WorldGSMcodes World's Leading unlock code source |
10-01-2014, 00:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Canada
Member: 2006815 Status: Offline Sonork: 1596960 Thanks Meter: 122 | Telus BlackBerry Curve 9360 Code Unlocking to work with Sasktel,Tbaytel,PC-Mobile BlackBerry Curve 9360 is a BlackBerry Smartphone running BlackBerry OS 7.0 and features 800MHz processor. It has a 2.44 inches (480 x 360 pixels, 246 ppi) display, and is powered by its 1000 mAh Standard battery, Li-Ion. In terms of storage it has 512 MB storage, 512 MB RAM and storage is expandable via microSD, up to 32GB. Pros
Unlock Telus BlackBerry Curve 9360 to use any where in the world with any supported service provider like AT&T, Straight talk, T-mobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN, Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo at You can request the code by submitting your imei @ http://uunlock.com/ Your phone will also keep working with your current lock to service provider. Take Your Telus BlackBerry Curve 9360with you on vacations and use the local service provider sim card in your phone and save roaming fees. Telus BlackBerry Curve 9360 Unlocking Instructions 1: Turn on phone with Not Accepted SIM card. 2: A menu will pop up to Insert the code. 3: Insert the provided code and press OK 4: Device is now unlocked. Method 2: 1: Trun on phone without any Sim card 2: Go to Options>>Device>>Advance System Settings>>SIM CARD 3: Type MEP2 while Holding ALT key. 4: A menu will popup to Enter the code. 5: Type in the code and Press Enter Note: While inserting the code make sure your wifi and bluetooth is OFF After Unlocking Telus BlackBerry Curve 9360will work with Also any where in the world with any Supported Carrier *Supported carriers can vary based on your locked to carrier and your region, please confirm with your service provider, before placing order Your phone will be permanently Unlocked,it will not erase your contacts or any data from your phone. Reasons to remote unlock your Telus BlackBerry Curve 9360: * If you are travelling, buy a local SIM card and save on roaming fees * The resell value of Telus BlackBerry Curve 9360will increase significantly as it is available to more carriers. * Easily switch between SIM card, using the same phone. * Unlock your phone from the comfort of your own home * You never send your phone to anybody. * There is absolutely no risk of damaging your Telus BlackBerry Curve 9360by unlocking it. * Very easy, no technical experience necessary. * The phone is permanently unlocked, even after updates * Warranty will not be voided by this Code * 100% Guaranteed, if we cannot get you your unlock code we will refund you no questions asked. |
