Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 08-21-2014, 13:06   #1 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
UFSx software problem
I have UFSt... almost every day i must do procedure with update software and install 1 file : DCTxBB5.ini
"Non Authorized Copy of Software Detected" why?
Old 08-22-2014, 07:51   #2 (permalink)
paulbs's Avatar
Member: 74719
Sonork: paulelectro
Thanks Meter: 181
by new UFS TURBO NO MORE PROBLEM
old box nead avery day update
Old 08-22-2014, 10:48   #3 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
And my old UFS stop connecting and updating without any reason.
UFST allmost every day i must update be couse of that UFSxBB5.ini which every day is bad. Even copied from yesterday to today is bad.
Waiting for Odia answer.
Old 08-23-2014, 06:46   #4 (permalink)
Member: 2082450
Thanks Meter: 1,454
Jusst take the registry backup on ufs panel, and when the error comes again, import that backup registry file.
Ur problem solved....
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 08-23-2014, 10:07   #5 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
Today without error.
I allready tried with backup time ago and it not help.
Old 08-23-2014, 11:06   #6 (permalink)
Member: 2082450
Thanks Meter: 1,454
Do u use more than one ufs box in ur pc.....?
Old 08-23-2014, 16:26   #7 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
My old UFS-HWK stop working without reason (stop updating) so i'm doomed to use UFSx.
Old 08-23-2014, 20:49   #8 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
What box you got UFST or UFSx3_HWK ?
For UFST in normal windows no need update box everyday I update it 3 month ago and all next update I do without any box update.
Mean that you got problem in your windows/computer not box that you need update everyday.
Old 08-23-2014, 22:30   #9 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
Win7x64 fresh, 2 weeks ago installed. Microsoft Essentials, Saras directory added to excluded. Nothing special.
I don't think that is computer problem.
Old 08-25-2014, 11:21   #10 (permalink)
Member: 2085623
Thanks Meter: 221
Box too not have that problem like you write I got about 10 freinds in Poland that use this box and never got problem like you with it.
Maybe box faulty then send to sellers to exchange.
Old 08-25-2014, 12:17   #11 (permalink)
mojahiudul's Avatar
Member: 1393008
Sonork: C0821FB9
Thanks Meter: 47
I have solution this problem by using usb 3.0 port and new cable. do not change usb port
use only one port which port use for update,
try this . inshah allah your problem will solved.
thanks
Old 10-13-2014, 11:08   #12 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
My problem still occure. Anyone have solved it in other way?
I almost every day need to update box and download one file from list: DctxBB5.ini
Old 10-14-2014, 07:04   #13 (permalink)
Crazy Poster
Member: 891371
Thanks Meter: 5
usb 3.0 port and new cable work for me....
Old 10-14-2014, 10:19   #14 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
I have problem with software , not with HW.
Old 10-14-2014, 12:34   #15 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,781
No need to update box again & again.After update make registry backup using panel & restore it again when box ask update.
Page generated in 0.24673 seconds with 8 queries
