WorldGSMcodes World's Leading unlock code source |
04-24-2014, 14:12 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Canada
Member: 2006815 Status: Offline Sonork: 1596960 Thanks Meter: 122 | Mobilicity Samsung Gravity 2 SGH T469 Network Code Unlocking to use with O2,Digicel Samsung Gravity 2 T469 is a side-slider GSM featuring QWERTY keyboard, 2MP camera, color display, Bluetooth, music player and microSD slot for memory. Unlock Mobilicity Samsung Gravity 2 SGH T469 to use any where in the world with any supported service provider like AT&T, Straight talk, T-mobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN, Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo at You can request the code by submitting your imei @ http://uunlock.com/ Your phone will also keep working with your current lock to service provider. Take Your Mobilicity Samsung Gravity 2 SGH T469 with you on vacations and use the local service provider sim card in your phone and save roaming fees. Mobilicity Samsung Gravity 2 SGH T469 Unlocking Instructions 1: Turn on phone with Not Accepted SIM card. 2: A menu will pop up to Insert the code. 3: Insert the provided code and press OK 4: Device is now unlocked. Method: 2 1: Turn on phone with Orignal sim card. 2: Dial #7465625*638*CODE# 3: Device is now unlocked. To make sure if your phone is Unlocked now dial *#7465625# ,if all your security levels are off or disabled then your phone is completely Unlocked. If your phone also has Service provider code enabled then you also do need to apply that by pressing #7465625*77*SP CODE# *Not accepted sim card mean any other sim card other then your current locked to network After Unlocking Mobilicity Samsung Gravity 2 SGH T469 will work with Also any where in the world with any Supported Carrier *Supported carriers can vary based on your locked to carrier and your region, please confirm with your service provider, before placing order Your phone will be permanently Unlocked,it will not erase your contacts or any data from your phone. Reasons to remote unlock your Mobilicity Samsung Gravity 2 SGH T469 : * If you are travelling, buy a local SIM card and save on roaming fees * The resell value of Mobilicity Samsung Gravity 2 SGH T469 will increase significantly as it is available to more carriers. * Easily switch between SIM card, using the same phone. * Unlock your phone from the comfort of your own home * You never send your phone to anybody. * There is absolutely no risk of damaging your Mobilicity Samsung Gravity 2 SGH T469 by unlocking it. * Very easy, no technical experience necessary. * The phone is permanently unlocked, even after updates * Warranty will not be voided by this Code * 100% Guaranteed, if we cannot get you your unlock code we will refund you no questions asked. |
