WorldGSMcodes World's Leading unlock code source |
02-28-2015, 22:02 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Canada
Member: 2006815 Status: Offline Sonork: 1596960 Thanks Meter: 122 | [2015] How to Unlock Virgin LG G3 to work with different service providers worldwide? The new LG G3 flagship sports 5.5-inch, 1440 x 2560 (QHD) pixel resolution screen, which provides the super-crisp, 538 pixels per inch. Dimensions are pretty compact for the screen size, resulting in excellent 76.4% screen to body size ratio. The Android 4.4 KitKat-based handset is powered by a quad-core Snapdragon 801 and 3GB of LPDDR3 RAM. It features 32GB of internal storage and a microSD slot. The main 13-megapixel rear shooter comes with the company's improved Optical Image Stabilization+ and has a laser auto focus assist beam, which delivers fast focus even in low light scenarios. The 2.1-megapixel front-facing cam comes with an "enhanced selfie mode". Unlock Virgin LG G3 to use any where in the world with any supported service provider like Mobilicity, Straight talk, T-mobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Mobilicity, Mobilicity, Mobilicity, Mobilicity, Virgin, Mobilicity, MTS, PC telecom, Mobilicity, Telus, Mobilicity at You can request the code by submitting your imei @ http://Unlock.CanadaGSM.ca Your phone will also keep working with your current lock to service provider. Take Your Virgin LG G3 with you on vacations and use the local service provider sim card in your phone and save roaming fees. Virgin LG G3 Unlocking Instructions 1: Turn on phone with Not Accepted SIM card. 2: A menu will pop up to Insert the code. 3: Insert the provided code and press OK 4: Device is now unlocked. *Not accepted sim card mean any other sim card other then your current locked to network After Unlocking Virgin LG G3 will work with Also any where in the world with any Supported Carrier *Supported carriers can vary based on your locked to carrier and your region, please confirm with your service provider, before placing order Your phone will be permanently Unlocked,it will not erase your contacts or any data from your phone. Reasons to remote unlock your Virgin LG G3 : * If you are travelling, buy a local SIM card and save on roaming fees * The resell value of Virgin LG G3 will increase significantly as it is available to more carriers. * Easily switch between SIM card, using the same phone. * Unlock your phone from the comfort of your own home * You never send your phone to anybody. * There is absolutely no risk of damaging your Virgin LG G3 by unlocking it. * Very easy, no technical experience necessary. * The phone is permanently unlocked, even after updates * Warranty will not be voided by this Code * 100% Guaranteed, if we cannot get you your unlock code we will refund you no questions asked. |
