Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > WorldGSMcodes
WorldGSMcodes World's Leading unlock code source
Old 07-01-2015, 20:12   #1 (permalink)
Member: 2006815
Sonork: 1596960
Thanks Meter: 122
Thumbs up [2015] How to Unlock AT&T Nokia Lumia 830 Network Code for Vodafone Australia,Optus
Comment débloquer AT & T Nokia Lumia 830 Code de réseau pour Vodafone Australie, Optus
Cómo desbloquear AT & T Nokia Lumia 830 Código de red para Vodafone Australia, Optus
NOKIA Lumia 830 Overview :
The successor to the Lumia 820 is another colorful Windows Phone with signature characteristics like a Lumia 1020-like 10MP PureView rear camera with OIS, a removable back cover, and hardware capacitive buttons. Designed as an affordable high-end device, the Lumia 830 houses a 5-inch 720p panel, and it's powered by a quad-core Snapdragon CPU. It runs on Windows Phone 8.1 with the Lumia Denim update.
NOKIA Lumia 830 Sim Unlocking :
Unlock Bell NOKIA Lumia 830 to use any where in the world with any supported service provider like
Optus Australia Brasil, Straight talk, FamilyMobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo
Only at
http://www.WorldGSMCodes.com/
Click here to buy Unlock code
NOKIA Lumia 830 Unlocking instructions:
1: Turn on phone with Not Accepted SIM card.
2: A menu will pop up to Insert the code.
3: Insert the provided code and press OK
4: Device is now unlocked.
How to Factory Reset/ Hard Reset NOKIA Lumia 830:
How to Reset NOKIA Lumia 830 pattern lock:
WARNING !
Hard Reset will erase all of your data
All described operations you are doing at your own risk.
First Method:
  1. Press Power button, until your phone is on.
  2. Then go to Settings -> About -> Reset your phone.
  3. Now confirm all warnings on your screen.
  4. Good job!
Second Method:
  1. Make sure, that your phone is off.
  2. Press Power button once.
  3. Next you should to press and hold Volume Down until you see exclamation mark on the screen.
  4. Then press this buttons in sequence: Volume Up -> Volume Down -> Power button -> Volume Down.
  5. That's all.
How to Update NOKIA Lumia 830 to latest Firmware:
Before starting a software update, we recommend that you make enough space on your phone. You need to have up to 1.5GB (depending on phone model) free phone memory to ensure that the software update goes smoothly. To check the available free space, go to Settings > Storage check.
There can be several updates available for your phone, so you may need to repeat the process a few times to get to the latest version. Follow all the update prompts so that you don’t miss out on any of the latest goodies. To see your current software version, go to Settings > Extras + Info.
We've recently announced that Windows 10 will be available later this year and it is our ambition to make an upgrade available to all Lumia smartphones running Windows Phone 8.1. In order to prepare your phone for Windows 10, you will need to have Lumia Denim (OS version 8.10.14219.341, or higher) installed.
Step 1: Your phone notifies you when an update is available for you. You can also check for updates by going to Settings > Phone Update and tapping Check for updates.
  • Tip! Use a Wi-Fi network to download the update and avoid mobile data transmission costs. Before starting the update, connect to a charger or make sure your phone has enough battery power (at least 50%). You might also need to make enough space on your phone for the update (up to 1.5 GB, depending on the phone model). To check for available free space, go to Settings > storage sense (storage check).
Step 2: To view and to install the updates, tap the notification message, and follow the instructions shown on your phone. You can install the update immediately, or postpone the update to a more convenient time.
Step 3: The update should take around 15-30 minutes, but a major update could take up to 2 hours to complete depending on your phone model. You are not able to use your phone during the update installation. Follow all the update prompts, and do not worry if your phone restarts several times during the process, that is completely normal.
Additional app updates from the Store could be needed to fully enable new features for your phone. You will get the app update notification on the Store app shortly after the software update.
From Lumia Denim update onwards, you can install phone updates more easily by scheduling them for a time that works best for you. You can find the Preferred install time option from Settings > Phone Update. Some of the phones now also support downloading updates to a memory card.
Windows Phone 8 compatible Phone Models
Lumia 430 Dual SIM, 435, 435 Dual SIM, 520, 520T, 521, 525, 526, 530, 530 Dual SIM, 532, 532 Dual SIM, 535, 535 Dual SIM, 620, 625, 630, 630 Dual SIM, 635, 636, 638, 640 LTE Dual SIM, 640 XL, 640 XL Dual SIM, 640 XL LTE, 640 XL LTE Dual SIM, 720, 720T, 730 Dual SIM, 735, 810, 820, 822, 830, 920, 920T, 925, 925T, 928, 930, Icon, 1020, 1320 and 1520.
How to Root NOKIA Lumia 830:
WARNING !
You will lose all your data and it is possible that you may brick your device
  • CLICK TO DOWNLOAD the Rooting software (free ) Click here
  • Enable 'USB debugging' on your device (you can find this in the settings menu)
  • Enable 'Unknown Sources' on your device (Also under settings)
  • Connect your device to the computer (If needed install the android drivers)
  • Click on one of the ROOT options in this software, and wait till it's finished.
Page generated in 0.14019 seconds with 9 queries
