WorldGSMcodes World's Leading unlock code source |
07-01-2015, 20:12 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Canada
Member: 2006815 Status: Offline Sonork: 1596960 Thanks Meter: 122 | [2015] How to Unlock AT&T Nokia Lumia 830 Network Code for Vodafone Australia,Optus Cómo desbloquear AT & T Nokia Lumia 830 Código de red para Vodafone Australia, Optus NOKIA Lumia 830 Overview : The successor to the Lumia 820 is another colorful Windows Phone with signature characteristics like a Lumia 1020-like 10MP PureView rear camera with OIS, a removable back cover, and hardware capacitive buttons. Designed as an affordable high-end device, the Lumia 830 houses a 5-inch 720p panel, and it's powered by a quad-core Snapdragon CPU. It runs on Windows Phone 8.1 with the Lumia Denim update. NOKIA Lumia 830 Sim Unlocking : Unlock Bell NOKIA Lumia 830 to use any where in the world with any supported service provider like Optus Australia Brasil, Straight talk, FamilyMobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo NOKIA Lumia 830 Unlocking instructions: 1: Turn on phone with Not Accepted SIM card. 2: A menu will pop up to Insert the code. 3: Insert the provided code and press OK 4: Device is now unlocked. How to Factory Reset/ Hard Reset NOKIA Lumia 830: How to Reset NOKIA Lumia 830 pattern lock: WARNING ! Hard Reset will erase all of your data All described operations you are doing at your own risk. First Method:
Second Method:
How to Update NOKIA Lumia 830 to latest Firmware: Before starting a software update, we recommend that you make enough space on your phone. You need to have up to 1.5GB (depending on phone model) free phone memory to ensure that the software update goes smoothly. To check the available free space, go to Settings > Storage check. There can be several updates available for your phone, so you may need to repeat the process a few times to get to the latest version. Follow all the update prompts so that you don’t miss out on any of the latest goodies. To see your current software version, go to Settings > Extras + Info. We've recently announced that Windows 10 will be available later this year and it is our ambition to make an upgrade available to all Lumia smartphones running Windows Phone 8.1. In order to prepare your phone for Windows 10, you will need to have Lumia Denim (OS version 8.10.14219.341, or higher) installed. Step 1: Your phone notifies you when an update is available for you. You can also check for updates by going to Settings > Phone Update and tapping Check for updates.
Step 2: To view and to install the updates, tap the notification message, and follow the instructions shown on your phone. You can install the update immediately, or postpone the update to a more convenient time. Step 3: The update should take around 15-30 minutes, but a major update could take up to 2 hours to complete depending on your phone model. You are not able to use your phone during the update installation. Follow all the update prompts, and do not worry if your phone restarts several times during the process, that is completely normal. Additional app updates from the Store could be needed to fully enable new features for your phone. You will get the app update notification on the Store app shortly after the software update. From Lumia Denim update onwards, you can install phone updates more easily by scheduling them for a time that works best for you. You can find the Preferred install time option from Settings > Phone Update. Some of the phones now also support downloading updates to a memory card. Windows Phone 8 compatible Phone Models Lumia 430 Dual SIM, 435, 435 Dual SIM, 520, 520T, 521, 525, 526, 530, 530 Dual SIM, 532, 532 Dual SIM, 535, 535 Dual SIM, 620, 625, 630, 630 Dual SIM, 635, 636, 638, 640 LTE Dual SIM, 640 XL, 640 XL Dual SIM, 640 XL LTE, 640 XL LTE Dual SIM, 720, 720T, 730 Dual SIM, 735, 810, 820, 822, 830, 920, 920T, 925, 925T, 928, 930, Icon, 1020, 1320 and 1520. How to Root NOKIA Lumia 830: WARNING ! You will lose all your data and it is possible that you may brick your device All described operations you are doing at your own risk.
