WorldGSMcodes World's Leading unlock code source |
07-06-2015, 03:18 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Canada
Member: 2006815 Status: Offline Sonork: 1596960 Thanks Meter: 122 | [2015] How to Unlock AT&T HTC Desire 610 Network Code in just 5 Minutes? Fastest WAY The HTC Desire 610 is a mid-range Android smartphone with a 4.7-inch qHD display, 1.2GHz quad core processor, 1GB of RAM, 8GB of storage and a 8-megapixe BSI camera. HTC Desire 610 Sim Unlocking : Unlock AT&T HTC Desire 610 to use any where in the world with any supported service provider like Optus Australia Brasil, Straight talk, FamilyMobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo HTC Desire 610 Unlocking instructions: 1: Turn on phone with Not Accepted SIM card. 2: A menu will pop up to Insert the code. 3: Insert the provided code and press OK 4: Device is now unlocked. How to Factory Reset/ Hard Reset HTC Desire 610: How to Reset HTC Desire 610 pattern lock: WARNING ! Hard Reset will erase all of your data All described operations you are doing at your own risk. First Method:
Second Method:
How to Update HTC Desire 610 to latest Firmware: This software upgrade available for your HTC Desire provides the following key enhancements:
Details Before you proceed, please confirm that this software upgrade to 1.53.502.11 ( 1.53.502.12 for pre-paid devices) is a newer version than what is currently loaded on your device. If it is the same version, there is no need to reload the software. Navigate to the Home screen then tap All apps > Settings > About > Software Information and locate the Software version. If your Software number is less than 1.53.502.11 ( 1.53.502.12 for pre-paid devices), you should proceed with the upgrade. WARNING: During the upgrade process the device will reboot multiple times and show software upgrade screens. Do not remove the AC charger as this might stop the update and your device may be rendered inoperable! Getting Started
Installation Instructions To manually perform the update, follow these steps below: 1.From the Home screen tap All apps, then tap Settings. 2.Tap AT&T Software Update. 3.Tap Check for updates. 4.Tap Continue to download the update. 5.If downloading the update using the mobile data network (not connected to Wi-Fi), you may be prompted with a data fee warning message. If this is acceptable, tap YES to start the upgrade process. 6.Status of the download can be checked in the Notifications pull down. 7.Once the download is complete, the user will be prompted to install from the Notifications pull down. Tap the System update to begin the upgrade process. 8.Tap OK to begin the update process to software version 1.53.502.11 (1.53.502.12 for pre-paid devices). WARNING: During the upgrade process the device will reboot multiple times and show software upgrade screens. Do not remove the AC charger as this might stop the update and your device may be rendered inoperable! 9.Device will reboot and begin installation. Users will not be able to use their device during the installation process (approximately 10 minutes). 10.The system update is complete. Tap OK to continue. How to Root HTC Desire 610: WARNING ! You will lose all your data and it is possible that you may brick your device All described operations you are doing at your own risk.
Note: if after flashing the SuperSU file your device will get stuck in a boot loop, go back to recovery. From there this time select “wipe data factory reset” and “wipe cache partition”. Then, go to main menu of recovery and pick “reboot system now”. Congratulations; you have successfully rooted your HTC Desire 610. That was all for now, but don’t forget that you can consider in updating your device with a custom ROM firmware and in performing other custom operations for optimizing the performances and for obtaining more power from your Android based smartphone. |
