07-03-2014, 06:22 | #1 (permalink) |
No Life Poster Join Date: Sep 2012 Location: INDIA Age: 31
Member: 1818374 Status: Offline Sonork: 100.1640346 Thanks Meter: 309 | LAVA IRIRS 408 E FORMAT DONE Mobile doctor box new update 2.49 =======UPDATES======= 2014.07.1 VER.2.49 1.MTK add 6575 font support 2.MTK Nand improved literacy 3.MTK add 6583 font support, improved write. 4.MTK improved file cryptanalysis 5.MTK improve Android formatting. 6.SPD improve Nand read font 7.SPD add 6531 font support 8.SPD add 8810/6820 font support 9.Android improvement in image barcode 10 Improved MTK interface, modify operation and error description. ---------------------------------------------------------------------------------------------------------------- 2014.05.19 VER.2.48 1.MTK add 6592 support 2.MTK add support for Android wire brush factory data Improved formatting 3.MTK Android 4.SPD add 6500 support 5.SPD modified 6530 format 6.SPD add 7710 to write the original data 7.SPD add 8810/6820 clear password (rd unlock-> clean passcode) 8.Android modify unlocked, add sound and picture lock lift 9.Android add Google lock delete 10.Android add samsung Reset Gmail (MTP mode) 11.Android add ROOT models support. 12.Android add samsung Writing library support -------------------------------------------------------------------------------------------------------------- 2014.04.17 VER.2.47 1.SPD add 8810/6820 font support 2.SPD modified format 3.SPD improve the original data is written 4.Android modify sansung read information, unlock. 5.Android add ROOT models 6.Android add APK installation 7.Coolsand add literacy NV -------------------------------------------------------------------------------------------------------------- 2014.03.03 VER.2.46 1.MTK modify Android Root can not be written in one key BUG 2.MTK modify USB into the meta model BUG 3.SPD improve the original data written 4.SPD add 8810/6820 format boot support 5.Android add sansung read information, unlock, restore factory settings support (MTP mode) 6.Android add sansung efs backup and restore (ADB mode) -------------------------------------------------------------------------------------------------------------- 2014.02.17 VER.2.45 1.SPD add 8810/6820 font support. 2.SPD modify the boot to change string formatting Android changed after 3.MTK add strings to clean boot logo, restore factory settings after the serial number is no longer missing 4.MTK add new and improved Android string methods. 5.Android added directly read Pattern (graphical code) -------------------------------------------------------------------------------------------------------------- 2014.01.21 VER.2.44 1.SPD supports 8810/6820 full flash read and write. 2.SPD modification 8810/6820 format, ROOT, NV function 3.SPD modify 6531A format support. 4.MTK add the chip supports NOKIA MTK -------------------------------------------------------------------------------------------------------------- 2013.12.24 VER .2.43 1.MTK modified Android system write bug 2.MTK modified Android system format Bug 3.Android Add ADB ROOT add new models support -------------------------------------------------------------------------------------------------------------- 2013.12.2 VER.2.42 1.MTK add support for 6572 Nand font font 2.MTK modify Emmc write 3.Android Add ADB ROOT4.Android Add Fastboot userdata and cache cleanup 5.Android add fastboot reboot under normal mode 6.Android modify some BUG. |
The Following User Says Thank You to mahaprobhu For This Useful Post: |
