WorldGSMcodes World's Leading unlock code source |
07-25-2014, 01:20 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Canada
Member: 2006815 Status: Offline Sonork: 1596960 Thanks Meter: 122 | Huawei D51 Discovery Factory Code Unlocking to work for Virgin Australia,3 Hutchinson Huawei D51 Discovery have Mini-SIM Card Slots,Huawei D51 Discovery support all GSM Based network providers. Huawei D51 Discovery mobile device support 2G Band Frequency at GSM 850,GSM 900,GSM 1800,GSM 1900 and there is no 3G Network Band Support,comes with network handling support with Network settings and work offline with flight Mode. Huawei D51 Discovery is a Bar device and it have device dimension with 114.5 x 50.5 x 16 mm, (4.51 x 1.99 x 0.63 in). Phone weight including the Battery 106g, (3.74 oz). Phone gave a dedicated Call,End and Power key,5-way Navi Key. Huawei D51 Discovery display enhanced with TFT Transmissive capable to display 256K colors at ~200 ppi pixel density . Unlock Huawei D51 Discovery to use any where in the world with any supported service provider like AT&T, Straight talk, T-mobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo at You can request the code by submitting your imei @ http://www.uunlock.com Your phone will also keep working with your current lock to service provider. Take Your Huawei D51 Discovery with you on vacations and use the local service provider sim card in your phone and save roaming fees. Huawei D51 Discovery Unlocking Instructions 1: Turn on phone with Not Accepted SIM card. 2: A menu will pop up to Insert the code. 3: Insert the provided code and press OK 4: Device is now unlocked. *Not accepted sim card mean any other sim card other then your current locked to network After Unlocking Huawei D51 Discovery will work with Also any where in the world with any Supported Carrier *Supported carriers can vary based on your locked to carrier and your region, please confirm with your service provider, before placing order Your phone will be permanently Unlocked,it will not erase your contacts or any data from your phone. Reasons to remote unlock your Huawei D51 Discovery : * If you are travelling, buy a local SIM card and save on roaming fees * The resell value of Huawei D51 Discovery will increase significantly as it is available to more carriers. * Easily switch between SIM card, using the same phone. * Unlock your phone from the comfort of your own home * You never send your phone to anybody. * There is absolutely no risk of damaging your Huawei D51 Discovery by unlocking it. * Very easy, no technical experience necessary. * The phone is permanently unlocked, even after updates * Warranty will not be voided by this Code * 100% Guaranteed, if we cannot get you your unlock code we will refund you no questions asked. |
