873, K371, K373, LS450, LS775, LS993, M150, M151, M153,
M154, M160, M160E, M250AR, M250F, M250H, M250I, M250K, M320, M320AR, M320DSN,
M320F, M320H, M320K, M320N, M320TV, M320Y, M400DF, M400DK, M400DY, M400F,
M400MT, M400N, M400Y, MP260, MS210, TP260, US997, VS501, VS835, VS988, X130G,
X130J, X132, X135, X137, X145, X147, X150, X155, X160, X165, X165G, X170G,
X210MB, X220DSH, X220DST, X220M, X220MB
According New LAF Security, Flashing is Allowed Only of Factory Signed Files.
We Improved KDZ Extraction Utility, It will Extract .dz and .sign Files,
for Flashing Must [Add Files] .dz and then .sign File.
Can Flash Directly Compatible .kdz File, then not need Extraction or sign.
MICROMAX
More Micromax Models Added:
AQ4750, C1, E451, E453, E485, E491, E4820, P701, P702, P70221, P802, Q310,
Q346+, Q354, Q402, Q453, Q3301, Q3501, Q3555, Q4202, Q4220, Q4251, Q4260,
Q4310, V51
MOTOROLA
More Motorola Models Added:
XT1670, XT1671, XT1672, XT1675, XT1676, XT1677 (Moto G5 Cerdic)
XT1680, XT1681, XT1683, XT1684, XT1685, XT1687 (Moto G5 Plus Potter)
XT1750 (Moto C 3G Watson)
Enabled [Reset FRP], Use [ADB Mode (via Menu...)], ADB Must be Enabled.
To Enable ADB use Trick with *#*#4636#*#*, Aptoide and Test_dpc_smart_manager.
MTK
[Format Flash] Function Added.
Format (Erase) Can be Done by Linear Address or Partition Name.
[Read Flash] Preloader Analysis and Extraction (to SPFL Format) Added.
Preloader now is saved as 2 Files:
preloader_partition.bin (Whole Partition), Flashable by UFST and
preloader_blabla.bin (Extracted SPFL File), Flashable by Original SPFL.
Blocked Write of not Correct Preloader File (Must be in Partition Format)
[Factory Info] will show Unlock Keys in Meta Mode (If is Allowed)
[Enter FacTst] Button added, to boot in Factory Test Mode.
NOKIA
More Nokia Models Added:
Nokia 3 (NE1, TA-1020, TA-1028, TA-1032, TA-1038)
RM-1013 Sahara Flashing.
QC (QUALCOMM)
Added Programer (FireHose) File Selection using [Add File] it will override
Default or selected by [DA] File and allows to save into INI File.
SAMSUNG
[Add MSL] Function Added (To Store Factory MSL into Local DataBase)
Fixed new models Failure while flashing HOME Files (meta-data)
More Samsung Models Added:
C5018, C7018, C701F, C9008, C900Y, G390Y, G891A, G930VL, G9500, G9508, G950F,
G950N, G950U, G950U1, G950W, G9550, G955F, G955N, G955U, G955U1, G955W,
J326AZ, J327A, J327AZ, J327R4, J327R6, J327R7, J327T, J327T1, J327U, J327V,
J327VPP, J330F, J330FN, J330G, J530F, J530FM, J530G, J530GM, J530K, J530L,
J530S, J530Y, J701F, J701M, J727A, J727R4, J727S, J727T, J727T1, J727U,
J727V, J727VPP, J730F, J730FM, J730G, J730GM, J730K, N935K, N935L, N935S,
S120VL, S320VL, S550TL, S820L, SC-02J, SC-03J, SC-04J, SCV35, SCV36, T825N0,
T825Y, T827, T827R4, T827V
SONY
Increased Image Write time-out from 5mins to 10mins,
to prevent error -2 at 99% for hughe (system) files.
Fixed Flashing of Models without loader.sin files.
To Enable ADB use Trick with QuickShortcutMaker.apk or other.
More Sony Models Added:
SO-02J (Xperia X Compact Kugo) SO-01J, SOV34, 601SO (Xperia XZ Kagura)
G3112, G3116, G3121, G3123, G3125 (Xperia XA1 Hinoki)
G3212, G3221, G3223, G3226 (Xperia XA1 Ultra Redwood)
G3311, G3312, G3313 (Xperia L1 Pine)
G8231, G8232, SO-03J, SOV35, 602SO (Xperia XZs Keyaki)
SPRD (SPREADTRUM)
More Sophistcated Boot Options:
Now can Boot, by Selecting FDL1 and FDL2 Using [Add File] or [DA] Button,
FDL Selection Order: PAC File, File from List [Add File] and Default by [DA]
Choosing with [Add File] Allows save into INI (Individual for each model).
Read Mode Selector Lets Auto-Read Files from Unknown Model.
Format (Erase) Can be Done by Partition Name.
VAR MTK
ACER Models Added:
Liquid Z6E, Liquid Zest 4G
AMOI Models Added:
L350, L760C
ARK Models Added:
Benefit M505, Benefit M506, Benefit M507, Benefit S503
BLACKVIEW Models Added:
A5, A7, A8, A8 Max, A9, A9 Pro, Alife P1 Pro, Alife S1, Breeze, BV2000,
BV2000s, BV5000, BV6000s, BV7000s, C1, E7, E7s, Heatwave, JK450, JK600,
JK606, JK890, Omega Pro, P2 Lite, R6, R6 Lite, R6s, Ultra, Ultra Plus, V3
CONDOR Models Added:
Griffe G4, Griffe G4+
CHERRY Models Added:
Cosmos 3, Cubix Cube 3, Flare 4, Flare 5, Flare HD Max, Flare Infinity Lite,
Flare J1 Plus, Flare J3, Flare J3 Plus, Flare J5, Flare J7, Flare P1,
Flare P1 Plus, Flare S, Flare S4, Flare S4 Max, Flare S4 Plus, Flare S5,
Flare S5 Plus, Flare S5 Power, Flare Selfie, Flare X, H7, Touch 2, Touch XL2
COOLPAD Models Added:
3503I (Mega 3), 3505I-S00 (Fancy 3), 8722-S00 (Roar Plus E570),
8722-U00 (Porto S E570), Y83-S00 (Sky 3 E502), Y83-U00 (Modena 2 E502)
DISCOVERY Models Added:
V8
DOOGEE Models Added:
T3, T5, T5 Lite, T6, T6 Pro, X3, X5, X5 b, X5 Max, X5 Max Pro, X5 Max S,
X5S, X6, X6 Pro, X6S, X7, X7 Pro, X7S, X9, X9 Pro, X9S, Y100X
EVERTEK Models Added:
EverAllure 2, EverFancy, EverFancy 3, EverGlory 2, EverGlory Plus,
EverGlow D35, EverGlow D40, EverGlow D50, EverMellow D45, EverMellow D50,
EverMiracle Mini, EverMiracle Nano, EverMiracle Plus, EverMiracle Power,
EverMiracle S, EverMiracle S2, EverShine 2, EverShine Plus, EverSlim Nano,
EverSolo, EverStar D40, EverStar Nano, EverStar Pro, EverStar Pro V2,
EverStar Q40, EverStar Q50, EverStar S, EverTrendy, EverTrendy Plus 3G,
EverTrendy Plus 4G, EverVivid Q47, F1, V1 Mini
GIONEE Models Added:
Elife S Plus, F103, F103B, F103BL, F103L, F105, F301, F303, F306, F306L,
GN3003L, GN5001L, GN5001S, GN5002, M3 Mini, M5 Plus L, M5 Mini, S6, S6S
INNJOO Models Added:
Fire 3G, Fire 2 3G, Fire 2 LTE, Fire 2 Plus LTE, Fire 3 LTE, Fire 3 Air LTE,
Fire Plus LTE, Fire Pro LTE, Halo LTE, Halo 2 LTE, Halo Plus, i1, i1k, i1s,
Max, Max 2 3G, Max 2 Plus 3G, Max 3 3G, Max 3 LTE, Max 3 Pro, Note, Note E,
Note Pro, One HD LTE, Pro, Two LTE
INTEX Models Added:
Aqua HD 5.5, Aqua Play, Aqua Ring, Aqua S7, Aqua Shine 4G, Aqua Power Pro,
Aqua Pride, Prime 4G, Aqua Strong 5.1, Aqua Strong 5.2, Aqua Supreme+,
Aqua Trend Lite, Aqua View, Aqua Y2 Pro, Cloud Q11
KARBONN Models Added:
K9 Smart 4G
LAVA Models Added:
A2, A3, Iris 820 MX, Z10
LYF Models Added:
LS-5506 Water 9, LS-5507 Water 7
PHILIPS Models Added:
S226M, S309, S318, S388, S396, S398, S616, V377, V387, V526, V586, V787, X586
QMOBILE Models Added:
Z10, Z12, Z12 Pro, Z9 Plus
TEXET Models Added:
TM-4071, TM-4072, TM-4082, TM-4083, TM-4172, TM-4182, TM-4272, TM-4510,
TM-4513, TM-4515, TM-4572, TM-4672, TM-4772, TM-4782, TM-4872, TM-4972,
TM-4982, TM-5003, TM-5005, TM-5009, TM-5010, TM-5011, TM-5017, TM-5072,
TM-5082, TM-5172, TM-5503, TM-5505, TM-5508, TM-5513, TM-5577, TM-6003
VODAFONE Models Added:
VFD300, VFD301, VFD500, VFD501, VFD502
ZTE Models Added:
Blade L3 Lite, Blade V7 Lite, Blade X7, Nubia N1 Lite, S158, T520, Voyage 4S
VAR QUALCOMM
BLACKPHONE Models Added:
BP2
3600I (Note 5), 8297-A, 8297-W00 (Dazen F2), A8-930, A8-I01 (Max A8),
SK3-S00 (Fancy E561), SK3-U00 (Torino S E561), Y76-I01 (Sky E501),
Y76-U00 (Modena E501), Y90-G00 (Shine R106), Y91-I00 (Note 3S),
Y91-U00 (Torino R108)
INTEX Models Added:
Aqua 4G, Aqua Fish, Elit-E1
HAIER Models Added:
Esteem L50, L61, Leisure L7
LYF Models Added:
LS-5005 Water 4, LS-5007 Water 5, LS-5502 Wind 3, LS-5505 Water F1
OPPO Models Added:
A11, A57, R8000, R9s, R9s Plus, X9000
VFD900
XIAOMI Models Added:
Mi Max 2 Oxygen
VAR SPRD
ARCHOS Models Added:
40 Neon, 50C Platinum, 50D Titanium
Flare J1, Flare J1S, Flare Lite 2, Flare Lite Quad, Flare P1 Mini,
Flare P1 Lite, Flare S5 Mini, Omega Lite 2, Touch HD
V1 Nano
Halo 3G, Halo 2 3G, Halo Plus, Halo X
INTEX Models Added:
Aqua 4.0 3G, Aqua 4.0 4G, Aqua 4.5 Pro, Aqua 4G Mini, Aqua_Amaze+,
Aqua Craze 2, Aqua Lions 4G, Aqua Q7N Pro, Aqua Pro 4G, Aqua Raze 2,
Aqua S3, Aqua Selfie, Aqua Strong 5.1+, Aqua Style 3, Y2 Power,
Cloud 4G Smart, Cloud M5 II, Cloud Matte, Cloud Scan FP, Cloud String HD
LAVA Models Added:
A50, A55
S326, S337
TEXET Models Added:
TM-4003, TM-4503, TM-5006, TM-5007, TM-5016
official 4shared link here
The Following 7 Users Say Thank You to dyo For This Useful Post:
Old 07-25-2017, 09:08   #2 (permalink)
Member: 2185549
Thanks Meter: 535
please fix diag selection for huawei devices ansd fix samsung flashing it keeps asking for pit even after doing it it keeps asking for pit please fix itt
Old 07-25-2017, 10:33   #3 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 608
can you post logs for further data check thank you
Old 07-25-2017, 11:11   #4 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 608
Cloudfone flash error
Var CLOUDFONE-Excite 502q (Excite 502q 3G DS) at USB Auto Select [MTK] {Write Flash}
Scatter : MT6582_Android_scatter_UFST.txt
BR USB Com: Vid_0e8d&Pid_2000
DA Agent : MTK_AllInOne_DA.bin
BR ComPort: COM3
BR Asic Id: MT6582 [0000]
BR Asic Sw: 8A00 CA01 0001 0000
DA Version: MTK_AllInOne_DA_v3.3001.00.00
PR MMC CID: 45010053454D303447282564BD1F5129 [SEM04G]
PR Version: 4.2 [0x87] (5) MT6582
eMMC BOOT1: 0x0000000000200000 [2.097.152]
eMMC BOOT2: 0x0000000000200000 [2.097.152]
eMMC RPMB : 0x0000000000200000 [2.097.152]
eMMC USER : 0x00000000EC000000 [3.959.422.976]
eMMC CID : 45010053454D303447282564BD1F5129 [SEM04G]
ERAM Size : 0x0000000040000000 [1.073.741.824]
IRAM Size : 0x0000000000020000 [131.072]
UNICAL ID : 21CD4762A9A4AE99DC226CEA1E2B3283
PMT (EBR) Found : 21 Partition Entries
Partitions to Flash: 11 (2.51 GB)
File: lk.bin not Exists
DA Shutdown Done, Disconnect Cable
MTK MT6582 (eMMC) at USB Auto Select [MTK] {Write Flash}
Scatter : MT6582_Android_scatter.txt
BR ComPort: COM3
got the file from support
The Following User Says Thank You to dyo For This Useful Post:
Old 07-25-2017, 11:17   #5 (permalink)
Member: 2185549
Thanks Meter: 535
https://www.4shared.com/photo/b75Qqr...pture__2_.html
and after
https://www.4shared.com/photo/J0PQrnWfca/Capture5.html
The Following User Says Thank You to ferouz kassim For This Useful Post:
Old 07-25-2017, 12:19   #6 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
@Dyo
Yes, true it not exists in that package ...
Solutions:
1. Unselect it in flash setup menu (wil be bypassed)
2. Read it from good phone
3. Take it from other firmware package
The Following User Says Thank You to Sha For This Useful Post:
Old 07-25-2017, 12:51   #7 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 608
Flash done after uncheck
BR ComPort: COM3
Partitions to Flash: 9 (948.5 MB)
Write PRELOADER 6 MB, Skipped
Write MBR 512 Bytes, Done in: 00:00.250
Write EBR1 512 Bytes, Done in: 00:00.241
Write PRO_INFO 3 MB, Skipped
Write NVRAM 5 MB, Skipped
Write PROTECT_F 10 MB, Skipped
Write PROTECT_S 10 MB, Skipped
Write SECCFG 128 KB, Skipped
Write UBOOT 384 KB, Skipped
Write BOOTIMG 6 MB, Done in: 00:00.698
Write RECOVERY 6 MB, Done in: 00:00.673
Write SEC_RO 6 MB, Done in: 00:00.674
Write MISC 512 KB, Skipped
Write LOGO 3 MB, Done in: 00:00.360
Write EBR2 512 Bytes, Done in: 00:00.240
Write EXPDB 10 MB, Skipped
Write ANDROID 800 MB, Done in: 01:17.897
Write CACHE 126 MB, Done in: 00:12.387
Write USRDATA 1.59 GB, Skipped
Write FAT 1.12 GB, Skipped
Write BMTPOOL 21 MB, Skipped
Write Done in : 01:33.511
Old 07-25-2017, 13:00   #8 (permalink)
Member: 2185549
Thanks Meter: 535
imei repair samsung g900f
Sent from my Nexus 5 using Tapatalk
Old 07-25-2017, 13:35   #9 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 608
Factory test boot done
Var CLOUDFONE-Excite 502q (Excite 502q 3G DS) at BOOT {Enter FacTst}
Insert Cable to Switched OFF Device
Factory Mode Entered
Old 07-25-2017, 14:04   #10 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
if have problem on Win10, here is new link:
https://www.4shared.com/s/fCaza5L0pei
also on server:
ANDROID_UFS_1055_Test19_w10fix.7z
soon will be released next one with PIT fix
it happens on Qualcomm phones with UFST memory
thanx to: ferouz kassim for found and report
The Following 3 Users Say Thank You to Sha For This Useful Post:
Old 07-25-2017, 14:53   #11 (permalink)
Member: 2185549
Thanks Meter: 535
mr sha please also fix the factory info button in the qualcom module it doesnot respond whereas in mtk its fucntioning
Old 07-25-2017, 15:51   #12 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
Yes, You right, fixing this
Old 07-25-2017, 16:35   #13 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 840
@Sha
in QC tab: when i select MSM8909 for example and select loader 8909 from QC_BOOT folder but get this error in software:
QC MSM8909 (eMMC) at Auto Select Flashing Port [SAHARA] {Reset FRP}
Select FireHose File Using [DA] Button !
DA automatically changes to: UFS_SAMs\QC_BOOT\prog_emmc_firehose_8909*.*
whever i click on Reset FRP
Old 07-25-2017, 16:37   #14 (permalink)
Member: 2185549
Thanks Meter: 535
None of Diags Ports Selected
Huawei Y625-U32 (Huawei Y625 3G DS) at USB (COM50) [DIAGS] {Factory Info}
<<< STOP >>>
Comms Failed: -1 (No Response)
Huawei Y625-U32 (Huawei Y625 3G DS) at USB (COM260) [DIAGS] {Factory Info}
OFFLMODE: OK
MDMVERSN: Mar 7 201511:54:14Mar 04 201522:00:00BAAAANWZ
MDMBUILD: 8x10_PL190335_20141120
NV IMEI1: 000000-00-000000-0
NV IMEI2: 000000-00-000000-0
NV BTID : 0000:00:000000
Huawei Y625-U32 (Huawei Y625 3G DS) at USB (COM260) [DIAGS] {Gen.Settings}
OFFLMODE: OK
NV WIFI : 0000:00:000000
Gen.Settings Write Done: 2 Item(s)
OFFLMODE: OK
NV IMEI1: 867948-02-856460-9
NV IMEI2: 867948-02-856460-9
Old 07-25-2017, 16:52   #15 (permalink)
Member: 2185549
Thanks Meter: 535
mr. sha fix the buttons for restart pcinfo and factory defaults in huawei tab(for qualcom based devices for mtk deivces are ohkay) the rest of tabs ohkay except that in huawei tab
Page generated in 0.25015 seconds with 9 queries
