04-09-2020, 20:47 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Vivo 1818 v15 pro frp show error {team check inside} https://imgur.com/a/wV4Ew66 SEE LOGS BELOW Code: Var VIVO-1818 (V15 Pro 1818 LTE DS PD1832F) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM34) SAHARA VERS: 2.1 SAHARA HWID: 000950E100730003 [SDM675-SM6150] SAHARA HASH: A7DF36FFD7AB557C67A6C26675E2795C922CF671308CFD7169BEDB84424C862B SAHARA HASH: C7B646907DD79989578590FB6370A940A7DF36FFD7AB557C67A6C26675E2795C SAHARA HASH: 922CF671308CFD7169BEDB84424C862BC7B646907DD79989578590FB6370A940 SAHARA HASH: A7DF36FFD7AB557C67A6C26675E2795C922CF671308CFD7169BEDB84424C862B SAHARA HASH: C7B646907DD79989578590FB6370A94000000000000000000000000000000000 SAHARA SERN: AB50E8BD (2874206397) SAHARA PROG: prog_emmc_ufs_firehose_Sm6150_ddr_vivo1.elf SAHARA PRID: SA22A289623250AAE2 FHINFO Failed: 4, 30 FHPROG SZFT: 0 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: FHPROG CHSN: 0xAB50E8BD FHPROG MEMT: eMMC FHINFO Failed: 4, 30 <log value="INFO: Binary build date: Feb 19 2019 @ 00:13:10" /> <log value="INFO: Binary build date: Feb 19 2019 @ 00:13:10" /> <log value="INFO: Chip serial num: 2874206397 (0xab50e8bd)" /> <log value="INFO: Supported Functions (17):" /> <log value="INFO: program" /> <log value="INFO: read" /> <log value="INFO: nop" /> <log value="INFO: patch" /> <log value="INFO: configure" /> <log value="INFO: setbootablestoragedrive" /> <log value="INFO: erase" /> <log value="INFO: power" /> <data><nop value="ping" /></data> <log value="INFO: Calling handler for nop" /> <log value="INFO: Binary build date: Feb 19 2019 @ 00:13:10" /> <log value="INFO: Chip serial num: 2874206397 (0xab50e8bd)" /> <log value="INFO: Supported Functions (17):" /> <log value="INFO: program" /> <log value="INFO: read" /> <log value="INFO: nop" /> <log value="INFO: patch" /> <log value="INFO: configure" /> <log value="INFO: setbootablestoragedrive" /> <log value="INFO: erase" /> <log value="INFO: power" /> <log value="INFO: firmwarewrite" /> <log value="INFO: getstorageinfo" /> <log value="INFO: benchmark" /> <log value="INFO: emmc" /> <log value="INFO: ufs" /> <log value="INFO: fixgpt" /> <log value="INFO: query_auth_id_info" /> <log value="INFO: parse_sig_ex" /> <log value="INFO: parse_sig" /> <log value="INFO: End of supported functions 17" /> <response value="ACK" rawmode="false" /> <data><configure MaxPayloadSizeToTargetInBytes="49152" MemoryName="eMMC" TargetName="8x26"/></data> <log value="INFO: Calling handler for configure" /> <log value="INFO: Storage type set to value eMMC" /> <response value="ACK" MemoryName="eMMC" MinVersionSupported="1" Version="1" MaxPayloadSizeToTargetInBytes="49152" MaxPayloadSizeToTargetInBytesSupported="1048576" MaxXMLSizeInBytes="4096" DateTime="Feb 19 2019 - 00:13:10" /> <data><configure MaxPayloadSizeToTargetInBytes="131072" MemoryName="eMMC" TargetName="8x26"/></data> <log value="INFO: Calling handler for configure" /> <log value="INFO: Storage type set to value eMMC" /> <response value="ACK" MemoryName="eMMC" MinVersionSupported="1" Version="1" MaxPayloadSizeToTargetInBytes="131072" MaxPayloadSizeToTargetInBytesSupported="1048576" MaxXMLSizeInBytes="4096" DateTime="Feb 19 2019 - 00:13:10" /> <data><getstorageinfo physical_partition_number="0" /></data> <log value="INFO: Calling handler for getstorageinfo" /> <log value="ERROR: Failed to open the SDCC Device slot 0 partition 0" /> <log value="ERROR: Failed to open the device:1 slot:0 partition:0 error:0" /> <log value="ERROR: OPEN handle NULL and no error, weird 344400420" /> <log value="ERROR: Failed to open device, type:eMMC, slot:0, lun:0 error:3" /> <response value="NAK" rawmode="false" /> <data><getstorageinfo physical_partition_number="0" /></data> <log value="INFO: Calling handler for getstorageinfo" /> <log value="ERROR: Failed to open the SDCC Device slot 0 partition 0" /> <log value="ERROR: Failed to open the device:1 slot:0 partition:0 error:0" /> <log value="ERROR: OPEN handle NULL and no error, weird 344400420" /> <log value="ERROR: Failed to open device, type:eMMC, slot:0, lun:0 error:3" /> <response value="NAK" rawmode="false" /> <data><read SECTOR_SIZE_IN_BYTES="512" num_partition_sectors="2" start_sector="0" physical_partition_number="0" read_back_verify="0"/></data> <log value="INFO: Calling handler for read" /> FHPROG Read Fail: -2, FRP not Found on this Device Reset FRP Failed HOW SOLVE IT OR ANY FIX CUSTOMER WILL KEEP PHONE WITH ME FOR 3DAYS ONLY STARTING FROM TODAY.. Last edited by johnoroo37; 04-09-2020 at 20:53. |
04-10-2020, 15:55 | #2 (permalink) |
Freak Poster Join Date: Nov 2015
Member: 2489055 Status: Offline Thanks Meter: 71 | frp partition write protected in latest vivo phones Vivo V15 pro needs auth to read write only AFtool can do UFST not support this model |
The Following User Says Thank You to hardnsoft67 For This Useful Post: |
