Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > WorldGSMcodes
WorldGSMcodes World's Leading unlock code source
Old 07-06-2015, 18:43   #1 (permalink)
Member: 2006815
Sonork: 1596960
Thanks Meter: 122
Thumbs up [2015] How to Unlock AT&T HTC One (M8) Network Code to work with Optus,Straight Talk
HTC One (M8) Overview :
The new HTC One (M8) comes with a radically different than all else 'Duo' camera (this refers to the two rear cameras on its back) that allows you things like selecting the focus of an image after you capture it.The new One also comes with the latest Snapdragon 801 quad-core system chip, an even more intense aluminum unibody construction, and 25% more powerful BoomSound front-facing stereo speakers. And it's not just that - HTC has improved the phone all around, even adding expandable storage via microSD cards of up to 128 gigs. Actually, the only change we can think of in the new One that could possibly bring forth some negativism is the increased overall footprint of the device - it's just larger and a bit bulkier.
HTC One (M8) Sim Unlocking :
Unlock AT&T HTC One (M8) to use any where in the world with any supported service provider like
Optus Australia Brasil, Straight talk, FamilyMobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo
Only at
http://www.WorldGSMCodes.com/
Click here to buy Unlock code
HTC One (M8) Unlocking instructions:
1: Turn on phone with Not Accepted SIM card.
2: A menu will pop up to Insert the code.
3: Insert the provided code and press OK
4: Device is now unlocked.
How to Factory Reset/ Hard Reset HTC One (M8):
How to Reset HTC One (M8) pattern lock:
WARNING !
Hard Reset will erase all of your data
All described operations you are doing at your own risk.
First Method:
  1. Switch off your device.
  2. Next press and hold Volume Down + Power button.
  3. When you see the three Android images, then release held keys.
  4. Then press Volume Down to select option "Factory reset", and press Power button to confirm.
  5. Good job!
Second Method:
  1. Switch on the device.
  2. Then from Main Menu go to Settings and tap Backup & reset.
  3. Next choose Reset phone and select Erase all data.
  4. Tap OK to confirm your choice.
  5. Success!
How to Update HTC One (M8) to latest Firmware:
Tip: Visit www.htc.com/us/go/htc-software-updates/ for news and details about your phone's software updates.
Checking Your System Software Version:
Before installing a system software update, you can check first what Android and HTC Sense® versions you have on your phone.
  • Go to Settings, and then tap About.
  • Tap Software information.
Enabling Automatic Updates
You can choose to automatically download and install software updates for HTC or mobile operator apps.
  • Tap Software updates.
  • To save on data usage, you can choose to update through Wi-Fi only.
  • Choose whether to auto-download system updates, app updates, or both. App updates are installed automatically. You'll still need to confirm when to install system software updates.
Installing a Software Update
When Internet connection is on and there's a new software update available, the update notification icon appears in the status bar.
  • Slide the Notifications panel open, and then tap the system update notification.
  • If you don't want to download the update using your data connection, select Update over Wi-Fi only.
  • Tap Download.
  • When download is complete, select Install now, and then tap OK.
After updating, HTC One will restart.
Installing an Application Update:
When Internet connection is on and there's an available update for your HTC or mobile operator apps, the update notification icon appears in the status bar.
  • Slide the Notifications panel open, and then tap the update notification.The Updates screen opens with the list of application updates to be installed.
  • Tap an item to view its details,and then tap .
  • When you're done reviewing the updates, tap Install. You'll be asked to restart HTC One if needed.
Installing App Updates from Google Play:
Some HTC apps and third-party apps get updated with improvements and bug fixes through Google Play. You can manually update apps or set your phone to automatically download and install app updates when available.
  • Open the Play Store app.
  • Tap to open the slide out menu.
  • Tap My apps.You'll a list of apps installed on your phone.
  • Under Updates, tap an app.
  • Tap Update.
  • Tap Accept.
Tip: In Play Store, tap > Settings > Auto-update apps to choose how you want Google Play to update your apps.
Checking For Updates Manually
  • Tap Software updates. HTC One checks if updates are available.
How to Root HTC One (M8):
WARNING !
You will lose all your data and it is possible that you may brick your device
Step 1. Go to Settings -> Power and make sure “Fast Boot” is checked OFF.
Step 2. Power off your HTC One M8 then hold down Volume Down and Power buttons for about 3 seconds until you see the Boot Loader Menu.
Step 3. Hit the Power button once and you should now be in FAST BOOT mode.
Step 4. Connect a micro-USB cable from your HTC One M8 to your computer.
Step 5. Download fastboot.zip and unzip the file, you should get a folder called “Fast Boot” in your Downloads directory.
Step 6. Next, go to the CWM/TWRP recoveries section of HTCOneRoot.com and download the appropriate CWM or TWRP recovery for your HTC One M8 model.
Step 7. Copy the downloaded CWM or TWRP recovery image (file ending in .img) to the Fast Boot folder you unzipped earlier.
Step 8. If using Mac or Linux, you can skip this step as no drivers are needed. If using Windows, open Device Manager (If you don’t know how to open Device Manager, please Google it!) and check that you have “My HTC” or “Android ADB”. If you don’t, you need to install HTC drivers, download HTC One M8 Drivers and run it then come back to this step.
Step 9. Open a command prompt or terminal. For Windows, simply type “cmd” in the search bar.
For Windows:
fastboot oem get_identifier_token
For Mac:
./fastboot-mac oem get_identifier_token
For Linux:
sudo ./fastboot-linux oem get_identifier_token
Step 10. Copy the identifier token to your clipboard. If you don’t know how to do this, see my video tutorial.
Step 11. Next, go to HTCDev.com and choose “Unlock Bootloader” and hit “Get Started”. You will need to register for the site first if this is the first time using the site.
Then choose “HTC One (M8)” and click on “Begin Unlock Bootloader”.
Step 12. Agree to the terms and click on “Proceed to Unlock Instructions”.
Step 13. Scroll all the way down and click on “Proceed To Step 5″.
Step 14. Scroll down and paste your identifier token you copied earlier in the box where is says, “My Device Identifier Token”.
Step 15. You should get a message like below if it was successful. If not, try Step 10 again and watch my video tutorial that shows you how to copy it exactly.
Step 16. Check your e-mail inbox and you should have gotten an e-mail from HTC with an unlock code file. Download this file and copy it to your fastboot folder.
Step 17. Next type in command prompt/terminal: TYPE
For Windows:
fastboot flash unlocktoken Unlock_code.bin
For Mac:
./fastboot-mac flash unlocktoken Unlock_code.bin
For Linux:
sudo ./fastboot-linux flash unlocktoken Unlock_code.bin
Step 18. Go to your HTC One M8 screen then use Volume key to choose “Yes”
then hit the Power button. Your HTC One M8 should reboot in couple seconds.
Step 19. Once rebooted, sign in to your HTC One M8.
Step 20. Repeat Step 1,go to Settings->Power and make sure “Fast boot” is checked OFF.
Step 21. Connect your HTC One M8 to your computer and copy over the SuperSU zip file.
Download SuperSU zip file
Step 22. Repeat Step 2 thru 4 and reboot your HTC One M8 into fastboot mode.
Step 23. Next, type:
Windows:
fastboot flash recovery PutImageFileHere.img
Replace “PutImageFileHere.img” with the image file you downloaded earlier in Step 6 and 7.
Then Type:
fastboot erase cache
For Mac, replace “fastboot” with “./fastboot-mac”.
For Linux, replace “fastboot” with “sudo ./fastboot-linux”.
Step 24. Choose HBOOT and select Power button on your HTC One M8′s screen.
Step 25. Choose “RECOVERY” and hit the Power button.
Step 26. You should now be in CWM or TWRP Recovery. For CWM Recovery, choose “install from zip” and for TWRP, choose “Install” then find the SuperSU zip file and install it.
Step 27. Once rebooted, you should find SuperSU app in your app drawer. Congratulations, you’ve successfully rooted your HTC One M8!
You can verify you have full root by downloading and running a rooted app such as Titanium Backup app on Play Store.
Page generated in 0.18103 seconds with 8 queries
