03-17-2015, 17:43 | #1 (permalink) |
Freak Poster Join Date: Mar 2003 Age: 48
Member: 24115 Status: Offline Thanks Meter: 46 | Unlock Samsung 1280 - need drivers |
03-17-2015, 22:52 | #2 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Old phone like this not have 64bit drivers need use 32bit OS that all. All drivers you got in ufs_t support section, to enter it just press SUPPORT button in software. |
03-18-2015, 16:55 | #4 (permalink) |
Member: 24115 Status: Offline Thanks Meter: 46 | I found spd 32bit drivers but still can't unlock phone - read only info - PORT: UART ProdCode: GT-E1280RWASUW IMEI: 353553-05- MSLA: RV1FA278BW SWVE: E1280XXNA2 UNID: 030C030009091725 FLID: GD25Q64 DATE: 01-17-2014 20:53:49 HWVE: MP 0.501 SERN: 00000000000 PREC: SUW PROV: NONE MSL Auth Failed, Use [Read E2P] to Read MSL Security PORT: UART Insert Cable to Switched OFF Device SROM_BOOT Failed: SROM_BOO1 NACK |
03-24-2015, 12:41 | #5 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | Quote:
Use [Read E2P] only click in read E2P. not need more. | |
12-17-2015, 09:52 | #6 (permalink) |
Freak Poster Join Date: Jan 2013 Location: everywhere
Member: 1868823 Status: Offline Thanks Meter: 47 | hi Samsung 1280 is a spd phone you need to install corect drivers if you are using windows xp is easy to instal on windows 7 is not so easy beacuse windows 7 is not installing drivers corectly and ports are instabile ,i used xp and was easy to unlock this model ,if you still have problems with the phone tri to flash the phone ba careful when flashing , and then tri unlock |
