05-09-2017, 16:31 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: I.R.IRAN
Member: 1785529 Status: Offline Sonork: 100.1656084 Thanks Meter: 53 | you can make a xml file via easy jtag and flash that xml file with ufs-t how ? its free quide : first you need an full dump of device as you know writing full dumk takes too much time but you can go to read by vendor tab in easy jtag and choose qualcom vendor and choose find partition table from file (you can choose from device ) and check wich files that you want and make a xml back up and connect your device in edl or saharam mode and write that back up too much fast and easy notice:you may you cannot use that back up without editing with another tool except usf-t |
The Following User Says Thank You to kvahid87 For This Useful Post: |
05-09-2017, 16:33 | #2 (permalink) |
Member: 1785529 Status: Offline Sonork: 100.1656084 Thanks Meter: 53 | for example read of g730 -u30 back up via easy jtag: Analyzing Image: EMMC_ROM1_H4G1d_27495065_00000000_E7000000.bin Vendor: Qualcomm Searching GPT ... GPT header is found and is valid GPT header successfully parsed Backup partition: 8xxx_msimage Address: 000000004400, size: 000000000000 Reading partition... Done reading partition. Read speed: 0.00 Kb/s 8xxx image is blank. Skipped XML-file created successfully Backup partition: PrimaryGPT Address: 000000000000, size: 000000004400 GPTHeader is valid Partition name: sbl1 Address: 000000004400, size: 000000080000 Reading partition... Done reading partition. Read speed: 76985.57 Kb/s Partition name: sdi Address: 000000084400, size: 000000008000 Reading partition... Done reading partition. Read speed: 15217.02 Kb/s Partition name: DDR Address: 000000400000, size: 000000008000 Reading partition... Done reading partition. Read speed: 15307.19 Kb/s Partition name: rpm Address: 000000800000, size: 00000007D000 Reading partition... Done reading partition. Read speed: 18006.70 Kb/s Partition name: tz Address: 00000087D000, size: 00000007D000 Reading partition... Done reading partition. Read speed: 119415.56 Kb/s Partition name: aboot Address: 0000008FA000, size: 000000576000 Reading partition... Done reading partition. Read speed: 83202.04 Kb/s Partition name: pad Address: 000000E70000, size: 000000100000 Reading partition... Done reading partition. Read speed: 118587.88 Kb/s Partition name: oeminfo Address: 000000F70000, size: 000004000000 Reading partition... Done reading partition. Read speed: 120472.42 Kb/s Partition name: modemst1 Address: 000004F70000, size: 000000400000 Reading partition... Done reading partition. Read speed: 94527.82 Kb/s Partition name: modemst2 Address: 000005370000, size: 000000400000 Reading partition... Done reading partition. Read speed: 131133.40 Kb/s Partition name: modem Address: 000005800000, size: 000006000000 Reading partition... Done reading partition. Read speed: 115782.23 Kb/s Partition name: fsg Address: 00000B800000, size: 000000400000 Reading partition... Done reading partition. Read speed: 22498.94 Kb/s Partition name: fsc Address: 00000BC00000, size: 000000000400 Reading partition... Done reading partition. Read speed: 286.72 Kb/s Partition name: ssd Address: 00000BC00400, size: 000000002000 Reading partition... Done reading partition. Read speed: 6201.62 Kb/s Partition name: log Address: 00000BC02400, size: 000002000000 Reading partition... Done reading partition. Read speed: 38305.63 Kb/s Partition name: bkbootup Address: 00000E000000, size: 000004000000 Reading partition... Done reading partition. Read speed: 102401.53 Kb/s Partition name: persist Address: 000012000000, size: 000000800000 Reading partition... Done reading partition. Read speed: 55753.77 Kb/s Partition name: boot Address: 000012800000, size: 000000C00000 Reading partition... Done reading partition. Read speed: 34738.55 Kb/s Partition name: recovery Address: 000013400000, size: 000001000000 Reading partition... Done reading partition. Read speed: 79542.84 Kb/s Partition name: cust Address: 000014400000, size: 000010000000 Reading partition... Done reading partition. Read speed: 72739.54 Kb/s Partition name: cache Address: 000024400000, size: 00000C000000 Reading partition... Done reading partition. Read speed: 65094.69 Kb/s Partition name: misc Address: 000030400000, size: 000000400000 Reading partition... Done reading partition. Read speed: 34276.71 Kb/s Partition name: system Address: 000030800000, size: 000040000000 Reading partition... Done reading partition. Read speed: 76432.16 Kb/s Partition name: userdata Address: 000070800000, size: 000040000000 Reading partition... Done reading partition. Read speed: 74952.83 Kb/s Partition name: grow Address: 0000B0800000, size: 0000367FBE00 Reading partition... Done reading partition. Read speed: 85836.64 Kb/s All done |
The Following 2 Users Say Thank You to kvahid87 For This Useful Post: |
05-09-2017, 16:38 | #3 (permalink) |
Member: 1785529 Status: Offline Sonork: 100.1656084 Thanks Meter: 53 | log of flashing that file with ufs-t (plz add g730-u30 i choosed the same model g630-u20) Huawei G630-U20 (Ascend G630 3G) at Auto Select Flashing Port [SAHARA] {Write Flash} Flash Bundle: rawprogram0.xml SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8x10_hua.mbn FHPROG SZFT: 4096 FHPROG SZTT: 49152 FHPROG SPTT: 49152 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8x10 FHPROG MEMT: eMMC Partitions to Write: 21 (3.58 GB) FWRITE DONE: ST 0x0000000022 sbl1 512 KB FWRITE DONE: ST 0x0000000422 sdi 32 KB FWRITE DONE: ST 0x0000002000 DDR 32 KB FWRITE DONE: ST 0x0000004000 rpm 500 KB FWRITE DONE: ST 0x00000043E8 tz 500 KB FWRITE DONE: ST 0x00000047D0 aboot 5.46 MB FWRITE DONE: ST 0x0000007380 pad 1024 KB FWRITE DONE: ST 0x0000007B80 oeminfo 64 MB FWRITE DONE: ST 0x000002C000 modem 96 MB FWRITE DONE: ST 0x000005E002 ssd 8 KB FWRITE DONE: ST 0x000005E012 log 32 MB FWRITE DONE: ST 0x0000070000 bkbootup 64 MB FWRITE DONE: ST 0x0000090000 persist 8 MB FWRITE DONE: ST 0x0000094000 boot 12 MB FWRITE DONE: ST 0x000009A000 recovery 16 MB FWRITE DONE: ST 0x00000A2000 cust 256 MB FWRITE DONE: ST 0x0000122000 cache 192 MB FWRITE DONE: ST 0x0000184000 system 1024 MB FWRITE DONE: ST 0x0000384000 userdata 1024 MB FWRITE DONE: ST 0x0000584000 grow 871.98 MB FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB FHSETD DONE: Ok FHREST DONE: Ok Write Flash Done in: 08:00.418 |
05-09-2017, 22:31 | #4 (permalink) | |
Insane Poster Join Date: Nov 2016
Member: 2647618 Status: Offline Thanks Meter: 18 | Nice-- Quote:
05-10-2017, 05:58 | #5 (permalink) | |
Member: 1785529 Status: Offline Sonork: 100.1656084 Thanks Meter: 53 | Quote:
but remember that you can just use it with ufs .. qpst and some other tools cannot flash it without editing | |
05-10-2017, 09:48 | #6 (permalink) |
Member: 1785529 Status: Offline Sonork: 100.1656084 Thanks Meter: 53 | huawei g630-u10-u20 backup without userdata and system plz upgrade firmware after writing this file with dload update file https://mega.nz/#!p4gCADjZ!IxT3C_88W...WlLTA4urkTjI5g |
The Following 4 Users Say Thank You to kvahid87 For This Useful Post: |
