09-27-2017, 08:02 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | UFST and UFS Turbo Only. v 1.0.5.5 test28 Ready v 1.0.5.5 --------- COMMON Minor Bug's Fixed in File and Model Selection. INI File Saving time decreased. [FPGM],[Re-Partition],[Use FastBoot] now Saving to Ini under Model Settings. Loging to File Added (Tick [Log] CheckBox in [Main Box Functions] Tab) Re-Tick of [Log] Will set New LogFile name (with Current Time Stamp) More Sophisticated USB Exceptions Handling with Tips where was a Problem. ALCATEL More Alcatel Models Added (Including QualComm Sahara): 4044L, 4044M, 4044N, 4044O, 4044T, 4044V, 4044W, 4060A, 4060O, 4060S, 4060W, 5044G, 5044R, 5046G, 6014D, 6014X, 6050A, 6050F, 6050W, 6050Y, 7043A, 7043E, 7043K, 7043Y, 7044A, 7044X, 7044Y, 7053D, 7053E, 7053J, 9006W, VF-895N ASUS More Asus Models Added: P001-Z170MG, P00A-Z380M, P00C-Z300M, X002, X005-T551TLC, X008-ZC520TL, X008_1-ZC520TL, X008D-ZC520TL, X008DA-ZC520TL, X008DC-ZC520TL, X00DD-ZC553KL, Z00LD-ZE550KL, Z00SD-ZC451TG, Z00T-ZE551KL, Z00TD-ZE551KL, Z00VD-ZC500TG, Z00WD-ZE550KG, Z00YD-G500TG, Z011D-ZE601KL, Z018-ZS550KL, Z01H-ZE553KL Tips - Asus uses totally crazy models naming schema, so please be here very accurate, same Sales Model can have x100 implementations on all possible MCU's. FASTBOOT Fixed Flashing of Devices with v0.4 fastboot core (Nvidia, Blackphone BP1) Reboot Mode Selector: Normal, Bootloader, EDL, Recovery (if Device Supports) Editable Commands Selector with Predefined (Most Used) Commands List. Editable VID Selector with Predefined Vendors List. Added 'Format' to Commands Parser. HUAWEI More Huawei Models Added: ATH-TL00, ATH-UL00, CRO-L02, CRO-L03, CRO-L22, CRO-L23, G620-L72, G620-L75, G629-UL00, G730-U30, H30-C00, S8-701U, SC-CL00, TIT-U02, VNS-AL00 LENOVO More Lenovo Models Added: A8-50LC, A2016a40, A2016b30, A2016b31, A2800-D, A3860, A3910e70, A3910t30, A5890, A6010+, A6020a41, A6020L36, A6020L37, A6600a40, A6600d40, A7010a48, A7700, B8080-F, B8080-H, B8080-HV, K10a40, K10e70, K30-E, K30-TM, K31-T3, K50-T3s, K51c78, K910E, K910L, K910SS, PB2-650M, PB2-670M, PB2-690M, S1La40, S856, TB3-730F, TB3-730X, TB3-850F, TB3-850M, TB3-8703F, TB3-8703X, TB3-X70F, TB3-X70L, TB-8504F, TB-8504X, TB-8704F, TB-8704X, TB-X304F, TB-X304L, TB-X704F, TB-X704L, YT-X703F, YT-X703L, YT-X703X LG More LG Models Added: AS993, F770S, F820L, G600K, G600L, G600S, G600V, H870, H870DS, H870K, H870S, H870V, H871, H872, H873, K120, K371, K373, LS450, LS775, LS993, K220TR, K220Y, K220Z, M150, M151, M153, M154, M160, M160E, M250AR, M250F, M250H, M250I, M250K, M320, M320AR, M320DSN, M320F, M320H, M320K, M320N, M320TV, M320Y, M400DF, M400DK, M400DY, M400F, M400MT, M400N, M400Y, M470, M470F, M700, M700A, M700AN, M700DSK, M700N, MP260, MS210, TP260, US215, US997, VS501, VS835, VS988, X130G, X130J, X132, X135, X137, X145, X147, X150, X155, X160, X165, X165G, X170G, X210MB, X220DSH, X220DST, X220M, X220MB According New LAF Security, Flashing is Allowed Only of Factory Signed Files. We Improved KDZ Extraction Utility, It will Extract .dz and .sign Files, for Flashing Must [Add Files] .dz and then .sign File. Can Flash Directly Compatible .kdz File, then not need Extraction or sign. [Unlock/Sec] and [Byp.Security] Fixed for Last MTK Models (M250, ...) MICROMAX More Micromax Models Added: AQ4750, C1, E451, E453, E485, E491, E4820, P701, P702, P70221, P802, Q310, Q346+, Q354, Q402, Q402+, Q409, Q421, Q437, Q438, Q440, Q441, Q453, Q3301, Q3501, Q3555, Q4202, Q4220, Q4251, Q4260, Q4310, Q4311, V51 MOTOROLA More Motorola Models Added: XT1670, XT1671, XT1672, XT1675, XT1676, XT1677 (Moto G5 Cerdic) XT1680, XT1681, XT1683, XT1684, XT1685, XT1687 (Moto G5 Plus Potter) XT1710-xx (Moto Z2 Play Albus) XT1721, XT1723, XT1724, XT1725, XT1726 (Moto C Plus Panell) XT1750 (Moto C 3G Watson) XT1754, XT1755, XT1756, XT1757, XT1758 (Moto C LTE Namath) XT1760, XT1761, XT1762, XT1763, XT1766 (Moto E4 LTE Woods) XT1767, XT1768 (Moto E4 LTE NA SPerry, Perry) XT1770, XT1771, XT1772, XT1773 (Moto E4 Plus Nicklaus) Enabled [Reset FRP], Use [ADB Mode (via Menu...)], ADB Must be Enabled. To Enable ADB use Trick with *#*#4636#*#*, Aptoide and Test_dpc_smart_manager. Note - MTK Models FRP Can be Done in Flash Mode. Enabled Sahara Flashing (Unbrick) for some Models (Addison,Athene,Albus,Potter) MTK [Format Flash] Function Added. Format (Erase) Can be Done by Linear Address or Partition Name. [Read Flash] Preloader Analysis and Extraction (to SPFL Format) Added. Preloader now is saved as 2 Files: preloader_partition.bin (Whole Partition), Flashable by UFST and preloader_blabla.bin (Extracted SPFL File), Flashable by Original SPFL. Blocked Write of Wrong Preloader File (Must be in Partition or Original Format) [Factory Info] will Show Unlock Keys in Meta Mode (If is Allowed) Enabled [Fact.Unlock] Button, Unlock in Meta Mode (If is Allowed) [Enter FacTst] Button added, to Boot in Factory Test Mode. Non Readable Partitions now Skipped, not Generate Fatal Exception. SIGN Update of Signed Devices [SBC] Fixed (Blink, not Start or Loose Digits) Note: not Original or not Signed Files will not cause Signature Update. Warning About MTK Signed Devices [SBC]: Must Flash Original Signed Files, Otherwise Device will not Start or Blink. If Have no Idea is Signed or not, Backup All, before Flashing ! Some Paranoid "Secured" Devices cannot read at all from Flash Mode, but can be Root-et and Read via ADB ... If Device need Signed Images, can flash Only SAME Version from other device. All this "Security" Paranoya not Affect a FRP, it can be done on all Devices. PMT Writing on GPT Devices Fixed (DL_SET_A4 Error) NOKIA More Nokia Models Added: Nokia 3 (NE1, TA-1020, TA-1028, TA-1032, TA-1038) Nokia 5 (TA-1024, TA-1027, TA-1044, TA-1053) Nokia 6 (TA-1000, TA-1003, TA-1021, TA-1025, TA-1033, TA-1039) RM-1013, Nokia 5, Nokia 6 Sahara Flashing, Read, Frp, Unbrick ... QC (QUALCOMM) Factory Operations Fixed. Added Programer (FireHose) File Selection using [Add File] it will override Default or selected by [DA] File and allows to save into INI File. Fixed Read Issue with some Driver Versions on some Machines. Non GPT Disks now will Read as Raw binary, instead of error Exception. SAMSUNG [Add MSL] Function Added (To Store Factory MSL into Local DataBase) Fixed New Models Failure while flashing HOME Files (meta-data) Fixed 'Error: PIT Tokens Count...' Bug on Some Models with UFST Memory. More Samsung Models Added: C5018, C7018, C701F, C9008, C900Y, G160N, G1650, G165N, G390W, G390Y, G891A, G892A, G930VL, G9500, G9508, G950F, G950N, G950U, G950U1, G950W, G9550, G955F, G955N, G955U, G955U1, G955W, J3119S, J326AZ, J327A, J327AZ, J327R4, J327R6, J327R7, J327T, J327T1, J327U, J327V, J327VPP, J3300, J3308, J330F, J330FN, J330G, J330L, J530F, J530FM, J530G, J530GM, J530K, J530L, J530S, J530Y, J530YM, J700T1, J701F, J701M, J701MT, J727A, J727AZ, J727R4, J727S, J727T, J727T1, J727U, J727V, J727VPP, J730F, J730FM, J730G, J730GM, J730K, N935K, N935L, N935S, N9500, N9508, N950F, N950N, N950U, N950U1, N950W, S120VL, S320VL, S550TL, S820L, SC-02J, SC-03J, SC-04J, SCV35, SCV36, T377W, T380, T385, T677A, T818A, T818V, T818W, T825N0, T825Y, T827, T827R4, T827V SONY Increased Image Write time-out from 5mins to 10mins, to prevent error -2 at 99% for hughe (system) files. Fixed Flashing of New Models without loader.sin files. Enabled [Reset FRP], Use [ADB Mode (via Menu...)], ADB Must be Enabled. To Enable ADB use Trick with QuickShortcutMaker.apk or other. More Sony Models Added: C1504, C1505, C1604, C1605 (Xperia E NanHu) C2304, C2305, S39h (Xperia C Pelican) C5302, C5303, C5306, M35c, M35h, M35t (Xperia SP Huashan) E2003, E2006, E2033, E2043, E2053 (Xperia E4g Calla) E2104, E2105, E2115, E2124 (Xperia E4 Jasmine) G3112, G3116, G3121, G3123, G3125 (Xperia XA1 Hinoki) G3212, G3221, G3223, G3226 (Xperia XA1 Ultra Redwood) G3311, G3312, G3313 (Xperia L1 Pine) G8231, G8232, SO-03J, SOV35, 602SO (Xperia XZs Keyaki) LT25c, LT25i, SO-01E, SOL21 (Xperia VC, V, AX, VL Tsubasa) LT29a, LT29i, SO-04D (Xperia TX, GX Hayabusa) LT30a, LT30at, LT30p (Xperia T Mint) SO-01J, SOV34, 601SO (Xperia XZ Kagura) SO-02J (Xperia X Compact Kugo) ST26a, ST26i (Xperia J JLo) Fixed partition-image Flashing for Old Models. SPRD (SPREADTRUM) More Sophistcated Boot Options: Now can Boot, by Selecting FDL1 and FDL2 Using [Add File] or [DA] Button, FDL Selection Order: PAC File, File from List [Add File] and Default by [DA] Choosing with [Add File] Allows save into INI (Individual for each model). Read Mode Selector Lets Auto-Read Files from Unknown Model. [Format Flash] Function Added. Format (Erase) Can be Done by Partition Name. SC6530A, SC6531A MCU Support Added (Read, Write, Format, Gen.Settings) 'ENUMERATION NOT EXIST' Error Fixed. VAR MTK ACER Models Added: Iconia One 10 WiFi, Liquid Jade, Liquid Jade S, Liquid Jade Z, Liquid X2, Liquid Z500, Liquid Z630S, Liquid Z6E, Liquid Zest 4G, Liquid Zest Plus AMOI Models Added: L350, L760C ARK Models Added: Benefit M505, Benefit M506, Benefit M507, Benefit S503 BLACKVIEW Models Added: A5, A7, A8, A8 Max, A9, A9 Pro, Alife P1 Pro, Alife S1, Breeze, BV2000, BV2000s, BV5000, BV6000s, BV7000s, C1, E7, E7s, Heatwave, JK450, JK600, JK606, JK890, Omega Pro, P2 Lite, R6, R6 Lite, R6s, Ultra, Ultra Plus, V3 BQ Models Added: BQS-4552, BQS-4555, BQS-4560, BQS-4570, BQS-5006, BQS-5022, BQS-5030, BQS-5032, BQS-5040, BQS-5045, BQS-5050, BQS-5055, BQS-5057, BQS-5058, BQS-5059, BQS-5060, BQS-5065, BQS-5070, BQS-5071, BQS-5500, BQS-5502, BQS-5505, BQS-5515, BQS-5520, BQS-5590, BQS-6050 CONDOR Models Added: Griffe G4, Griffe G4+ CHERRY Models Added: Cosmos 3, Cubix Cube 3, Flare 4, Flare 5, Flare HD Max, Flare Infinity Lite, Flare J1 Plus, Flare J3, Flare J3 Plus, Flare J5, Flare J7, Flare P1, Flare P1 Plus, Flare S, Flare S4, Flare S4 Max, Flare S4 Plus, Flare S5, Flare S5 Plus, Flare S5 Power, Flare Selfie, Flare X, H7, Touch 2, Touch XL2 COOLPAD Models Added: 3503I (Mega 3), 3505I-S00 (Fancy 3), 8722-S00 (Roar Plus E570), 8722-U00 (Porto S E570), Y83-S00 (Sky 3 E502), Y83-U00 (Modena 2 E502) DISCOVERY Models Added: V8 DOOGEE Models Added: T3, T5, T5 Lite, T6, T6 Pro, X3, X5, X5 b, X5 Max, X5 Max Pro, X5 Max S, X5S, X6, X6 Pro, X6S, X7, X7 Pro, X7S, X9, X9 Pro, X9S, Y100X ELEPHONE Models Added: A1, A1 Mini, C1, C1 Max, C1 Mini, C1X, H1, S3 Basic, S7 Mini EVERTEK Models Added: EverAllure 2, EverFancy, EverFancy 3, EverGlory 2, EverGlory Plus, EverGlow D35, EverGlow D40, EverGlow D50, EverMellow D45, EverMellow D50, EverMiracle Mini, EverMiracle Nano, EverMiracle Plus, EverMiracle Power, EverMiracle S, EverMiracle S2, EverShine 2, EverShine Plus, EverSlim Nano, EverSolo, EverStar D40, EverStar Nano, EverStar Pro, EverStar Pro V2, EverStar Q40, EverStar Q50, EverStar S, EverTrendy, EverTrendy Plus 3G, EverTrendy Plus 4G, EverVivid Q47, F1, V1 Mini GIONEE Models Added: Elife S Plus, F103, F103B, F103BL, F103L, F105, F301, F303, F306, F306L, GN3003L, GN5001L, GN5001S, GN5002, M3 Mini, M5 Plus L, M5 Mini, S6, S6S INNJOO Models Added: Fire 3G, Fire 2 3G, Fire 2 LTE, Fire 2 Plus LTE, Fire 3 LTE, Fire 3 Air LTE, Fire Plus LTE, Fire Pro LTE, Halo LTE, Halo 2 LTE, Halo Plus, i1, i1k, i1s, Max, Max 2 3G, Max 2 Plus 3G, Max 3 3G, Max 3 LTE, Max 3 Pro, Note, Note E, Note Pro, One HD LTE, Pro, Two LTE INTEX Models Added: Aqua HD 5.5, Aqua Play, Aqua Ring, Aqua S7, Aqua Shine 4G, Aqua Power Pro, Aqua Pride, Prime 4G, Aqua Strong 5.1, Aqua Strong 5.2, Aqua Supreme+, Aqua Trend Lite, Aqua View, Aqua Y2 Pro, Cloud Q11 KARBONN Models Added: K9 Smart 4G LAVA Models Added: A2, A3, Iris 820 MX, Z10 LYF Models Added: LS-5506 Water 9, LS-5507 Water 7 NOUS Models Added: NS5002, NS5502 PHILIPS Models Added: S226M, S309, S318, S388, S396, S398, S616, V377, V387, V526, V586, V787, X586 QMOBILE Models Added: Z10, Z12, Z12 Pro, Z9 Plus TECNO Models Added: 7C, 7CS, 7H, 8H, C5, C7, C8, C9, C9 Plus, CX Air, i3, i3 Pro, i5 Pro, J5, J7, J8, L5, L6, L7, L8, L8 Plus, L9 Plus, N8, N8S, Phantom 5, W1, W2, W3, W3 LTE, W4, W5, W5 Lite, WX3 TEXET Models Added: TM-4071, TM-4072, TM-4082, TM-4083, TM-4172, TM-4182, TM-4272, TM-4510, TM-4513, TM-4515, TM-4572, TM-4672, TM-4772, TM-4782, TM-4872, TM-4972, TM-4982, TM-5003, TM-5005, TM-5009, TM-5010, TM-5011, TM-5017, TM-5072, TM-5082, TM-5172, TM-5503, TM-5505, TM-5508, TM-5513, TM-5577, TM-6003 VODAFONE Models Added: VFD300, VFD301, VFD500, VFD501, VFD502 WIKO Models Added: Barry, Bloom, Darkmoon, Fizz, Getaway, Goa, Harry, Iggy, Jerry2, K-Kool, Lenny3 Max, Lenny4, Ozzy, Rainbow Lite, Sunset, Ufeel Go, Upulse, Upulse Lite WILEYFOX Models Added: Spark, Spark Plus, Spark X ZTE Models Added: Blade L3 Lite, Blade V7 Lite, Blade X7, Nubia N1 Lite, S158, T520, Voyage 4S VAR QUALCOMM BLACKPHONE Models Added: BP2 BQ Models Added: BQS-5025, BQS-5037 COOLPAD Models Added: 3600I (Note 5), 8297-A, 8297-W00 (Dazen F2), A8-930, A8-I01 (Max A8), SK3-S00 (Fancy E561), SK3-U00 (Torino S E561), Y76-I01 (Sky E501), Y76-U00 (Modena E501), Y90-G00 (Shine R106), Y91-I00 (Note 3S), Y91-U00 (Torino R108) INTEX Models Added: Aqua 4G, Aqua Fish, Elit-E1 HAIER Models Added: Esteem L50, L61, Leisure L7 LYF Models Added: LS-5005 Water 4, LS-5007 Water 5, LS-5502 Wind 3, LS-5505 Water F1 OPPO Models Added: A11, A57, R8000, R9s, R9s Plus, X9000 VODAFONE Models Added: VFD900, VFD1400 WIKO Models Added: Freddy, Tommy2, Ufeel Prime, WIM, VIM Lite WILEYFOX Models Added: Storm, Swift, Swift 2, Swit 2 Plus, Swift 2X XIAOMI Models Added: Mi 5x Tiffany, Mi Max 2 Oxygen, Mi Note 3 Jason, Redmi Note 5A UggLite, Redmi Note 5A Prime Ugg YU Models Added: AO5510, YU5040, YU5510, YU5510A ZTE Models Added: Blade A711, Blade S6, Blade S6 Lite, Blade S6 Plus, Blade X9, V5 Pro VAR SPRD ARCHOS Models Added: 40 Neon, 50C Platinum, 50D Titanium BQ Models Added: BQS-4707, BQ-5501 CHERRY Models Added: Flare J1, Flare J1S, Flare Lite 2, Flare Lite Quad, Flare P1 Mini, Flare P1 Lite, Flare S5 Mini, Omega Lite 2, Touch HD EVERTEK Models Added: V1 Nano INNJOO Models Added: Halo 3G, Halo 2 3G, Halo Plus, Halo X INTEX Models Added: Aqua 4.0 3G, Aqua 4.0 4G, Aqua 4.5 Pro, Aqua 4G Mini, Aqua_Amaze+, Aqua Craze 2, Aqua Lions 4G, Aqua Q7N Pro, Aqua Pro 4G, Aqua Raze 2, Aqua S3, Aqua Selfie, Aqua Strong 5.1+, Aqua Style 3, Y2 Power, Cloud 4G Smart, Cloud M5 II, Cloud Matte, Cloud Scan FP, Cloud String HD LAVA Models Added: A50, A55 PHILIPS Models Added: S326, S337 TEXET Models Added: TM-4003, TM-4503, TM-5006, TM-5007, TM-5016 WIKO Models Added: Jerry, Sunny2, Sunny Max Download HERE |
The Following 7 Users Say Thank You to dyo For This Useful Post: |
09-27-2017, 08:18 | #2 (permalink) | |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Cherry mobile Flare Lite MT6572 Format Function Test done Quote:
The Following User Says Thank You to dyo For This Useful Post: |
09-27-2017, 09:26 | #3 (permalink) |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Samsung note Kies info function Test done Samsung GT-N7005 (Note LTE) at USB (COM51) [MODEM] {Kies Info} MODEMCON: OK MODEL : GT-N7005 PRODCODE: SGH-I717RWZTGY HIDVERS : N7005ZHMF1/N7005ZZHMF1/N7005ZHMF1/N7005ZHMF1 CONNECT : AT,MTP,MTP LOCKSTAT: NONE PRNUMBER: 639460815582 SW VERS : N7005ZHMF1/N7005ZZHMF1/N7005ZHMF1/N7005ZHMF1 IMEI 1 : 352013-05-217984-0 |
09-27-2017, 09:27 | #4 (permalink) |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | ADB Test ok RILSERN : R21D24AHZZR RILSWVER: N7005ZHMF1 RILCSCVER:N7005ZZHMF1 RILPRCODE:SGH-I717RWZTGY PRDBRAND: samsung PRDMODEL: GT-N7005 PRDNAME : GT-N7005 BLDVERS : 4.0.4 BLDDISID: IMM76D.ZHMF1 BLDPROD : GT-N7005 PRODBRD : MSM8660_SURF BRDPLATF: msm8660 HARDWARE: qcom USB CNFG: mtp,adb MMC1 CID: 1501004b594c30304d2565f143c111d2 Superuser Permissions Denied |
09-29-2017, 15:24 | #5 (permalink) |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | when i try to do something with spd i have this error SPRD SC7731C (eMMC) at USB Auto Select [SPRD] {Read Flash} BOOT: FDL1 and FDL2 from Default [DA] Hold Vol+, Vol- and Insert Cable to Switched OFF Device SROM: SPRD3 FDL1_BOOT Failed: FDL1 RCON |
09-29-2017, 16:04 | #6 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | LG H650E (Class / Zero LTE) at Auto Select Flash Port [LG FLASH 5] {Reset FRP} DL MODE : 2 DL REQM : 5 DL MODEL: LG-H650E DL SWVER: H65010c DL IMEI : 355879-07-078741-9 LF MODEL: LG-H650E LF SERNO: LGH650d1a9b403 LF SWVER: LGH650EAT-00-V10c-EUR-XX-FEB-02-2016+0 LF MINOS: MiniOS 3.0 LF OSVER: 5.1.1 LF IMEI : 355879-07-*****-9 LF DVPID: YE05S151130000974 LF SOCTY: msm8916 LF CABLE: USER Reset FRP Done in 00:06.304 |
The Following 4 Users Say Thank You to -=MR_Gsm=- For This Useful Post: |
09-30-2017, 03:05 | #7 (permalink) | |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Quote:
and not run (USB Port gone and not arrive again) So select .pac from same or similar phone Or Select FDL, using [DA] FDL's pair must have same name: blabla_FDL1 and blabla_FDL2 | |
The Following User Says Thank You to Sha For This Useful Post: |
09-30-2017, 03:41 | #8 (permalink) | |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | no firmware needed selecting DA from folder helps thanks read firmaware Myphone My28sdtv Quote:
Br: Dyo | |
The Following 2 Users Say Thank You to dyo For This Useful Post: |
