Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > WorldGSMcodes
WorldGSMcodes World's Leading unlock code source
Old 07-06-2015, 02:32   #1 (permalink)
Member: 2006815
Sonork: 1596960
Thanks Meter: 119
Thumbs up [2015] AT&T Samsung Galaxy S6 Active Simcode Unlocking to use with Digicel,Optus,Tele
Samsung Galaxy S6 Active Overview :
The Samsung Galaxy S6 Active features the same 5.1-inch screen that the regular Galaxy S6 is offering. The rugged version of Samsung's latest flagship handset is powered by the same octa-core Exynos 7420 processor, offering a 16 MP rear camera, and a 5 MP front-facing camera. 3 GB of RAM and 32 GB of internal memory is included. However, the Galaxy S6 Active has a bigger battery (3500 mAh), measuring 146.8 x 73.4 x 8.6 mm - thus being a bit larger and thicker than both the S6 and S6 edge.
Samsung Galaxy S6 Active Sim Unlocking :
Unlock AT&T Samsung Galaxy S6 Active to use any where in the world with any supported service provider like
Optus Australia Brasil, Straight talk, FamilyMobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo
Only at
http://www.WorldGSMCodes.com/
Click here to buy Unlock code
Samsung Galaxy S6 Active Unlocking instructions:
1: Turn on phone with Not Accepted SIM card.
2: A menu will pop up to Insert the code.
3: Insert the provided code and press OK
4: Device is now unlocked.
How to Factory Reset/ Hard Reset Samsung Galaxy S6 Active:
How to Reset Samsung Galaxy S6 Active pattern lock:
WARNING !
Hard Reset will erase all of your data
All described operations you are doing at your own risk.
First Method:
  1. In order to turn off the device hold down the Power key for a short while.
  2. Afterwards press and hold together: Volume Up + Home + Power button for a while.
  3. You can release held keys when the Samsung Logo appears on the screen
  4. Then select from Recovery Mode menu "wipe data / factory reset" using Volume buttons to navigate and Power button to confirm.
  5. Choose "Yes -- delete all user data" to confirm the whole operation.
  6. After that select option "reboot system now".
  7. Well done! The hard reset has just been performed.
Second Method:
  1. Start by turninng on the device by using the Power button.
  2. From the Home Screen go to Menu and then to Settings.
  3. Tap Backup & Reset and then Factory data reset.
  4. In the next step find and choose Reset device.
  5. To confirm your choice select Erase everything.
  6. That's all. The hard reset is done.
How to Update Samsung Galaxy S6 Active to latest Firmware:
  1. Connect your device to your computer using the USB cable. ...
  2. Open Kies. ...
  3. Click Firmware upgrade to start the upgrade process.
  4. A pop-up message may also display when you connect your device to Kies. ...
  5. You will be taken through the backup process to preserve all of your data.
How to Root Samsung Galaxy S6 Active:
WARNING !
You will lose all your data and it is possible that you may brick your device
Pre –Requesties for Rooting Samsung Galaxy S6 Active:
  • This guide is made especially for Samsung Galaxy S6 Active SM-G890.
  • To check device model, tap on Settings> More/ General> About Device. Check the Model number written there. If you have some other device. Stop right here.
  • Make sure to have at least 60% charged battery so that your device stay alive during the whole rooting process.
  • Backup Your data before Rooting your device. In some cases users have lost all their important data including SMS, Call Log, Contacts, Media files, Calendar etc.
  • Make Sure that the USB Debugging Mode is enabled in the Developers menu under Settings option.
  • Make sure to Turn off Samsung Kies and other software if you are Using ODIN 3.09 while doing the rooting of your device. As using Odin is the most recommended way of rooting or flashing a Samsung device.
  • Last and most Important: We will not be responsible if your device stuck during the process or after it. So do it on your own risk. If you are a newbie, Read more rooting guides before trying this.
How To Root Galaxy S6 Active SM-G890:
First of all make sure to download these files needed to root Galaxy S6 Active
How to root Procedure:
  • First of all Extract the CF-Auto-Root files to get the *.tar.md5 Files.
  • Now open the Odin 3 v3.09.exe.
  • Now turn your device S6 Active on Download mode by pressing and holding the Power + Home + Volume Down buttons all together for at least 10 seconds. If you see the warning notice press the Volume Up button now.
  • Now Connect your S6 Active with your PC.
  • ID COM box will turn blue soon after your device will be detected on Odin 3.09. If not make sure to download and Install the Samsung USB Drivers given above.
  • Now click on the AP tab on Odin3 v3.09 and add the CF-Auto-Root *.tar.md5 file.
  • You can do the same by clicking on the PDA tab if you are using the Older version of Odin3, i.e Odin 3.07
  • Make sure that your Odin3 V3.09 looks like this one in the screenshot below.
  • Everything ready. Now Hit start and your device will get rooted automatically.
  • You can find the SuperSu app on your device now.
  • That’s it You have successfully Rooted your Galaxy S6 Active.
If you want to verify your device is rooted or not, You can download the Root Checker app from Google Play Store. Tap on the Root checker option in the app and then tap on Verify Root. It will ask for grant from SuperSU, tap on Grant. The message will appear that the Root Access is Verified Now! That’s it. Your device is Rooted now and you can customize it the way you want it to be.
Page generated in 0.19279 seconds with 7 queries
