08-05-2018, 05:43 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | vivo Y69 flashing problem Var VIVO-Y69 (Y69 LTE DS PD PD1705F) at USB Auto Select [MTK] {Write Flash} Scatter : MT6750_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_VIV5.bin BR ComPort: COM25 BR Asic Id: MT0326 [0000] Alias: MT6755 BR Asic Sw: 8A00 CB00 0001 0000 BR Fuse Id: 00001442 BR Secured: 5 [SBC DAA] DA Version: MTK_AllInOne_DA_v3.3001.00.00. BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Flashing Canceled DA_SHUTDOWN Error: -1 Last USB Exception: 0x03E3 The I/O operation has been aborted because of either a thread exit or an application request. Can be Cable Problem or Battery Low ! |
The Following User Says Thank You to trio1 For This Useful Post: |
08-05-2018, 05:56 | #4 (permalink) |
Member: 757799 Status: Offline Thanks Meter: 782 | Var VIVO-Y69 (Y69 LTE DS PD PD1705F) at USB Auto Select [MTK] {Write Flash} Scatter : MT6750_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_PL_VY69.bin BR ComPort: COM25 BR Asic Id: MT0326 [0000] Alias: MT6755 BR Asic Sw: 8A00 CB00 0001 0000 BR Fuse Id: 00001442 BR Secured: 5 [SBC DAA] DA Version: MTK_AllInOne_DA_v3.3001.00.00. BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Flashing Canceled DA_SHUTDOWN Error: -1 Last USB Exception: 0x03E3 The I/O operation has been aborted because of either a thread exit or an application request. Can be Cable Problem or Battery Low ! |
10-06-2019, 16:22 | #8 (permalink) | |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Quote:
Please have your device 60% battery on it... | |
10-06-2019, 16:33 | #9 (permalink) | |
Download this 3 file and use it in correct path post result... Ufst | |
10-06-2019, 16:37 | #10 (permalink) |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | DA PREL AUTH file is Here just wait final update will be set out soon, test is still on progress have patience team is working out to give you good update BR. |
The Following User Says Thank You to dyo For This Useful Post: |
