10-12-2018, 14:48 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 57
Member: 137980 Status: Offline Thanks Meter: 168 | Vivo v5s flashing error MTK MT6750 (eMMC) at USB Auto Select [MTK] {Write Flash} Scatter : MT6750_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_0003 (BROM) DA Agent : MTK_AllInTwo_DA.bin BR ComPort: COM7 BR Asic Id: MT0326 [0000] Alias: MT6755 BR Asic Sw: 8A00 CB00 0001 0000 BR Fuse Id: 00001442 BR ME_ID : E3F4CCD344F2C8DCF02B152DB2E31649 BR Secured: 05 [SBC DAA] DA AgentId: SA13A3C944BB0F42EF DA Version: MTK_AllInOne_DA_v3.3001.2018-05-22.16:52_440462. BR_RUN_D5 Error: -1 -2 Possible not Valid DA Agent BR_BOOT Error: -15 Select Correct Auth File using [Add File] Button Flashing Canceled DA_SHUTDOWN Error: -1 MTK MT6750 (eMMC) at USB Auto Select [MTK] {Write Flash} Scatter : MT6750_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_0003 (BROM) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM7 BR_SYNC Error: -1 BR_BOOT Error: -3 Flashing Canceled DA_SHUTDOWN Error: -2 Last USB Exception: 0x001F A device attached to the system is not functioning. Can be Cable Problem or Battery Low ! MTK MT6750 (eMMC) at USB [FASTBOOT] {Read FB Info} <<< STOP >>> MTK MT6750 (eMMC) at USB Auto Select [MTK] {Write Flash} Scatter : MT6750_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_0003 (BROM) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM7 BR Asic Id: MT0326 [0000] Alias: MT6755 BR Asic Sw: 8A00 CB00 0001 0000 BR Fuse Id: 00001442 BR ME_ID : E3F4CCD344F2C8DCF02B152DB2E31649 BR Secured: 05 [SBC DAA] DA AgentId: SA86FBA18A078C6693 DA Version: MTK_AllInOne_DA_v3.3001.00.00. BR_RUN_D5 Error: -1 -2 Possible not Valid DA Agent BR_BOOT Error: -15 Select Correct Auth File using [Add File] Button Flashing Canceled DA_SHUTDOWN Error: -1 |
10-13-2018, 01:05 | #2 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Of corse error, because you select wrong model for secure boot Always read whats.new file: " Before Using [MTK], [QC], [SPRD] Tabs Always Check [Var] Tab for predefined Models. In this way will be used Correct Loaders and settings for Secure Boot. Note: Use of wrong Loaders can cause BLINK, BRICK or IMEI loose Issues! " So select VIVO-V5S Model in [Var] Tab and use patch A9 for 1.0.5.7 |
The Following User Says Thank You to Sha For This Useful Post: |
