WorldGSMcodes World's Leading unlock code source |
07-06-2015, 01:55 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Canada
Member: 2006815 Status: Offline Sonork: 1596960 Thanks Meter: 122 | [2015] AT&T Samsung Galaxy Note Edge N915W8 Simcode Unlocking to work with Boost,O2 The Samsung Galaxy Note Edge is a unique device and a first for Samsung: it comes with a screen that curves towards one of the edges of the phone and allowing users to quickly glance at notifications and also use this area to add more controls to the device. The Galaxy Note Edge is a phablet at heart: it packs a 5.6-inch 1440 x 2560-pixel (Quad HD) display. It's also got a powerful Snapdragon 805 system chip and a 16-megapixel OIS camera. Samsung Galaxy Note Edge N915W8 Sim Unlocking : Unlock AT&T Samsung Galaxy Note Edge N915W8 to use any where in the world with any supported service provider like Optus Australia Brasil, Straight talk, FamilyMobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo Samsung Galaxy Note Edge N915W8 Unlocking instructions: 1: Turn on phone with Not Accepted SIM card. 2: A menu will pop up to Insert the code. 3: Insert the provided code and press OK 4: Device is now unlocked. How to Factory reset/ Hard Reset Samsung Galaxy Note Edge N915W8: How to Reset Samsung Galaxy Note Edge N915W8 pattern lock: WARNING ! Hard Reset will erase all of your data All described operations you are doing at your own risk. First Method:
How to Update Samsung Galaxy Note Edge N915W8 to latest Firmware:
How to Root Samsung Galaxy Note Edge N915W8: WARNING ! You will lose all your data and it is possible that you may brick your device All described operations you are doing at your own risk. Step 1: Download and Install Samsung USB Driver on your computer. If Samsung USB Driver is already installed on your computer then Skip this Step. Step 2: Download and extract the root files on your computer. After extracting you will be able to see the following files: Step 3: Now, Switch off your Smartphone. Step 4: After switching-off the phone, you need to boot into Download Mode. To boot into download mode Press and hold Volume Down, Home and Power button at same time for 5-8 seconds until download mode is active. Step 5: In the Download mode you will be able to see a Warning Yellow Triangle Sign. In this situation you have to press the Volume Up key to continue. Step 6: Now, Open Odin3 (found in the extracted files, that you have downloaded in the Step#2) on your computer. Then connect your Smartphone to the computer. Step 7: Once you have connected the Smartphone to the computer, Odin will automatically recognize the device and show “Added” message at the lower-left panel. Step 8: Once your device is detected by Odin, click on the PDA button and select the CF-Auto-Root.tar file (you have downloaded this file in step#2). Step 9: Now, click on the Start button in Odin to begin the Flashing. Step 10: Flashing usually takes 30-50 seconds to complete the rooting process on your Samsung Galaxy Note Edge SM-N915G. Once Rooting process is completed you will be able to see a Green Box with Pass written on it in Odin. During this process Smartphone will re-boot automatically. Step 11: Once you see, the Pass message in Odin, you can disconnect your Device from the computer. Step 12: Now, to make sure you have successfully rooted your Samsung Galaxy Note Edge SM-N915G, open Applications Menu on your Smartphone and Find SuperSU App. If this app exist on your Smartphone then it means you have successfully rooted your device. Congratulations. Optional: You can also verify that your device is successfully rooted or not by Root Checker Application. |
