WorldGSMcodes World's Leading unlock code source |
07-06-2015, 18:43 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Canada
Member: 2006815 Status: Offline Sonork: 1596960 Thanks Meter: 122 | [2015] How to Unlock AT&T HTC One (M8) Network Code to work with Optus,Straight Talk The new HTC One (M8) comes with a radically different than all else 'Duo' camera (this refers to the two rear cameras on its back) that allows you things like selecting the focus of an image after you capture it.The new One also comes with the latest Snapdragon 801 quad-core system chip, an even more intense aluminum unibody construction, and 25% more powerful BoomSound front-facing stereo speakers. And it's not just that - HTC has improved the phone all around, even adding expandable storage via microSD cards of up to 128 gigs. Actually, the only change we can think of in the new One that could possibly bring forth some negativism is the increased overall footprint of the device - it's just larger and a bit bulkier. HTC One (M8) Sim Unlocking : Unlock AT&T HTC One (M8) to use any where in the world with any supported service provider like Optus Australia Brasil, Straight talk, FamilyMobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo HTC One (M8) Unlocking instructions: 1: Turn on phone with Not Accepted SIM card. 2: A menu will pop up to Insert the code. 3: Insert the provided code and press OK 4: Device is now unlocked. How to Factory Reset/ Hard Reset HTC One (M8): How to Reset HTC One (M8) pattern lock: WARNING ! Hard Reset will erase all of your data All described operations you are doing at your own risk. First Method:
Second Method:
How to Update HTC One (M8) to latest Firmware: Tip: Visit www.htc.com/us/go/htc-software-updates/ for news and details about your phone's software updates. Checking Your System Software Version: Before installing a system software update, you can check first what Android and HTC Sense® versions you have on your phone.
Enabling Automatic Updates You can choose to automatically download and install software updates for HTC or mobile operator apps.
Installing a Software Update When Internet connection is on and there's a new software update available, the update notification icon appears in the status bar.
After updating, HTC One will restart. Installing an Application Update: When Internet connection is on and there's an available update for your HTC or mobile operator apps, the update notification icon appears in the status bar.
Installing App Updates from Google Play: Some HTC apps and third-party apps get updated with improvements and bug fixes through Google Play. You can manually update apps or set your phone to automatically download and install app updates when available.
Tip: In Play Store, tap > Settings > Auto-update apps to choose how you want Google Play to update your apps. Checking For Updates Manually
How to Root HTC One (M8): WARNING ! You will lose all your data and it is possible that you may brick your device All described operations you are doing at your own risk. Step 1. Go to Settings -> Power and make sure “Fast Boot” is checked OFF. Step 2. Power off your HTC One M8 then hold down Volume Down and Power buttons for about 3 seconds until you see the Boot Loader Menu. Step 3. Hit the Power button once and you should now be in FAST BOOT mode. Step 4. Connect a micro-USB cable from your HTC One M8 to your computer. Step 5. Download fastboot.zip and unzip the file, you should get a folder called “Fast Boot” in your Downloads directory. Download fastboot.zip Step 6. Next, go to the CWM/TWRP recoveries section of HTCOneRoot.com and download the appropriate CWM or TWRP recovery for your HTC One M8 model. Step 7. Copy the downloaded CWM or TWRP recovery image (file ending in .img) to the Fast Boot folder you unzipped earlier. Step 8. If using Mac or Linux, you can skip this step as no drivers are needed. If using Windows, open Device Manager (If you don’t know how to open Device Manager, please Google it!) and check that you have “My HTC” or “Android ADB”. If you don’t, you need to install HTC drivers, download HTC One M8 Drivers and run it then come back to this step. Step 9. Open a command prompt or terminal. For Windows, simply type “cmd” in the search bar. For Windows: fastboot oem get_identifier_token For Mac: ./fastboot-mac oem get_identifier_token For Linux: sudo ./fastboot-linux oem get_identifier_token Step 10. Copy the identifier token to your clipboard. If you don’t know how to do this, see my video tutorial. Step 11. Next, go to HTCDev.com and choose “Unlock Bootloader” and hit “Get Started”. You will need to register for the site first if this is the first time using the site. Then choose “HTC One (M8)” and click on “Begin Unlock Bootloader”. Step 12. Agree to the terms and click on “Proceed to Unlock Instructions”. Step 13. Scroll all the way down and click on “Proceed To Step 5″. Step 14. Scroll down and paste your identifier token you copied earlier in the box where is says, “My Device Identifier Token”. Step 15. You should get a message like below if it was successful. If not, try Step 10 again and watch my video tutorial that shows you how to copy it exactly. Step 16. Check your e-mail inbox and you should have gotten an e-mail from HTC with an unlock code file. Download this file and copy it to your fastboot folder. Step 17. Next type in command prompt/terminal: TYPE For Windows: fastboot flash unlocktoken Unlock_code.bin For Mac: ./fastboot-mac flash unlocktoken Unlock_code.bin For Linux: sudo ./fastboot-linux flash unlocktoken Unlock_code.bin Step 18. Go to your HTC One M8 screen then use Volume key to choose “Yes” then hit the Power button. Your HTC One M8 should reboot in couple seconds. Step 19. Once rebooted, sign in to your HTC One M8. Step 20. Repeat Step 1,go to Settings->Power and make sure “Fast boot” is checked OFF. Step 21. Connect your HTC One M8 to your computer and copy over the SuperSU zip file. Download SuperSU zip file Step 22. Repeat Step 2 thru 4 and reboot your HTC One M8 into fastboot mode. Step 23. Next, type: Windows: fastboot flash recovery PutImageFileHere.img Replace “PutImageFileHere.img” with the image file you downloaded earlier in Step 6 and 7. Then Type: fastboot erase cache For Mac, replace “fastboot” with “./fastboot-mac”. For Linux, replace “fastboot” with “sudo ./fastboot-linux”. Step 24. Choose HBOOT and select Power button on your HTC One M8′s screen. Step 25. Choose “RECOVERY” and hit the Power button. Step 26. You should now be in CWM or TWRP Recovery. For CWM Recovery, choose “install from zip” and for TWRP, choose “Install” then find the SuperSU zip file and install it. Step 27. Once rebooted, you should find SuperSU app in your app drawer. Congratulations, you’ve successfully rooted your HTC One M8! You can verify you have full root by downloading and running a rooted app such as Titanium Backup app on Play Store. |
